Old Jan 29, 2013, 02:34 PM
lanerover is offline
Find More Posts by lanerover
United Kingdom, England, Clay Cross
Joined Jan 2013
Further to my previous post this is todays result of attempting to fly. I was gliding the model very easily straight and level. I then tried about 1/4 throttle and the model flew relatively straight. At 1/2 throttle the model started to turn to the right,I managed to cut the throttle and land. I then tried again again I let it come full circle towards me, at this point it was flying into the wind (about 12/15 mph) The wind appeared to get under the wing and started to lift the model which started to climb and then stall and fall back only to keep repeating the process. I was trying to get it under control by letting go of the sticks but the wind kept taking it further away. I tried to bring it back with more throttle but again it was travelling into the wind and now started turning somersaults. I had no option but to cut the throttle and let it fall at which point it spiraled into the ground with the results shown.Rather than bin the model I decided to try repairing with a hair dryer, thin cyano, kicker and some spare carbon rods.
I'm quite pleased with the results after 2 hours work.
lanerover is offline Find More Posts by lanerover
Old Jan 29, 2013, 04:33 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Lack of airspeed led to a stall. Pilot error I'm afraid to say.
Also, your previous pictures show a very poorly aligned airframe. Nose looks very bent and the right aileron is up enough to turn.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Jan 30, 2013, 05:09 AM
Joined Jan 2013
Thanks Gerry I would probably agree,however since the latest crash I've managed to straighten the nose, the ailerons always "park" in this position until powerup exactly the same on my Wildthing. The lack of airspeed could be due to the lack of motor power the correct motor was damaged in an earlier crash and this one was fitted as a temporary measure I'm hoping to fit the correct one again before the weekend. Much of the twist in the airframe is as it came out of the box, the stabilizer was so bad that I have tried to straighten it 4/5 times, initially it was so bad that operating the elevator caused the stabilizer to move about 30mm at each end as it tried to straighten the bent hinge line, eventually the elevator ripped off at the hinge line before the model had flown. Needless to say I'm not very enamoured with the quality of Multiplex components. Hopefully I will have more to report on Sunday, a friend who is a BMFA instructor is to try to fly the plane.
Old Jan 30, 2013, 12:52 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
I think you need to do some research on foam planes. Many come out of their boxes like that but can be easily fixed.
Old Feb 17, 2013, 02:25 PM
Joined Jan 2013
Well I finally sorted the right turn problem! The right wing was dropped when viewed from the front and aligned with the stabilizer, this was cured with a balsa packing (about 1-2 mm thick ) under the wing where it fits into the fuselage, the left wing also needed a packing about half as thick.. I've also straightened the stabilizer with a 2 mm carbon rod along the hinge line.
The first flight with the BMFA instructor resulted in him having to apply full down elevator to stop the plane trying to somersault, this was resolved with re-trimming and resulted in several successful flights. The instructor was really impressed with the model in spite of 24 mph wind and he being a committed i/c man. Must say I'm dead chuffed I was beginning to think it would never fly!
Discussion Easy Star RTF - only "easy" after 1 year - NOT for beginners MiddleMarc Beginner Training Area (Aircraft-Electric) 43 Feb 27, 2012 04:36 PM
Help! Small Cessna 15" wings Pulls to the right on take off! ShokWaveRider Scratchbuilt Indoor and Micro Models 3 Sep 09, 2011 09:57 PM
Discussion Easy Glider vs. Easy Star as video platform? StephenG Beginner Training Area (Aircraft-Electric) 6 Apr 27, 2011 03:56 PM
Discussion Multiplex Easy Star 2006 - A discussion of anything Easy Star and sometimes more Grassy Knoll Foamies (Kits) 6833 Dec 31, 2006 10:45 PM
Help! multiplex easy star continously steer right - HELP! menih Electric Plane Talk 8 Oct 26, 2006 11:19 AM
