Old Sep 12, 2011, 10:55 AM
bsfixit is offline
Find More Posts by bsfixit
bsfixit's Avatar
Sarasota, FL
Joined May 2009
Help!
RV 900 mHz TX/RX, DX-201. PROBLEMS
Hey everyone,
I have not made my way to fvp, but just wanted to get some video from an Easystar. My setup is from RV. When I first got the equipment I hooked it up and everything was fine. I wanted to be a better flyer before I installed them on a plane. So the sat for a while in storage. Now I cannot get anything to work. All parts are 12v. I know the Tx can get warm (200mw) but the DX-201 also gets quite warm. I cannot get any video at all. I uses a 11.1 1000 mAh lipo with voltage regulated to 12v via demension engineering anyvolt micro. RCA and BNC connectors were removed and wired red to red yellow to yellow and black to black. I didn't hook up white for audio yet but I have a mic from RV. Any help as to what I have done wrong is greatly appreciated.
bsfixit is offline Find More Posts by bsfixit
Old Sep 12, 2011, 11:08 AM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
I wanted to add I am using a 12v @ 1amp wall transformer for the video RX power.. polarity was checked..
Old Sep 12, 2011, 11:21 AM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
Can you snap a few pictures of the wires connecting? Is the equipment showing any signs of getting power?
Tracks is offline Find More Posts by Tracks
Old Sep 12, 2011, 03:13 PM
bsfixit is offline
bsfixit's Avatar
Sarasota, FL
Joined May 2009
Yes, the RX powers up with its lights, other than getting warm the Range video TX and DX-201 camera just get warm, no lights on them to indicate power. Put I did check voltages with a DVOM and there are voltages where they need to be. I will have to pull the equipment out for pictures later tonight. I had them soldered onto terminals using 3 wire JR cables and connectors. Then tried straight soldering with shrink wrap, still nothing. I was using a small LCD screen with a stereo type AV plug as the input, but I will try a B/W TV that has RCA inputs from the RX's RCA output. When I get the equipment out tonight. Thank you.
Brett
For Sale Video Goggles ObiWanOvermann FPV Equipment (FS/W) 5 Oct 23, 2011 08:49 PM
For Sale Gently used 900 mhz patch and 1/2 wave 900 mhz tx antenna Kahuna717 FPV Equipment (FS/W) 1 Aug 02, 2011 09:53 PM
For Sale Gently used 900 mhz patch and 1/2 wave 900 mhz tx antenna Kahuna717 FPV Equipment (FS/W) 4 Jul 03, 2011 12:20 AM
Discussion what can i do to improve my rv 900 mhz video tx? djdaveq FPV Talk 6 May 10, 2010 05:07 AM
Discussion RV 900 MHz range problems... jimbril FPV Talk 34 Apr 18, 2009 03:06 PM
