Old Sep 13, 2011, 10:39 PM
justin144 is offline
Find More Posts by justin144
justin144's Avatar
Joined Sep 2011
Help!
4-channel receiver has red blinking LED and won't respond
I'm a total noob here. I need some help with my new plane, and can't find help in any online manuals or anywhere else, so I'm depending on you guys.
I bought a nexstar mini EP RTF. It came with a Tactic 2.4 GHz Radio (TTX440) and has a Tactic tr.424 4-channel receiver in the plane. I flew it for a very short time yesterday and I was working on it today and noticed that one of the connectors on the receiver came undone. (I probably yanked it off somehow when I was working on it).
I connected it back to the receiver and went to fly the plane today but it wouldn't turn on. I unplugged that same one, turned on the controller and the plane went crazy and the prop started spinning even with the controller off. I disconnected all the connectors to the receiver. The prop was still spinning full speed, so I disconnected the battery.
Now I've connected all the wires back to the receiver and when I turn on the controller, the red LED on the receiver blinks repeatedly and the rudder moved with the flashes of the LED. The plane is irresponsive. I don't think the radio and receiver became un-binded.. Can someone help?
justin144 is offline Find More Posts by justin144
Old Sep 14, 2011, 01:40 AM
justin144's Avatar
Joined Sep 2011
could it be because I disconnected the battery when the prop was still spinning?
Old Sep 14, 2011, 03:32 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Perhaps (I once blew up a boat controller by unplugging the battery while the motor was going).
However you may just have something plugged in wrong. If you can post a picture of the receiver and wiring it might help us to diagnose the problem.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 14, 2011, 03:56 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
You should never have the power on in the model when the "controller" (transmitter) is switched off, as it can result in all sorts of nasty things happening, including the motor going uncontrolled.
Anyway, as Bruce has said, show us a picture of your setup if you can. Without knowing which lead was disconnected, and so on, it's difficult to say what's happened.
Also, check that your transmitter and receiver batteries are fully charged. Unresponsive radio, with flashing light and jumpy servo(s) sometimes simply means it's not getting any signal from the transmitter -- either it's unbound, or the transmitter's not transmitting for some reason.
abenn is offline Find More Posts by abenn
Old Sep 14, 2011, 11:44 AM
justin144's Avatar
Joined Sep 2011
Did not know this. Thanks.
Anyways I figured out the problem just like 5 minutes ago.
Apparently, the leads can be plugged into the receiver backwards.. Retarded on my part, I know, but I thought I tried plugging it in both ways already. Anyways i turned the lead around and everything is working now. Thanks for the help guys. I'm sure I will be on this forum looking for help quite often lol.
Old Sep 14, 2011, 02:32 PM
abenn is offline
Joined Jul 2004
That's good news. It's easy to plug "universal" or "JR" plugs in the wrong way. No harm comes of it, but it's difficult to spot sometimes, especially when the leads are coloured red, orange, and brown (3 shades of brown?), as they often are, instead of red, white, and black.
Help! Hobby Zone Champ won't bind or respond to transmitter Paul Parkflyers 2 Sep 21, 2011 01:31 PM
Discussion Making a 3 channel respond like a 4 channel immelguy Beginner Training Area (Aircraft-Electric) 18 Jun 10, 2011 07:17 AM
Discussion DSM2 6ch OrangeRX won't bind--won't even flash the LED horseflesh Radios 12 Jun 09, 2011 12:06 AM
Discussion HobbyPartz won't respond! djroberts HobbyPartz.com 31 May 23, 2011 12:38 PM
Question Blinking Red LED on Rx - Low Rx Battery? FlyingW Xtreme Power Systems 3 Aug 23, 2007 08:19 AM
