Old Oct 02, 2011, 10:56 AM
Joined Aug 2005
Originally Posted by Biggles51 View Post
Thanksfor that DT56..
Had pretty much decided to go with the seperate elevators and will try the COG at 63mm.
Will report later.
Regards
You may want to consider changing just the control system at first.
Good Luck!
DT56 is offline Find More Posts by DT56
Old Oct 02, 2011, 11:19 PM
Who said Kiwi's can't fly!
Grunta5's Avatar
Hawkes Bay , New Zealand
Joined Feb 2008
Its a little bit like my Little Bit ( no joke or pun intended, I really did build a Little Bit.. well two actually) Its a tailless electric plane and it flew great , way over powered with the motor I used and upon launch it would drop and torque to the left. The C.G was critical and close to the L.E ( 28mm from it) , certainly different to fly than a normal plane and would land rather fast too ( didn't like to be slowed down that much , but then it did have a small wing area) , I wonder if this has the same traits..? certainly a nice looking sailplane and something I may look at having a go at scratch building along the lines of..
Grant.
Grunta5 is offline Find More Posts by Grunta5
Old Oct 08, 2011, 12:37 PM
Gold Coast Australia
Joined Sep 2010
Kia ora Grant
I am an ex pac Kiwi living in Oz for 24 years.
Sitting in Wellington airport right now after going to Whanganui for friends funeral
Motto, fly every day .....
Project Pioneer is on hold for a bit but will revisit later and post.
Feel like the Walsh Bros with this one.,be nice if the Jap guy flying on the video would jump on the thread.
Cheers
Tony
Biggles51 is offline Find More Posts by Biggles51
Old Oct 27, 2011, 05:08 AM
Nando
Nando.Edge's Avatar
Australia, NT, Ghan
Joined Apr 2011
Kia ora Grant
Cheers
Tony
You must contact the supplier and ask them what's up, why the beautiful model flies so tough
Nando.Edge is offline Find More Posts by Nando.Edge
Old Nov 17, 2011, 09:18 AM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
I just received one of these for a test and the cg I got is 40+2 and the elevators are in board and the ailerons are outside the wing. And heres a pic of other cg they gave me
Mikemynameis is offline Find More Posts by Mikemynameis
Old Nov 17, 2011, 03:27 PM
American since 1947
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
YEP ... I'm monitoring BOTH of the Pioneer threads :-)
Way late but ...
These are Flying Wing Airfoils I PRESUME and as such need a CG at ~20-25% not the usual 30%
I have used the Marske Root airfoil section that I got FROM JIM MARSKE
and found it to be a very nice flying section.
I've been meaning to build a PioneerIII for some time now but just too lazy.
I have a 3D model that I tried to mill but I used lousy cheap foam and it cam out a mess.
If these folks are NOT offering a reasonable quality model I may have to revisit my previous efforts.
I was expecting 2.6M Fox like quality, which also needed some rework but, still flys nicely.
I would like to see the KIT offered for FULL assy from parts.
THAT WAY we could inspect the sub assys and re glue if necessary and
put my own personal Touches into it.
L8r
Bob
birdofplay is offline Find More Posts by birdofplay
Old Nov 17, 2011, 08:26 PM
Joined Jan 2007
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 17, 2011, 10:58 PM
American since 1947
birdofplay's Avatar
Joined Dec 2005
A much more exhaustive analysis than mine. Thank you, kevin.
Much needed here, me thinks.
The use of the Tip root swap for fsw on the widely used CG calc w was an eye opener.
How could I have missed that simple but elegant work around.
Overall I hope this model is a succes and indroduces more modelers to
Marski's designs and the years of eperience that they demonstrate in Jims work.
Old Nov 18, 2011, 12:36 AM
Joined Jan 2007
Old Nov 18, 2011, 11:07 AM
San Pedro,Ca
Joined Sep 2004
and dont forget to put the reflex in the elevator before flight
Old Nov 19, 2011, 11:23 AM
American since 1947
birdofplay's Avatar
Joined Dec 2005
My reply from the Mfgr can be read at ...
http://www.rcgroups.com/forums/showt...1540863&page=2
Bob
Old Nov 20, 2011, 02:10 PM
Joined Sep 2010
Hi Guys,
I sent you a private message Twiz. Sorry been busy with other projects.
Had another go with the inboard elevator set up and trying a different COG.
Got close to flying...but wing tip stalled on me. More damage and got really peeved and put it in the loft for now.
I also got an email from RC Sun with COG point drawing.
Read with interest all the new posts on this thread.
Good luck with maiden Twiz will be waiting for your post with much interest and many many questions.
Cheers
Tony
Old Nov 23, 2011, 02:17 PM
San Pedro,Ca
Joined Sep 2004
Hi Guys,
Cheers
Tony
Well I found the cg to be wrong and someone said something like 60mm and thats sounding about right. It was way tail heavy so as I moved the battery forward it got better and better so Friday going to do some more flying and see where the cg ends up. I also found the power setting at launch is critical because to little and whats to nose drive and to much goes like a bat out of hell and is all over the place.
Old Nov 23, 2011, 02:30 PM
American since 1947
birdofplay's Avatar
Joined Dec 2005
Suprising report.
I would expect it to glide well from even just a toss.
After all it is a mostly foam construction like the 2.3 Fox.
Guess we'll wain n see after teh CG gets all sorted out.
Old Nov 23, 2011, 03:57 PM
San Pedro,Ca
Joined Sep 2004
Originally Posted by birdofplay View Post
Suprising report.
Well I made a mistake with the cg and measured wrong it not 60mm nor is it 40mm what they say. Since today flight I was getting closer to the perfect cg and right know I moved the battery forward just alittle and found from the pic they sent me was 10mm behind wheel and when I drew the line down to the wing it was showing 35mm but will do a flight this Friday and see what happens.
New Product Kit for Marske Pioneer 3 bie Scale Sailplanes 10 Nov 26, 2011 11:00 AM
Discussion Sloping in the Massachusetts Pioneer Valley smrouss Slope 0 Mar 28, 2011 12:56 PM
Sold Sirius Satellite for Pioneer Car Audio rz22g Non R/C Items (FS/W) 2 Mar 25, 2011 09:02 AM
