Old Dec 26, 2012, 02:11 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Originally Posted by xcz5785 View Post
Oh! I just assumed the motor and rotor needed to be balanced together. The motor is HET and it says dynamically balanced. I did not know the Jet fan came balanced. So once assemed it should be ready to go, huh?
"If" ........the big "if"...... You get your fan assembled and running and THEN find that there is a bit of vibration or resonance you can try turning the spinner in increments to fine tune to your satisfaction.
Basically just follow the directions that come with the fan......
Mike Warren is offline Find More Posts by Mike Warren
Old Dec 26, 2012, 02:21 PM
xcz5785 is offline
Find More Posts by xcz5785
xcz5785's Avatar
United States, IL, Palatine
Joined Jul 2011
Thanks! Yes, I'm an EDF nube!
xcz5785 is offline Find More Posts by xcz5785
Old Dec 26, 2012, 05:02 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Originally Posted by Robert Belluomini View Post
Another Jhh F4 Phil?
I have given thought to building one with the jf80 on 8S x2 of course!
No, Bob. Its a complete scratch build
I think the JHH F-4 wud be easier to do with a single larger fan this time, with current level of fan/pack development. A knife-little 5incher shud even be doable.
Cheers,
Phil
PhilLin is offline Find More Posts by PhilLin
Old Dec 26, 2012, 09:41 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Yes but the sound of two fans in harmony gives me chills everytime.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Dec 26, 2012, 10:04 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Hi Bob
So what do you think see below
thanks
Originally Posted by BadLemon View Post
It started out pretty snug but after several times on and off it slips off easy now. Do you think I oblong the adapter? I need to send Mike Warren an email and see if he has replacement adapters.
How well does the adapter fit the shaft? A lot of motors have undersize shafts.
What motor?
BadLemon is offline Find More Posts by BadLemon
Old Dec 26, 2012, 10:14 PM
Joined Dec 2000
I doubt you oblonged the adapter. You should be able to bring all three just into contact with the shaft check for run out and gradually tighten the set screws in a rotating pattern and check for run out.
Old Dec 26, 2012, 10:59 PM
BOHICA!
Joined Dec 2010
I have "undersize" adapters for the set screw style, just shoot me a PM or email with your address and I will send you new ones of both standard and undersize.
NOTE: Beware motor shafts with a factory cut "flat" for setscrew, some are so large that the adapter cannot properly center on the shaft. For the older set screw adapters I do not recommend a flat other than a very small hand ground one of approximately 1/16" width, just enough to meet one of the grub screws.
In any case, if you have a flat on the motor shaft, locate the flat (if any) and center then tighten a grub screw in that one first......
BTW: for those so inclined, the standard for 5mm shaft is nominally 4.975mm. The undersized is nominally 4.93mm for some of the less than standard motor shafts out there = "other than Neu or HET700-60 or 700-68"
The really optimum fit would be one where the adapter has to be heated in order to slip on the shaft then shrink to fit upon cooling. No chance for slop or having to fiddle with set screw tension other than tighten them up.
-Mike
Old Dec 28, 2012, 06:43 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I got the mounting tabs in the mail today, thanks again Mike.
davecrash is offline Find More Posts by davecrash
Old Dec 28, 2012, 06:47 PM
BOHICA!
Joined Dec 2010
My pleasure
Old Dec 30, 2012, 08:14 AM
buckaroo is offline
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
Very good info on the shaft sizes Mike. I wish all the EDF motors we buy would come without flats such as the HET's. Hopefully manufactures will catch on. Also I believe most problems with anyone's fans are usually centered around run-out on bad fitting set screw type adapters. I wish more manufacture's would use clamp type adapters. Mike do you recommend eliminating the flat with JB weld or such when using a clamp type adapter? Thanks in advance for your help.
Dean
buckaroo is offline Find More Posts by buckaroo
Old Dec 30, 2012, 08:27 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Hi Robert
I found the problem with my fan 80mm unit the motor shaft has .005 runout in it. The funny thing is the shaft is true from the motor bearing out about a 1/4" then is off from there. I bought the motor used so I guess I should of checked it. Lesson Learned. There is a machine shop where I work so I should be able to clamp the shaft in a jig to straighten it with a arbor press and a dial inductor.
thanks for the help
Old Dec 30, 2012, 08:46 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Is there a U.S. distributor for this fan? I'd like to use it in my soon to be completed y/a A4
pdawg is online now Find More Posts by pdawg
Old Dec 30, 2012, 08:54 PM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Yah...
Talk to Mike at Performance EDF.
PikeStaff is offline Find More Posts by PikeStaff
Old Dec 30, 2012, 09:00 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
+1
For Mike Warren that's him on post 1119 Here is his website
http://www.performance-edf.biz/jetfan80mm90mm.html
Old Jan 02, 2013, 02:58 AM
stewarti is offline
Find More Posts by stewarti
Joined Jun 2010
I slotted the holes in the fan mounting tabs and fitted some servo grommets to rubber mount the fan and it sounds even better than when it was hard mounted.
stewarti is offline Find More Posts by stewarti
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 01:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 10:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 12:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 08:12 AM
