Old Sep 13, 2011, 09:05 AM
Joined Jun 2011
Servo Arms & Horns - Big selection!
If you need a servo arm, look no further. ServoCity has a great selection of arms and horns at prices that can't be beat!
SUB-MICRO ARMS
Specifically designed to fit the HS-50 and HS-55, these horns will also fit a variety of other name-brand sub-micro servos such as Futaba, Cirrus and GWS.
Lite Double Horn - $0.95
Micro X-Horn - $0.95
2.00” Double Horn - $0.95
.935” Horn Pack - $5.99
MICRO ARMS
Specifically designed to fit the HS-125, HS-5125MG, HS-56HB, HS-65HB and HS-65MG.
Hitec OEM Horn Set - $2.99
MINI ARMS
These mini horns have the standard 24 tooth Hitec spline so they will fit all standard spline Hitec servos.
Mini Wheel Horn - $0.95
Mini X-Horn - $0.95
Mini Wide X-Horn - $0.95
STANDARD ARMS
These standard horns have the standard 24 tooth Hitec spline so they will fit all standard spline Hitec servos.
Adjustable Arm - $0.95
Small X-Horn - $0.95 SALE $0.49!!!
Small Wheel Horn - $0.95 SALE $0.49!!!
Large Wheel Horn - $0.95
HEAVY DUTY ARMS
Hitec Heavy Duty Set - $8.95
Futaba Heavy Duty Set - $8.95
J/R Heavy Duty Set - $8.95
SUPER-DUTY ARMS
Hitec Super Duty Set - $10.95
Futaba Super Duty Set - $10.95
J/R Super Duty Set - $10.95
ALUMINUM HORNS
Single Arm (Hitec) - $6.99
Double Arm (Hitec) - $6.99
Heavy-Duty Hub Horn (Hitec or Futaba) - $9.99
LONG SAIL ARMS
Standard Spline (Hitec) - $5.99
Large Spline (Hitec) - $5.99
Standard Spline
(Futaba) - $7.99
HS805/HS815BB ARMS
These horns are designed to fit the HS-805BB and HS-815BB servos.
HS-805/815 Wheel Horn - $0.95 SALE $0.49!!!
HS-805/815 X-Horn - $0.95 SALE $0.49!!!
PULLEY WHEELS
Hitec Pulley Wheel - $6.99
Futaba Pulley Wheel - $7.99
AND MUCH MORE!
To view our entire selection of servo arms and horns visit: http://www.servocity.com/html/servo_arms___horns.html
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
Discussion Big Lama: Longer Servo Arms + shorter and lighter flybar = Flying Faster Owner1 Coaxial Helicopters 5 Jul 21, 2011 02:13 PM
Wanted Cirrus CS 30BB servo horns/arms SpiritQuest Aircraft - General - Radio Equipment (FS/W) 3 Dec 13, 2006 05:06 AM
Wanted Cirrus CS 30BB servo horns/arms SpiritQuest Aircraft - General - Radio Equipment (FS/W) 0 Oct 28, 2005 04:09 AM
Max throw - control horns and servo arms Valid8r Beginner Training Area (Aircraft-Electric) 6 Nov 02, 2004 10:48 PM
