Espritmodel.com Heli Air
Old Sep 14, 2011, 08:09 PM
Congress, AZ
Joined Sep 2001
Tom,
Could you elaborate on this a bit: "IE only up deflection and turning isn't much of an issue."
The only time I tried rudderless, if only the one flap was deflected up, then the plane sort of lurched as if it couldn't decide what to do. I finally figured out that the down wing was just generating drag and the plane would try to turn into it. The plane turned, but the wrong direction.
I suppose I could have done some mixing and in effect reversed the rudder controls when flaps were down, but finally just gave up.
Gary
GaryO is offline Find More Posts by GaryO
Old Sep 14, 2011, 08:17 PM
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Originally Posted by GaryO View Post
Tom,
Gary
Tom was talking about that only when his flaps are down for landing......the flaps (aileron) is already so far down that moving it farther down is useless. SO he uses his differential setting to 100% so only one flap moves up for turning
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Sep 15, 2011, 07:05 AM
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Yep.
That's exactly what I meant. My normal program (float, thermal) has just a pinch of negative differential. I think I use some "normal" differential in speed mode.
tom43004 is offline Find More Posts by tom43004
Old Sep 15, 2011, 08:53 PM
Congress, AZ
Joined Sep 2001
So the turn is actually towards the raised aileron? Mine always seemed to turn to the unmoved flap (drag?)
Maybe I'm deploying the flaps too far. I'll have to check it out.
Gary
Old Sep 15, 2011, 10:11 PM
Joined Apr 2007
If my flaps are down much past 45 degrees, turning without rudder is sketchy at best.
I have a flight mode for landing that moves the flaps to about 30-35 degrees down for slow flight, but good turning. To slow beyond that I use the throttle stick to slam the flaps to max, take them full off (30-35degrees position) for turning corrections, and slam on the flaps again when I'm straight.
It's all about knowing the limits and working either within them or around them
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
Discussion Cancer Surges In Body Scanner Operators; TSA Launches Cover-Up P-51C Life, The Universe, and Politics 10 Jun 29, 2011 10:02 AM
Help! DLG flies parallel to ground on hard launches?! apex Hand Launch 34 Jun 18, 2011 03:36 PM
