Old Sep 14, 2011, 09:46 AM
isoarthenland is offline
Find More Posts by isoarthenland
Russ Young
isoarthenland's Avatar
United States, UT, South Jordan
Joined Mar 2006
Rudderless launches
I've just started paying attention to DLG's and was wondering:
On a rudderless DLG, how is a straight launch achieved without associated rudder deflection to offset the forces of spinning?
Russ
isoarthenland is offline Find More Posts by isoarthenland
Old Sep 14, 2011, 10:05 AM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Generally no rudder deflection is used anyway. Modern DLGs are designed not to need it.
Usually when rudder is needed on a launch nowdays, it is due to one of two things. First is technique, where the thrower hooks the launch. Rudder is then a partial correction for poor technique.
Second, it is from not having a stiff enough rudder linkage setup. That includes the pushrod (or pull-spring) and the servo. Skimping in this area is not a good idea.
One problem with using rudder preset on launch is that the timing for releasing it tends to be different than what one wants for releasing the elevator preset.
Gerald
G_T is offline Find More Posts by G_T
Old Sep 14, 2011, 10:06 AM
glidermang is online now
Find More Posts by glidermang
Russ:
Not to worry: few, if any rudder-equipped DLGs actually have to have rudder input.
The normal yaw stability will usually result in a straight launch, if you release wings level.
I used to use rudder offset on a polyhedral DLG, but eventually, I even straightened that one out.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Sep 14, 2011, 10:30 AM
Russ Young
Joined Mar 2006
Thanks guys.
Greg, my only DLG is a 4 year old Gambler AG poly that I only have flown occasionally. I launched it with a bit of rudder offset. I intend on overcoming any launching bad habits when I start up with competition planes.
Russ
Old Sep 14, 2011, 11:08 AM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Hey Russ, be sure to come down to Orem this weekend for the Blue Skies over Utah event (http://www.rcgroups.com/forums/showthread.php?t=1443980). There's still room for more contestants and we would equally welcome spectators.
jfinch is offline Find More Posts by jfinch
Old Sep 14, 2011, 11:30 AM
FD Pilot is offline
Find More Posts by FD Pilot
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
So what are the advantages and disadvantages of going rudderless? Bruce Davidson endorses the rudderless approach in the Radio Carbon Art DLG videos. I'm building a Taboo GT and I'm at the decision point to go rudderless or not so your opinions are being solicited.
FD Pilot is offline Find More Posts by FD Pilot
Old Sep 14, 2011, 11:32 AM
Russ Young
Joined Mar 2006
jfinch,
I've been lurking around DLG for a couple weeks now. I'll be there to watch and help(if needed) this weekend...I won't join in the fun this time around...an old Gambler AG would not do too well against modern comp. planes...although, it does find 15' lift on occasion.
Russ
Old Sep 14, 2011, 11:35 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I'm rudderless. It's one less servo, one less pushrod, one less adjustment, simpler construction, but most of all it's a stiffer tail so you have an airframe that is less compliant at the time of the first yaw excursion. That equates to measurable launch height increase.
Sometimes I wish I had a rudder in flight, but it's not terribly often and it's hard to quantify whether or not it costs me anything in terms of flight time.
tom43004 is offline Find More Posts by tom43004
Old Sep 14, 2011, 11:38 AM
Russ:
I will be at the Blue Skies. Please stop in and ask around.
Yours, Greg
Old Sep 14, 2011, 11:53 AM
FD Pilot is offline
FD Pilot's Avatar
Phoenix, AZ
Joined Nov 2006
Tom,
Some say rudder is advantageous in tight strong thermals and slow speed flaps down roll initiation. Oleg, stated he flew a ruderless Taboo and didn't like it, but didn't mention any performance negatives other than odd/different handling that you have to get used to and play with aileron differential to tune-out. Did you use aileron differential?
Old Sep 14, 2011, 12:16 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Originally Posted by FD Pilot View Post
Tom,
I don't use significantly different differential than I did on ruddered airplanes. Yes, you have to fly a bit differently here and there, but after a week or two you hardly notice it.
Flaps down I have 100% differential programmed... IE only up deflection and turning isn't much of an issue.
Old Sep 14, 2011, 12:46 PM
mrdoodah is offline
Find More Posts by mrdoodah
Joined Apr 2009
I learnt as a newby on a rudderless, just what is a rudder please ?
mrdoodah is offline Find More Posts by mrdoodah
Old Sep 14, 2011, 01:21 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
A rudder makes a plane more fun to fly IMO. This past summer I got into some super strong thermals down low and had my glider hooked so tight I know it couldnt of happened without my rudder. Im sure I could have been flatter and much more efficient but Im into this for kicks as well and the darn thing was super cool to see literary climbing like crazy in about a 10 ft radius
Concerning performance. I believe rudderless has a advantage for launch ,sink rate but down low [below 30 ft] rudders rule.
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Sep 14, 2011, 01:49 PM
G_T is offline
G_T
G_T
Joined Apr 2009
Also rudders are useful for landing and when playing tag with trees. I've handed planes with rudders to people and had them be amazed by the launch height. It is how you set it up.
I'm solidly in the rudder camp.
I rarely need a lighter plane.
Gerald
PS - I'd suggest flying helo a bit for those who lack good control of their left thumbs.
Old Sep 14, 2011, 02:30 PM
Bad scientist is offline
Find More Posts by Bad scientist
Joined Feb 2009
I love my rudder to pieces!
Earlier this summer, I broke my pull/pull rudder connection. I decided to try flying rudderless for a couple of weeks, partly to check it out, and partly because i did not have the time to do the repair. I simply taped it up, and tossed it. I belive i might have gained a few extra feet on the launch, but flying without rudder really lessened the flying pleasure imo.
The joy of making a perfect coordinated turn is such a big part of my passion for
unmotored aviation, so mayby I don`t need that extra axis, but I love it, and will never, ever again part with it.
I don`t compete (yet), but I fly alot, and i want my plane to look good in the air. Nice coordinated turns makes it look good, and that makes me happy.
Rudder makes me happy.
Bad scientist is offline Find More Posts by Bad scientist
Wanted Bagged, Rudderless DLG Tailset thumbhead Aircraft - Sailplanes (FS/W) 4 Aug 22, 2011 08:22 PM
Sold Twister-1 DLG (ARF + Ballast + Swindell Rudderless) Kai@UCSB Aircraft - Sailplanes (FS/W) 4 Jul 25, 2011 07:34 PM
Discussion Cancer Surges In Body Scanner Operators; TSA Launches Cover-Up P-51C Life, The Universe, and Politics 10 Jun 29, 2011 10:02 AM
Help! DLG flies parallel to ground on hard launches?! apex Hand Launch 34 Jun 18, 2011 03:36 PM
