Old Jan 02, 2013, 04:08 AM
Downwind3Zero is online now
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Good one!
Downwind3Zero is online now Find More Posts by Downwind3Zero
Old Jan 02, 2013, 04:55 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
You could also use L or T shaped alloy extrusion and silicon it to the sides of the fan, makes a nice isolated mount too, like I do on the alloy housings.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 02, 2013, 05:04 AM
buckaroo is offline
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
Interesting Mark, Just silicone is enough to hold the extrusion's to the housing? Even for the 127mm big boys? Does it help that much to dampen out vibrations?
Dean
buckaroo is offline Find More Posts by buckaroo
Old Jan 02, 2013, 05:08 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
I use dow corning MIL3145, its about the highest grade I have found, huge shear strength and so far no returns or issues from the guys running the big fans. It certainly damps the fans better than a solid bonded bracket, but servo grommets are also great, you could use both
Old Jan 02, 2013, 06:04 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Originally Posted by pdawg View Post
Is there a U.S. distributor for this fan? I'd like to use it in my soon to be completed y/a A4
nice skyhawk i flew one of these years ago on a dynamax
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jan 02, 2013, 06:34 AM
buckaroo is offline
Banzai Institute
buckaroo's Avatar
Joined Oct 2005
Wow Bob you squeezed a Dynamax in there? Correct me if I am wrong as I still have this A4 fuse in glass hanging up in the rafters. Mine was originally one of Bob Violets first DF kits. It was designed around the "Scuzzi?" fan unit with a K&B 7.5 for power. I think Larry Wolf ended up with the rights to both and the fan than became the Turbax. As far as the airframe goes I have herd rumors that the Yellow version ended up being almost the exact same thing.
My buddy built and flew this plane way back when. It was very marginal with the setup but was never the less the FIRST successful ducted fan kit to hit the market. It used a cheater hole that was molded into the bottom of the wing. Later improvements included internal ducting and the elimination of the cheater hole but it still was marginal with the 7.5.
Seeing how much trouble my buddy was having with the kit I never built it. I did look at it a while ago and seen you could squeeze a Dynamax in there but boy was it tight. Bob did you use the cheater hole on yours? Cool stuff. Boy those were the days. What a leap from than till now.
Dean
Old Jan 02, 2013, 07:41 AM
Joined Dec 2000
The yellow a4 used a dynamax dont recall it having a cheater hole.
Old Jan 02, 2013, 01:32 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Thank you Robert!
Mine was also set up for a dynamax but with the current technologies a 90mm seems much more appropriate. Look at how much more space there will be with the 90mm.
pdawg is online now Find More Posts by pdawg
Old Jan 02, 2013, 01:41 PM
Tempest is offline
Find More Posts by Tempest
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
If you have any interest in removing the existing ducts, Tam makes a nice set of 90mm intake ducts for the Yellow A-4.
Paul
Tempest is offline Find More Posts by Tempest
Old Feb 05, 2013, 09:20 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Anyone stateside have a pair of inlet rings for the jetfan 90's they be willing to part with? I have some on order that i can replace yours with when they arrive if you dont mind helping a guy out
invertmast is offline Find More Posts by invertmast
Old Feb 05, 2013, 09:36 PM
Tempest is offline
Tempest's Avatar
Joined Nov 2000
Thomas, my Jetfan 90's did not come with inlet rings. I do however, have more Midifan inlet rings, if those would help.
Let me know.
Paul
Old Feb 05, 2013, 09:44 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Thomas,
My order of 90mm is delayed so I'm asking Rainer to ship out the inlet rings in a separate shipment ASAP. I hope I might get them in within the next week to 10 days?
-Mike
www.performance-edf.biz
Mike Warren is offline Find More Posts by Mike Warren
Old Feb 06, 2013, 06:22 AM
Joined Mar 2004
Paul,
Do those fit the jetfan shroud?
Mike,
That sounds great! It may be about 10 days before i have time to install everything into the horton anyways, so that may work out just right c
Old Feb 06, 2013, 09:20 AM
Joined Dec 2000
Originally Posted by Mike Warren View Post
Thomas,
-Mike
Mike I would like one of the inlet rings please.
bob
Old Feb 06, 2013, 05:19 PM
NY, Rochester
Joined Oct 2003
Do you know what the holdup is Mike?
Chris
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 01:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 10:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 12:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 08:12 AM
