Old Oct 31, 2011, 10:31 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
And we thought you would not notice
clive45 is offline Find More Posts by clive45
Old Oct 31, 2011, 10:39 PM
CARL SCHIMNOWSKI is offline
Find More Posts by CARL SCHIMNOWSKI
Joined May 2007
Patience is a virtue ....... waiting is a pain in the aileron
CARL SCHIMNOWSKI is offline Find More Posts by CARL SCHIMNOWSKI
Old Oct 31, 2011, 11:23 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
And the HK Hawk is the same plane as the NitroPlanes T-45...If you want to see a build thread then just look at the CMP NitroPlanes T-45 thread.......
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Nov 01, 2011, 08:33 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Yeah I noticed that too. Dont care...i like CMP
vettster is offline Find More Posts by vettster
Old Nov 01, 2011, 09:24 PM
Joined Mar 2007
I like CMP too!!!...I'm working on my T-45 as we speak...I can't believe how much plane you get for so little $$$---I'm happy and looking forward to many flights..
Kevin
Old Nov 02, 2011, 03:14 AM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Any one know if the pilots have turned up yet or do they work for QANTAS
Old Nov 02, 2011, 07:57 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Originally Posted by Pilot_Tony View Post
. The one I'm after is the UK demo team version ine the link above.
Stunning! Cant be long as they had quite a few planes in that review. the g500 has just been stocked in the US warehouse
lipoflyer is offline Find More Posts by lipoflyer
Old Nov 02, 2011, 09:51 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
ohhh harsh...
They haven't turned up because the potato munching cowboy joyce has locked them out!
dave
ticketec is offline Find More Posts by ticketec
Old Nov 22, 2011, 03:34 AM
Blackcataircraft is offline
Find More Posts by Blackcataircraft
Blackcataircraft's Avatar
Australia, WA, Esperance
Joined Dec 2010
HK Bae 90mm Hawk
Guy's I have one it is fibreglass with built up wings. The kit is finished of beautifully, how ever she does carry a bit of weight and you will need to really plan it out. I have a jetfan 90 with a Het 700-68 running 8s to which is coming from Extremerc in Oz. The problem I have now is i dont have the retracts as they ran out. Unknown as to when they will be back in stock. The ducting is great everything fits nicely without too much stuffing around. There are a couple of things that I have changed on her. i would trust the push rods they supply, I'm going with carbon. The canopy is screwed on so that got cahged I placed 2 pieces of ply under the front and a solid block at the rear with a hatch latch. There are 2 small pieces of alloy for the mounting of the wing to go into the fuselage, however where they have cut the slot it's been made to big so I had to cut a small piece of hardwood in to make it a tight fit. The pilots are not to scale and i ahd to trim down the rear so I could get his helmet of the canopy, also had to trim some of the sides so they could sit in straight. Need to epoxy / microfill the gaps around the inlet and the ducting tubes. no biggy. It doesn't come as stated in Scott's sneak peak video, eg drop tank fixed undercarriage, so I'm a little disappointed. The instruction manaul isn't great deal of help as it doesn't have a check list as you get with other kits, the C of G is out so they can't have flown it before going to market.
Blackcataircraft is offline Find More Posts by Blackcataircraft
Old Nov 22, 2011, 07:59 AM
Scott Cuppello is offline
Find More Posts by Scott Cuppello
Commercial UAV Pilot
Scott Cuppello's Avatar
United Kingdom, England, Carlisle
Joined Mar 2007
I have sent an e-mail to the factory today with regard U/C, etc as a few people have said they were missing. As for C of G, they said they HAD flown it and thought it was ok....well, if you dealt with these factories as I do, you wouldn't be very suprised to hear that...they were told to get it changed.
Scott Cuppello is offline Find More Posts by Scott Cuppello
Old Nov 22, 2011, 08:34 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
How is your Hawk build coming along Scott.as a matter of interest what CG will you be using.
Gaz-b is offline Find More Posts by Gaz-b
Old Nov 22, 2011, 09:07 AM
Joined Mar 2007
Mate, not even started it yet...like everyone else, starting at 105mm.
Old Nov 22, 2011, 10:28 AM
SniperWj is offline
Find More Posts by SniperWj
The Sarawak KoloMee
SniperWj's Avatar
Singapore
mine dont come with wheel well too
SniperWj is offline Find More Posts by SniperWj
Old Nov 22, 2011, 12:30 PM
torque roll is offline
Find More Posts by torque roll
A Texan abroad
torque roll's Avatar
Joined Oct 2011
Yups. The undercairage is pretty important.
torque roll is offline Find More Posts by torque roll
Old Nov 22, 2011, 03:17 PM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
Mine came today. It's my Christmas present, so can't play with it yet....just a quick check for damage. All arrived in perfect condition, she's a real looker, but as mentioned no drop tank / fixed gear / wheel wells or doors. Don't mind about the tank / gear but, as ill be going the retract route, could really use the wells and doors. Sure hope HK comes good with the missing parts, its a beautiful bird.
SMorrisRC is offline Find More Posts by SMorrisRC
Build Log Jet Teng Models Full Composite 90MM Bae Hawk V2 From RC-Warbirds Build & Video's FlyBoyTha1 Electric Ducted Fan Jet Talk 701 Mar 23, 2015 07:32 PM
For Sale Jet teng 90mm Bae Hawk swiss rtf newly assembled $1500 jetfan20 Aircraft - Electric - Jets (FS/W) 1 Jun 05, 2011 03:00 AM
Discussion is there a build thread somewhere on the fly fly bae hawk ? aviador Foamy EDFs 1 Feb 04, 2008 10:42 PM
Question Build thread on BAE Hawk nitro models/raidentech? carl rich Electric Ducted Fan Jet Talk 12 Apr 09, 2007 04:44 PM
CJM BAE Sport Hawk build thread gregg f Electric Ducted Fan Jet Talk 26 Jan 28, 2006 01:55 PM
