Espritmodel.com Heli Air
Old Sep 14, 2011, 06:51 PM
Joined Sep 2011
Finding replacement wing rods/ identify this sailplane?
I have this 6 channel sailplane, with a wingspan of approximately 3 meters (see pics). During a recent move across the country, the wing rods got lost for the wings and vertical stabilizer. How exactly do I get a new set of rods? Any suggestions?
I have no clue what type of sailplane this is. Got it a few years ago from an old club member who no longer flies, he doesn't remember what it is either. Apparently it's an older model. I'm thinking if i knew the make of the sailplane, it would facilitate finding replacement parts?
king of flats is offline Find More Posts by king of flats
Old Sep 14, 2011, 10:50 PM
slopemeno's Avatar
United States, CA, Mill Valley
Joined Jan 2003
Dixiepins. Hardened mold ejector pins, in inch or metric.
slopemeno is offline Find More Posts by slopemeno
Latest blog entry: F-20 update
Old Sep 15, 2011, 06:06 AM
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Lincoln Is the man to ask about this one,He will probably know what it is .
As far as the wing rods go there are a number of sources for the rods, are they carbon fiber or aluminum?
doc993 is offline Find More Posts by doc993
Old Sep 15, 2011, 09:25 AM
Greensboro, Pa.
Joined Jun 2002
Looks like a Pulsar from Bob Sealy. I could be wrong but that is what it looks like to me. He sold 2 or 3 versions of that sailplane.
PDARR is offline Find More Posts by PDARR
Old Sep 15, 2011, 11:54 AM
JimN8UAY
United States, OH, Medina
Looks like a pretty Falcon 880 to me!
Jimn8uay is offline Find More Posts by Jimn8uay
Old Sep 15, 2011, 02:39 PM
Play loud, Fly high
Gil Gauger's Avatar
Vincennes,IN USA
Joined Apr 2007
Rods
Determine the length required by measuring the depths of the tubes in the wings and stabs, and the length needed to reach through the fuse. Use drill bits to accurately guage the rod diameters. Most planes from that era used music wire rods. Ejector pins are better.
Gil Gauger is online now Find More Posts by Gil Gauger
Old Sep 15, 2011, 07:17 PM
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
It's a Pulsar fuse, with a different wing on it, maybe. The Pulsar had a 100 inch wing if I remember right. Maybe there was an Pulsar XL at one time....
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old Sep 15, 2011, 07:53 PM
Joined Dec 2003
Rods
www.vintagesailplanes.com
Send diameter and length. Steel, Stainless, Aluminum, ejector pins, etc.
Jim
vintagesailplnr is offline Find More Posts by vintagesailplnr
Old Sep 16, 2011, 06:32 PM
Joined Sep 2011
Thanks guys. This aircraft originally had stainless wing rods. What is the advantage of the ejector pins vs stainless?
Old Sep 16, 2011, 07:18 PM
Joined Dec 2003
SS will not rust!
Ejector may tarnish in time - but rubbing with 400# steelwool will solve the tarnish problem.
Jim
Old Sep 16, 2011, 09:24 PM
United States, MA, Waltham
Joined Dec 2001
Moi? I want to say Dodgson Saber, but I don't think the area of the fuse near the wing is right. Otherwise, it seems similar. But I'm not sure what makes me an expert!
lincoln is offline Find More Posts by lincoln
Old Sep 17, 2011, 07:27 AM
Williamsburg, VA
Joined Apr 2004
Don't think it is a Dodgson Design...
Believe that the planform on the Saber was like the Windsong/Lovesong/Anthem, single taper from root to tip.
Vertical stab/rudder looks awfully low-profile as well (though it could be 'compression' from the camera angle).
r/
Dave (who's still trying to finish a Lovesong started in the late 90's!!!)
D_Ryan is offline Find More Posts by D_Ryan
Old Sep 17, 2011, 05:32 PM
Joined Dec 2001
I distinctly remember that the Saber was NOT a single taper. It also had a shorter span and lower aspect ratio than those others.
Old Sep 20, 2011, 06:55 AM
'da Range
Joined Nov 2003
You can use Carbon fiber rods for the tail feathers; take your stabs to a local hobby shop and fit them. You'll have to buy a 36 in piece of two sizes, but they're cheap. Your could also measure the size and order from:
http://www.acp-composites.com/home.php?cat=4662
I would use Al for the main wingrods because of weight. An 18 in 7076 rod, 1/2 in dia, weighs around 5 oz whereas a similar size steel rod weighs 16 oz. Of course, in windy situations you may want the steel.
Bulk 7076 Al rod cut to length can be obtained from:
http://www.speedymetals.com/c-8369-7075.aspx
You will then need to 'BEND' the Al rod to approx 5 - 6 degrees creating a little dihedral when installed in your plane.
Note - you need the stronger 7076 rod!
I just went thru this process...I bent the 7076 using two pieces of regular pipe. I practiced on the less strong 6061 rod that I obtained from a local bulk metals shop. I paid $12 for three pieces of 6061, cut plus the two pieces of pipe... IMO, Your not going to be able to bend the steel rod with this process!!! This shop did NOT carry the stronger 7076 Aluminum rod, although he could order it.
If you determine you really want the 6061 rod, I will give you my bent practice piece; you pay for the shipping. I'm sure it would work, but it won't hold up to a full winch launch so that is why I'm not going to use it. 6061 is only what is available today pre-cut/bent from stores on the net, if you can find it, which is why I went my own route. It was a fun project to go thru.
My plane flys beautifully.
JrcSeller is offline Find More Posts by JrcSeller
Discussion Help!! Identify this plane interplanet Giant Scale Airplanes 12 Oct 18, 2011 08:21 PM
Help! Need help finding 13MM wing joiner Kenbogunz Composites Fabrication 5 Sep 19, 2011 09:46 PM
Found Wing Rods 4 118" Craft Air Viking MkII Wylie Shaw Aircraft - Sailplanes (FS/W) 4 Sep 07, 2011 07:44 AM
Question can anyone identify this delta wing? Roadawg27 Flying Wings 4 Aug 12, 2011 11:40 PM
Help! Help finding wing for this twin 55mm F-22 impostor Foamy EDFs 3 Apr 11, 2011 10:43 PM
