Old Dec 14, 2011, 10:10 PM
Sean Moloney is offline
Find More Posts by Sean Moloney
It flies!
Sean Moloney's Avatar
Sunshine Coast, Australia
Joined Jun 2007
First Part
Well, it's only half a part really, but a good milestone nevertheless. I was curious to see how the surface looked so used some scrap carbon to get a dark colour to showup the surface (without having to apply paint).
The layup was 25g glass, 200g carbon, 1.5mm balsa sanded down a bit, 100g glass. It was good practice to try making a sandwich (my first attempt) and it also serves to stiffen this half part so it keeps its shape. I even chucked in a spar cap made from 400g uni carbon. Stab is small enough that all materials used were scraps. Marbocote was used for release and it came out very easily.
The results are good! As usual the pics are very flattering. The surface is glossy and the carbon came up beautifully with no pinholes. As expected (and hoped) the surface smoothness on the part looks better than it does on the mould, but the slight waviness is definitely still there. It's hard to capture with the camera, but you can just see it in the last pic below - look in the white highlights left by the window. It's more obvious in the flesh (the workshop fluoro is ruthless in that regard), definitely not a big deal but I do want to make sure it doesn't happen on the wings. There are a few mistakes around the LE of this moulded part which should be easily fixed next time (I know what I did wrong, won't go into detail)
In the pics you can see I've scribed the elevator hingeline in to get an idea of how it will look. I'll probably move it 1 or 2mm forward on the final stabilisers.
Moulding this was quite fun, I plan to keep knocking out stabilisers 'till I'm really happy with the results and the learning curve starts to feel a little less steep.
Sean Moloney is offline Find More Posts by Sean Moloney
Old Dec 14, 2011, 10:40 PM
Ezza is offline
Find More Posts by Ezza
DS= -$ & :-)
Ezza's Avatar
Byron Bay, Australia
Joined Feb 2006
Wow, great result Sean. Congrats on this milestone. Very smart to keep practising and learning on the smaller parts before you go for the big bits. Off to a great start.
Eric
Ezza is offline Find More Posts by Ezza
Old Dec 14, 2011, 10:41 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
It looks very good Sean. Good news about the Marbocote.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Dec 14, 2011, 11:04 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Looks very nice! Great work!
wyowindworks is offline Find More Posts by wyowindworks
Old Dec 15, 2011, 02:54 AM
airtimeasto is online now
Find More Posts by airtimeasto
There is only DS
airtimeasto's Avatar
Australia, WA, Baldivis
Joined Aug 2008
Holy Crap that's awesome work Sean.
What's the wingspan of that part. Can we make a wing out of that .
airtimeasto is online now Find More Posts by airtimeasto
Old Dec 15, 2011, 03:22 AM
It flies!
Joined Jun 2007
Thanks Guys, pretty happy with results so far, just need to get that second mould half done to have an actual complete part...
Yeah the Marbocote's been working a treat when used in a mould. I suspect it doesn't like being applied over paint, definitely need to do tests before using. Very easy to use and less work than wax or PVA.
Hehe I've thought about that . It's only 500mm span so is pretty tiny, 8mm thick at the thickest point. Would make a pretty crazy little plank...
Old Dec 15, 2011, 03:31 AM
Joined Aug 2008
Sealer plus Marbocote?
Is that Marbocote a two part application like Frekote? By that I mean, sealer first coat then the actual Frekote (or Marbocote).
Old Dec 15, 2011, 03:45 AM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Very interesting Sean, thanks for sharing.
Stab planks are proven - Julian Bailey's original Stab & his larger Stab Extremes frontside & DS very well in a wide range of conditions & are huge fun. Eagerly awaiting a carbon version
dsman is offline Find More Posts by dsman
dsman is offline
dsman's Avatar
Joined Mar 2007
Stab Extreme
http://www.rcspeeds.com/aircraftdetails.aspx?AC=350
Old Dec 15, 2011, 03:50 AM
It flies!
Joined Jun 2007
Yep that's right, it's a sealer plus top coat. It's a bit pricey and has a limited shelf life, thankfully we were able to share the cost between a few people. You can buy 1L of the top coat for $60 but the sealer is the really expensive component (around $150 plus GST for a litre, which was the smallest amount available where I bought it).
I think Evan used the Marbocote top coat without the sealer on his Sniper wing, but not 100% sure on that (David, Jeff?).
Old Dec 15, 2011, 03:52 AM
Joined Aug 2008
[QUOTE=Sean Moloney;20143744].................. You can buy 1L of the top coat for $60 but the sealer is the really expensive component (around $150 for a litre, which was the smallest amount available where I bought it).
..........................QUOTE]
Ouch!
Old Dec 15, 2011, 03:56 AM
It flies!
Joined Jun 2007
Yeah I remember those two that's what got me thinking . Wasn't the smaller one made from a Blaster DLG tail? I actually have a Blaster tail sitting around doing nothing (rest of the Blaster is now deceased).
Old Dec 15, 2011, 05:22 AM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
Strewth. Incredible.
AvB is offline Find More Posts by AvB
Old Dec 15, 2011, 05:26 AM
OZPAF is offline
Find More Posts by OZPAF
Sydney
Joined Apr 2009
OZPAF is offline Find More Posts by OZPAF
Old Dec 15, 2011, 05:29 AM
OZPAF is offline
Sydney
Joined Apr 2009
Great stuff Sean - your careful approach is paying off. I'm sure the wing will be really good after seeing your stab.
You'll have to do a stab plank - 20" will definitely be a challenge even for Asto. His 30" Msw is too big anyway
Did you transfer the hinge line during the moulding btw or scribe it on afterwards?
John
Sold Two 6s turnigy lipos 3.3 and 3.0 postalflyer72 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 22, 2011 07:35 AM
