Old Sep 20, 2011, 05:09 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Thanks for the video BarnOwl!!!
DT56 is offline Find More Posts by DT56
Old Sep 21, 2011, 10:05 PM
Biggles51 is offline
Find More Posts by Biggles51
Gold Coast Australia
Joined Sep 2010
Caution
Just to let you know that the vendor for this model, RC Sun is not responding to my emails.
Cant ascertain if my kit has even been sent yet.
Have posted on the Vendors forum.
Regards
Tony
Biggles51 is offline Find More Posts by Biggles51
Old Sep 22, 2011, 03:38 PM
Joined Sep 2010
Good news !!!
Its on its way, vendor finally responded and I have tracked to Australia.
They actually sent it when they said they would but some glitch with emails.
Should have early next week and will post box opening.
Cheers
Tony
Old Sep 22, 2011, 04:08 PM
BarnOwl is offline
Find More Posts by BarnOwl
Heli's and gliders, what else?
BarnOwl's Avatar
Nederland, GE, Slijk-Ewijk
Joined Apr 2006
Ok, great! Keep us informed...........
BarnOwl is offline Find More Posts by BarnOwl
Old Sep 22, 2011, 04:37 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Awesome!! Glad to hear the good news........looking forward to your pics upon receipt!
Doubletap is offline Find More Posts by Doubletap
Old Sep 26, 2011, 02:51 AM
Joined Sep 2010
Arrival.
Got the kit today.
Double boxed and well packed. First impressions are very good. Some nice design features. The body is real short !! Some strakes on the wing, flaps, and central wheel. Came with a lot of hardware and even prop hub and blades. Wing has full length decent size carbon fibre spars and joiner is a sleeve over system. Looks real strong.
Its EPO but not too brittle ( some of the foam pattern visible in places.)
I reckon mine is an ex demo model, its obviously been "dry" fitted together and then repacked. Some minor rubs and flaws but I will live with it.
Instructions are for a ARF but at least COG is there and also 5% up airleron trim recommended.. Cant pick up manufacturer, its a no brand sheet.
Initial thoughts were to fit a 35/42 Turnigy but quick weigh up has me thinking something lighter. Instructions list a 36/ 05 ? outrunner . Have a E flite 480 that may be the go and will match up to 11 x 7 blades supplied.
I will do the AUW and make my mind up then.
Will post pics tomorrow
Cheers
Tony
Old Sep 26, 2011, 05:23 PM
Doubletap's Avatar
Joined Jul 2005
Sigh of relief!
Very good to hear that you actually received the model today Tony!!
Can't wait to see the pics.
Old Sep 27, 2011, 03:05 PM
Joined Sep 2010
Build Pics
Got some time last night to start putting it together.
AUW with proposed Park 480 motor and 2200 3 cells is 1.4kg, so going with that light set up.
Also with battery in likely looking battery tray back in the cockpit area over the wing spar, first COG check is all good.
All pretty straight forward, the aleron and flaps are set up for top of wing
installation. Not my preference but if using on a slope or landing area is rough
will protect them. Using some mini metal gear coronas. Had to do a lttle foam surgery to get them to fit but nothing untoward.
Pics attached.
Need to get my elevon throws equalised and one wing is not sitting fully in but should get sorted and have a maiden on the weekend.
Cheers
Tony
Old Sep 27, 2011, 07:02 PM
DT56 is offline
Joined Aug 2005
Thanks for the photos! Rather surprised to see the wood internal structure.
Look forward to the flight report!!!
Old Sep 28, 2011, 10:12 PM
Joined Sep 2010
Maiden Flight - (not)
Update for those following this thread.
Why was I the guinea pig !!!!!
Fixed the wing insert problem by cutting 56mm off the joinning spar, it was too long.
Had a lull this morning in what has been a pretty windy week and went for a maiden.
Flew out nice and stable but as soon as I put some throttle in to climb out it duck dived staight in. Brought back into the carpark for the air crash investigation committee. Front cowl always looked really fragile and this was
a mess, broken propellor and motor mount out. Couple of internal formers broken and a aleron hinge torn. All repairable but why....
It looked like a classic case of reversed eleators but this was checked out before and after and all going right way. Too sudden for even extreme nose heavy COG but second opinion on COG rules this out as well.
Had a closer look at engine mount...and another look....not much in the way of evidence of glueing , looks like it was a Friday job and they had used up the glue allowance on Thursday. Best assesment is that when I gave it full throttle the torque pulled the engine mount out and down.
Kicking myself that I didnt do the normal CA run around over all the joints that I do with my aerobatic stuff.It had looked like a good well built
ply inner cage before I joined the foam fuselage sides to it.
Summary so far
1. Check length of joinng spar
2. Go over engine mount frame and reinforce and CA joins
RC Sun if you are following this thread please note.
and it would be nice if you could send me another cowl.
Will report further on take 2.
Cheers
Tony
Old Sep 28, 2011, 10:39 PM
Doubletap's Avatar
Joined Jul 2005
Aw hell......poor workmanship strikes again!
sorry Tony, what dumb luck! to get one that was assembled by the new guy at the factory, using not enough adhesive for the firewall
Old Sep 29, 2011, 02:07 AM
BarnOwl is offline
BarnOwl's Avatar
Joined Apr 2006
Wow, that's a bummer.......
Did you write them an e-mail? I think they should get you a new and proper one.
Otherwise this thread is not a very good advertisement for their Pioneer glider, is it?
Old Oct 01, 2011, 10:18 PM
Joined Sep 2010
Take 2 - Worse
Fixed the front end and time for remaiden. Decision made to hand launch without power
for second test to take thrust line out of play.
Same disastor, pitched straight in, no elevator authority at all.
Apologies to the glue guy it must not have been the engine mount pulling out,
it must be a COG issue. Sheet gives COG at 40mm +2mm from wing edge. This is at front edge of spar and lots of second opinions from other experienced members at our field agrees that it looks OK......
but lots of head scatching... the normal 25 - 30% of wing chord must not apply. Taking COG back to say 65 mm looks like going the wrong way. I am st...ed.
Went to COG calculations on flying wings forum. Helps but calculations are tricky with tailess glider with slight forward swept wing throw
Can anybody help, any ideas..
Wing root is 260mm
Wing tip is 80mm
Forward rake is approx 50mm
Also some discussions on using the "flaps" as the elevators and the alerons without the elevon mixing.
We wont give up ...yet
Regards
Biggles
Old Oct 01, 2011, 11:46 PM
DT56 is offline
Joined Aug 2005
Originally Posted by Biggles51 View Post
Take 2 - Worse
Wing root is 260mm
Wing tip is 80mm
Regards
Biggles
Are you aware that the full scale Pioneer uses separate elevator and aileron controls, not elevons? The inboard control surfaces are elevators and the outboard surfaces ailerons with no mixing required as in elevons.
http://continuo.com/marske/pioneer/h...cont/wing2.htm
As far as CG, this calculator has been used for forward swept wings by swapping the root and tip chords.
http://fwcg.3dzone.dk/?wing_span=200...ow_mac_lines=0
Old Oct 02, 2011, 05:47 AM
Joined Sep 2010
Thanksfor that DT56..
Had pretty much decided to go with the seperate elevators and will try the COG at 63mm.
Will report later.
Regards
New Product Kit for Marske Pioneer 3 bie Scale Sailplanes 10 Nov 26, 2011 11:00 AM
Discussion Sloping in the Massachusetts Pioneer Valley smrouss Slope 0 Mar 28, 2011 12:56 PM
Sold Sirius Satellite for Pioneer Car Audio rz22g Non R/C Items (FS/W) 2 Mar 25, 2011 09:02 AM
