Old Dec 25, 2012, 08:13 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
To me it looks like the stator is setting up high or it is installed backwards. I was looking through the attachment file and couldn't find one unit setup like that.
http://www.rcgroups.com/forums/thumb...=threadgallery
Originally Posted by Downwind3Zero View Post
Thanks BadLemon and Robert for the reference pics! Funny, I was also thinking the shroud may be too short, measured mine, 58mm. Will have to disassemble them to figure out whats wrong.
Just hard to believe they send off both fans assembled like this??? On a side note, there is no yellow eJets sticker on it either, not that I care though...
BadLemon is offline Find More Posts by BadLemon
Old Dec 25, 2012, 08:14 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Good question I got an 80mm jetfan I can't get to run smooth at all.
Originally Posted by xcz5785 View Post
Where is a good place to send the motor/fan to get it balanced? In the States preferably.
Old Dec 25, 2012, 08:16 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I just measured the fan the stator is flush with the back edge of the shroud. the front edge of the stator is 23-24 mm from the front edge. The rotor is 5mm back from the front edge
the shroud is 58 mm long
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Dec 25, 2012, 08:18 AM
Joined Dec 2000
What style rotor do you have? set screw or collet.
Old Dec 25, 2012, 08:20 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I got the older set screw style
Old Dec 25, 2012, 08:23 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
downwind3zero
I took a measurement of the depth of the stator on mine and its setting in at 21mm.
Old Dec 25, 2012, 08:25 AM
Joined Dec 2000
How well does the adapter fit the shaft? A lot of motors have undersize shafts.
What motor?
Old Dec 25, 2012, 08:39 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
It started out pretty snug but after several times on and off it slips off easy now. Do you think I oblong the adapter? I need to send Mike Warren an email and see if he has replacement adapters.
What motor?
Old Dec 25, 2012, 08:57 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Thanks for the measurements guys!
My stator is 17mm back from front of shroud and 8mm ahead of back of shroud.
Rainer needs to chime in here!
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Dec 25, 2012, 09:01 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I think that may be it, the back of my stator is flush with the back of the shroud. Here is a pic I found of what mine looks like.
Old Dec 25, 2012, 09:07 AM
NY, Rochester
Joined Oct 2003
Yeah, that's it!
I don't understand how he can assemble, balance and run it without noticing - worries me!
Old Dec 25, 2012, 09:14 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I'm sure Rainer will chime in he is always willing to help in anyway he can.
Old Dec 25, 2012, 09:17 AM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
So you bought 2 jetfan-90's are you putting them in a dual engine plane?
Old Dec 25, 2012, 09:39 AM
NY, Rochester
Joined Oct 2003
Ha! No they are going into separate planes, both HK Viper 90's
Old Dec 25, 2012, 09:45 AM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
I too hav received my 2 x JetFan 90 recently; but hav yet to assemble with a motor.
But I did place the rotor in the fan against the motor tube; and the rotor blades were within the shroud.
. Good Luck.
Merry X'mas to all.
Phil
PhilLin is offline Find More Posts by PhilLin
Last edited by PhilLin; Dec 25, 2012 at 03:36 PM. Reason: removedd incorrect suggestion. Sorry.
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 01:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 10:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 12:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 08:12 AM
