Old Nov 01, 2012, 02:48 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Originally Posted by sihinch View Post
Hey - I've just finished my build. When I first ran the stock fan up, the blades shattered. So I've just finished fitting a 4 blade 70mm Changesun fan, with a 2900kV motor:
https://www.toysonics.com/2836-2900k...-for-70mm.html
I'm a bit disappointed. Using 60A esc & 2200mAh 4S 40C lipo I'm only getting about 40A and 450watts. Is that enough to fly this plane (with no modifications, so stock AUW)?
Simon
You better upgrade it to get at least 650 watts, Tayphoon 2W20/HET-70mm fan will give you at least that, J.
jofro is offline Find More Posts by jofro
Old Nov 01, 2012, 02:51 AM
jofro is offline
Joined Jan 2010
This is all the footage my Darl managed out of 3 min flight in 30mph wind, landing was something on very narrow strip of sand as the tide was coming in. J.
P1050169 (0 min 15 sec)
Old Nov 01, 2012, 11:26 AM
sihinch is offline
Find More Posts by sihinch
Canada, ON, Toronto
Joined Jun 2007
OK, so I swapped to motor for another EDF motor that I had at home. I put in the HobbyKing 3200kV 2836 and got some better numbers:
585watts at 40A max.
I'll giv that a try before I order anything else. Thanks for your help & suggestions.
sihinch is offline Find More Posts by sihinch
Old Nov 02, 2012, 11:43 AM
rcgeorge29 is offline
Find More Posts by rcgeorge29
MAAC 79785
rcgeorge29's Avatar
Kimberley BC Canada
Joined Sep 2009
what kind of foam is everybody using to mod this kit? I just received mine the other day, and in good conscience I cant fly it in its current rendition! I'm gonna mod it to the GR7 as well I'm thinking. Anyway, the blue foam...is it the blue insulation foam from the home improvement stores? as well, what glue is compatible with it? Any help greatly appreciated!
Cheers
Rob
rcgeorge29 is offline Find More Posts by rcgeorge29
Old Nov 02, 2012, 04:29 PM
davylah is offline
Find More Posts by davylah
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Hi Rob, I think it's the same as what's used in building insulation. I just searched for 'blue foam on UK eBay and was able to order it already cut into 10mm slices. For fixing it to the existing foam I used 5 minute epoxy. Don't forget to post pictures as you go, I'd love to see another 'proper' Harrier flying
davylah is offline Find More Posts by davylah
Old Nov 03, 2012, 03:18 PM
MAAC 79785
rcgeorge29's Avatar
Kimberley BC Canada
Joined Sep 2009
thats what i thought, just wanted some confirmation...thanks Davy. I'll get on it in the next few days, I've got a 1/5 Beaufighter hogging all the building space currently.
cheers
Rob
Old Nov 17, 2012, 09:42 AM
stevo0476 is offline
Find More Posts by stevo0476
BelgiŽ, Vlaams Gewest, Brugge
Joined Sep 2011
George,
The brand name is styrofoam, it can be glued with PU glue (gorilla) , epoxy, or ordinary woodglue, you will have to check the foam of the Harrier too.
So this bird has been coming available at the NL based warehouse for around 70 Euro. I've been dragging myself away from the desk where my computer is for a couple of times now, it's the only way to prevent me pushing that "buy" button
Cheers
Steve
stevo0476 is offline Find More Posts by stevo0476
Old Dec 11, 2012, 02:42 AM
pattern14 is offline
Find More Posts by pattern14
Closed Account
Joined Feb 2009
It is a great model, but just like any foamy it needs few little mods. On other hand what do you expect for $45- I think that's what I have seen it selling for on HK site. Last two years I have done well over 100 flights with mine and there is still not one dint on it, Joe.
Crashed mine once after about 15 flights, and not all that hard either. Totalled the nose, tore a huge chunk out of the underside and generally looked prettty sad I found it rather fragile, but no worse than my He 162 Starmax. Built a new nose out of coreflute to keep her flying, and plan to make a "proper one" at some stage. I covered it in clear packing tape, which helped totally, and put bi directional tape on the belly. So far so good....
pattern14 is offline Find More Posts by pattern14
Old Dec 29, 2012, 05:43 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
I'm looking for one if anyone has one laying around. I know HK has them but hoping to avoid high shipping $$.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jan 24, 2013, 11:56 PM
jofro is offline
Joined Jan 2010
Latest footage flying my "Harrier" today while using new movie director helm/cam, vid. soon, J.
Old Jan 26, 2013, 05:36 PM
jofro is offline
Joined Jan 2010
The latest footage using my "Movie director", enjoy it, Joe.
P1050417 (3 min 4 sec)
Old Feb 24, 2013, 03:00 PM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
I was so impressed with davelah's harrier i have started one myself.
6s setup changesun fan pulls 65 amps 1570 watts 1.3 kilos of thrust
scunna is offline Find More Posts by scunna
Old Feb 24, 2013, 03:15 PM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
Good work sir!
I look forward to seeing your progress
Old Feb 24, 2013, 03:20 PM
scunna is offline
scunna
scunna's Avatar
Joined May 2007
Trying to copy av-8 harrier 11. ran it up today got 1570 watts it sounds awesome. im probably looking at 3 3.5 pounds auw battery is going under wing above fan.. How much thrust did you have davylah ?
Old Feb 24, 2013, 03:57 PM
davylah is offline
Ex RAF Techie
davylah's Avatar
North East England
Joined Jun 2010
I'd say yours will be a good bit more powerful than mine.
Mine was my first edf, so I didn't have any specialist equipment for measuring current draw, power etc. I didn't even measure the thrust, I just used the motor and fan that Hobbyking suggested, and hoped that it would fly!!!
Discussion My 1/6th scale Harrier Eddy VTOLs 51 Jan 03, 2015 04:45 PM
Discussion Erics Harrier RCvertt VTOLs 5 Sep 11, 2011 04:30 AM
Discussion EDF Harrier test flight DominicM Electric Ducted Fan Jet Talk 17 Sep 10, 2011 09:01 AM
Discussion AV8 Harrier saintpr25 EJF/EPP 0 Mar 17, 2011 11:07 PM
Discussion rolling harrier dialed kygreen229 3D Flying 8 Mar 15, 2011 11:02 PM
