Old Feb 06, 2013, 06:49 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Originally Posted by Downwind3Zero View Post
Do you know what the holdup is Mike?
Chris
Parts suppliers? Rainer can't build fans if the supply chain breaks down....
Mike Warren is offline Find More Posts by Mike Warren
Old Feb 07, 2013, 02:26 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
So is the tamjet shroud and tailcone worth the expense? I know cooler running temps are better all together, and it makes a nice little pod to hold the esc (if a 120hv ice2 fits), but other than that, whats the benefit of it (other than draining my wallet another $150 for two)?
invertmast is offline Find More Posts by invertmast
Old Feb 07, 2013, 03:25 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
You are better off with the ESC heatsink in the inlet duct in front of the fan, it stays cooler and the wire lengths balance out much better, sticking it behind a hot motor with very short leads forces you to extend batt leads more than is necessary.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Feb 07, 2013, 03:47 PM
Joined Mar 2004
There is no inlet duct infront of the fan... And the batteries are literally located RIGHT beside the fans
Old Feb 07, 2013, 04:21 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I always talk to my models, they tell me where the components need to go to achieve cg without adding weight. that said I prefer esc in the tailcone for superior cooling, tams upgrade also adds a heatsink to the motor which improves motor cooling also, airflow/airspeed is greater behind the fan so better cooling is realized. esc's can fail and do fail, containing it in a carbon fiber tube with 200mph airflow around it can contain an esc fire and most of the time save the model from catching fire.
so open ducting? that would pretty much settle it for me they would be in the tailcone and would move the batts foward a little bit if needed away from the fans
jcdfrd is offline Find More Posts by jcdfrd
Old Feb 07, 2013, 05:05 PM
Joined Mar 2004
I guess you could consider it opening ducting... The inlet ring is modified and then epoxied to the inlet:
Battery placement: the fans are only about 3 to 4" on either side of the edges of the batteries, and by the time you do a series harness, there is excess wire to work with.
Already had one esc fire in this model on a 6s setup, not really wanting to repeat that:
Old Feb 07, 2013, 05:22 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
lol!!! thats about as open as it gets........dude that airframe is yelling at me "PUT THE ESC"S IN THE TAILCONE" hahaha thats what I would do for sure
Old Feb 07, 2013, 05:56 PM
Joined Mar 2004
Alrighty... 100% fsa is no problem on this model
Old Feb 07, 2013, 09:01 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
I have heard from many not to put the ESC in the tail cone because of the hot motor....
When I read my temps the ESC stays much cooler in the tail cone. I've done it both ways and have success with each, but I like the tail cone better, never thought of the fire issue that another plus in my book.
Look to BVM and Tam Jets and see where the ESC is.... tailcone
these guys lay down flight after flight so not sure how that could be a bad place
I'll have super long leads in my F-18 but feel the benefits out weigh the long leads.. I will have a bank of caps for each fan and will check my ripple
Ron101 is offline Find More Posts by Ron101
Old Feb 07, 2013, 09:02 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
+1 Tailcone!
Jetnfast is offline Find More Posts by Jetnfast
Old Feb 07, 2013, 09:12 PM
Joined Mar 2004
OH man ron.. now you opened another can of worms... Caps... wonder if they are really necessary on 12" of battery leads total...at most..
Old Feb 08, 2013, 02:42 AM
EJETS-II is offline
Find More Posts by EJETS-II
TeamSiam
Graz
Joined May 2007
Inlet rings and stuff
Hi caps,
Mike already posted it. I run out of carbon tubes for the shroud, but they are already here in Graz at FEDEX.
So i will get them today. Then the production can start again.
Inlet rings. Yes, the are made specailly for the JF-90 and JF-90V2 (same shroud)
So i*ll send a bunch of them to Mike today. Rest of the fans will follow next week, have to canfugurate them.
Sorry for the wait, but if the suppliers are lazy, i'm in the same troubles as all other little companys like HK
Best greez from Austria,
Rainer
EJETS-II is offline Find More Posts by EJETS-II
Old Feb 08, 2013, 03:58 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Funny!
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Feb 08, 2013, 08:07 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
This is happening world wide all suppliers and manufacturers are running lean inventory and most build on demand after the order is placed.
BadLemon is offline Find More Posts by BadLemon
Old Feb 08, 2013, 10:05 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
the caps on the esc are designed to handle 12in of wire between batt and esc, 6in on the batt and 6in esc leads. you will be fine, no caps needed for your install
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 01:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 10:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 12:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 08:12 AM
