Old Oct 16, 2012, 02:51 AM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Originally Posted by AIR SALLY View Post
he had heat sinks on them but yeah good ques.i think the biggest thing we all learned on this was the thrust to weight ratio does'nt scale the same .i think he had more than half the weight in thrust,but still needs a bit morer i think if he had 30 lbs of thrust it would be better.
I agree Roger.
More thrust to push that big airframe thru tje air.
Isn't it 100% FSA on the intakes w/90mm currently?
What would it be with 110mm fans? I know you guys can whip up ducting pretty easily. Might be the better solution instead of pushing 90mm fans/motors to the limit. I'm afraid the scale factor would suffer somewhat with larger exhausts though...
If you want to continue to push the envelope though the Neu 1527/2D 1150kv gets my vote. I think at the sustained power it needs to fly you want as much motor mass as possible. It's rated at 2250W continuous and 4500W surge, and the price hurts. $324ea.
bmiller is offline Find More Posts by bmiller
Old Oct 16, 2012, 03:29 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
The Neu 1527/2D has the power, but Kv needs to be higher. If he went that way he should go with the 1527/1Y@ 1250Kv. The JetFan needs the rpm to extract its power. I had checked with both, Steve Neu and Rainer on the 1524/2D, the reasons were, on the charts no Voltage was listed and on Rainers side would the JetFan body hold the weight. Steve gave the go ahead for 12s
Weight was Ok with Rainer.---
Would like to say that the 1524 with 550gramm should also be OK. But in this case i would support within 3 thin rods between the housing and the motor.
Then i really have no issue with the weight.
at the 1527 i'm not sure if there might occure a problem after some hours of running.
BR ,Rainer
At 4" long and at 19.4 and 21.8 oz respectivly, thats alot to hang out there.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 16, 2012, 03:59 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Thet're both really heavy! If Steve and Rainer says ok on the /24 then so be it.
I am concerned about the continuous high watts the jet needs though...
Old Oct 16, 2012, 04:20 AM
Joined Dec 2008
I had only checked because I had given some thought on the 1524 myself. C/.N
said the Het 1200kv would be fine for my F-86 @ around 15lb. Not so sure any more. I am no motor guru, but the weight of the Het 1200Kv is only 330g/11.64oz, thats like the Neu 1515 series. The Het 700-83 is 460g/16,22oz, more like the Neu 1521's @16.93 oz I guess bigger is better!
Should note, that Rainer and Stuarti both used the Het 700-83-1445 in ther Sabres.
Old Oct 16, 2012, 07:27 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the trouble brent had was he could not back off the power ,he was having nose gear issues and trying to roll the plane inverted ect. so he could not back off .i dont think he had a chance to ck the motors ..they may still be ok ,or perhasp the heat after shut down got them . the batts were ejected fwd so there was no power after it came to a stop to see if the one motor would still run.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 16, 2012, 07:43 PM
Tempest is offline
Find More Posts by Tempest
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
I was assembling a Jetfan 90 this evening and had a question for those who have assembled these. When tightening the rotor to the adapter is there any trick you guys are using to hold the fan while tightening the bolt? The only way to hold the fan is to grab onto a couple of the blades while tightening the nut. I'm concerned this would stress the blades too much while tightening the bolt. Is there some other way to do this or should I not be concerned.
I must say this is a really nicely designed fan. Nice job Rainer!
Thanks!
Paul
Tempest is offline Find More Posts by Tempest
Old Oct 16, 2012, 08:55 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Yes the fan is very nice. It would be nice if there were two opposing holes on the hub then you could make a tool that had pins that would engage the holes so you could easily tighten and loosen the nut, Rainer are you reading this post?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Oct 16, 2012, 09:40 PM
Tempest is offline
Tempest's Avatar
Joined Nov 2000
Agreed Bob. That would be a nice solution.
Paul
Old Oct 17, 2012, 06:30 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
I havent had any trouble holding the rotor and tightening so far, the blades are incredibly strong, you would have to be trying for a cold weld to get enough force in there to break something.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Oct 17, 2012, 07:47 AM
latinajet is offline
Find More Posts by latinajet
latinajet's Avatar
Joined Feb 2011
Originally Posted by kimhey View Post
I recieved mine last week, and have test flown it in my HTG L-39. ARC 36.75.1 (1680kv) on 8s4000 reads 102 Amps peak. Tried the ARC 36.65.1 (2150kv?) and got 95 Amps (6s motor)
The "schwoosh" sound that this fan produces, is the best I have heard up untill now. And for the price, I think it is great value.
Kim
You sure the amps are not reversed? Usually going from a 6s to 8s setup the amps would be lower.
Any thrust figures?
The amps you stated with the arc motors are similar to a wemo fan using those motors?
About 6.5 lbs on wemo midi 6s
About 7.9 lbs on wemo midi 8s
latinajet is offline Find More Posts by latinajet
Old Oct 17, 2012, 08:39 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
The amps would increase going from a 6s to an 8s this is because the rpm of the edf unit is higher and the thrust is greater so the motor is going to need more amps. See the charts below and look at the Het 700-68-1680 on 6s and 8s cells.
BadLemon is offline Find More Posts by BadLemon
Old Oct 17, 2012, 12:45 PM
ravikoth is offline
Find More Posts by ravikoth
RAVI KOTHARI
Joined Nov 2005
Just got the v2 rotor, and installed it, just noticed that the Blade Tip to shroud clearance is the smallest i have ever seen in any Fan, what's the report on blade flex and therefore Blade scrape on the v2 rotor?
any input would be appreciated
ravikoth is offline Find More Posts by ravikoth
Old Oct 17, 2012, 03:56 PM
UNABLE2SURF is offline
Find More Posts by UNABLE2SURF
Jet's are cool!
UNABLE2SURF's Avatar
United States, KS, Wichita
Joined Nov 2011
I am running the fan on 8s with HET 1400kv and 1500kv and there is no blade scrape.YES I have 2 of these fans. There is only smooth quiet POWER!!!!!!!!!! Just make sure when you installed the motor it is evenly spaced in the mount.
UNABLE2SURF is offline Find More Posts by UNABLE2SURF
Old Oct 18, 2012, 04:03 AM
ravikoth is offline
RAVI KOTHARI
Joined Nov 2005
Thanks , will make sure on the mount..........
Old Oct 18, 2012, 04:06 AM
stewarti is offline
Find More Posts by stewarti
Joined Jun 2010
I'd be interested in a bigger fan as well Rainer, something suitable for 14 cells. I have a JAS 39 Grippen that would suit a bigger fan I just couldn't bring myself to buy a Schubie or turbine for it.
Good luck with your Mirage, extreme, mine was the best fun I'd had in ages, it really suits low level full throttle fly bys and the jetfan sounds great at 220 kph. It was going really well until last Friday when it suffered a bad case of "pilot induced oscillation" during a very low fly past and was totally destroyed. A waste of a day off work. Ah well.
Another order on its way Rainer....
stewarti is offline Find More Posts by stewarti
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 01:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 10:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 12:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 08:12 AM
