Old Sep 11, 2011, 04:25 PM
kruiser7 is offline
Find More Posts by kruiser7
kruiser7's Avatar
United States, WV, Beckley
Joined Feb 2008
Brushless Hydro Build
Finally starting to get a break in work, summer is over. I gained a lot of information from you people on my last adventure, and am now ready to do a serious brushless hydro. I was finally able to obtain the hull that I want to use from a friend of mine that never got around to finishing it. It is an Aeromarine Sport X Hydro. It measures 50" long and is 25" wide at the forks. It is complete with all of the Aeromarine hardware , and has a modified BH Hanson aluminum motor. The boat has neven been finished. I always like the massive size of the boat and glad that I now own it! I am ready to start buying up the new power system for it. I want it to be CRAZY fast ! I want it to be single brushless power. What I am asking for is some good advise on a motor and ESC. I will appreciate any and all input into this. And thanks! Its great to have the time now to devote it to my hobbies!
kruiser7 is offline Find More Posts by kruiser7
Old Sep 11, 2011, 04:32 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
The most powerful motor that i can think of without getting into Lehner's is the Neu 2230. Neu makes motors that are available in 2215, 2220, and 2225 as well. A Castle 2028 is another great option and powerwise its right along with a Neu 2225. You will need 9-10s lipo minimum and possibly 12s in 2p config. with the 2230.
scorpion1 is offline Find More Posts by scorpion1
Old Sep 11, 2011, 06:34 PM
kruiser7 is offline
kruiser7's Avatar
Joined Feb 2008
That are the motors that I have come up with so far myself and seem like good choices, just not sure what the top end in speed might be. I hear a lot about the Lehner motors also, but the only place I have seen them is FineDesign, and Im not going to that subject right now, lol, thanks Scorpion , Seems like some good choices, but what kind of RPM's do you think useing 12s and a ball park figure in top speed. This is a pretty good sized boat.
Old Sep 11, 2011, 07:11 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I run a Castle 2028 and 9s2p in my 50" Hydro, allows me to spin a bit larger prop. RPM's are in the 26,000 range.
Here's my "Big Red"
50" Hydro Castle 2028 WOT runs (2 min 3 sec)
Old Sep 11, 2011, 07:32 PM
kruiser7 is offline
kruiser7's Avatar
Joined Feb 2008
VERY impressive Scorpion,, seems to both run and handle extremely well! If you wanted to push it a little farther , what would you do? Different motor, more battery?
Old Sep 11, 2011, 07:51 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What do you consider "crazy" fast?
wparsons is offline Find More Posts by wparsons
Old Sep 11, 2011, 07:57 PM
kruiser7 is offline
kruiser7's Avatar
Joined Feb 2008
I am very impressed with Scorpion's hydro, it is awesome!!!! To be honest, I can only afford one shot at this, and it has to be the best that I can do. I want to make this big hydro do all it can do.
Old Sep 11, 2011, 08:07 PM
kruiser7 is offline
kruiser7's Avatar
Joined Feb 2008
I want to push this hydro close to 100 mph. This is a very serious attempt to build something that I have wanted for a long time.
Old Sep 11, 2011, 09:15 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
100 mph is a bit much..............one thing goes wrong............hit a stick, bad hop on a wake................and you're toast.
But if you want to go all out, go for a Neu 2230 1y 725kv on 12s Lipo................or for 100 bucks more a Lehner 3080 8 turn on 12s.
Old Sep 11, 2011, 09:24 PM
kruiser7 is offline
kruiser7's Avatar
Joined Feb 2008
Scorpion, I do realize the "cons" of going this fast. I do appreciate your help and input, and I truly value what advise you have to share. Like I said, I can only afford this once, no trial and error, this is something that I have to do. Can I purchase the Lehner somewhere other than from Chris Fine? I had a bad experience with him before, and I dont now if I can trust, or deal with him again.
Last edited by kruiser7; Sep 11, 2011 at 09:29 PM. Reason: wanted to add more info.
Old Sep 11, 2011, 11:10 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You can google Lehner motors...............they sell them in Germany and a few other sites i believe. I'd just go with a Neu 2230 from Steven at OSE. He backs his products with the warranty it comes with and you dont have to go thru a bunch of crap to get it done if need be. A Neu 2230 1y on 12s should get you into the mid to high 70's on 12s.
Old Sep 12, 2011, 02:20 AM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
I like your 10S run better.
mozzyrocks is offline Find More Posts by mozzyrocks
Old Sep 12, 2011, 02:58 PM
Racer59 is offline
Find More Posts by Racer59
United States, CA, SF
Joined Sep 2006
I also have a question not to steal the thread about your post.
I have a 52 inch cat. I just finished installing the Leopard Motor and a 240HV ESC.
I plan on runnng it in series at 18.5v each side so I have 37 volts to run.
Question is..... I was instructed to install a X452 prop.
Is that prop too small for the big cat?
I ran it last time with the prop similiar to the 275 Octura and the ESC burned down on me
I mean flame coming out.
I finished the job and never had the chance to run it yet.
So, 37 volts on a 52 inch cat running on a Leopard motor 1090KV with the King Fisher 240HV ESC. Is this a good combo for the prop?
Thank You for all the inputs.
Julio.
Racer59 is offline Find More Posts by Racer59
Old Sep 12, 2011, 04:06 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I assume you are referring to a 5692 Leopard. I would not recommend 10s for that motor if its the 5692 1090 kv, 8s is better witha bit more prop like in the 55-57 mm range. If you are set on 10s i would go smaller like has been recomended to you.
Old Sep 12, 2011, 04:35 PM
rotorkilla is offline
Find More Posts by rotorkilla
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
You can get Lehner motors from here in Germany, they are a reliable supplier;
www.hydromarine.de
rotorkilla is offline Find More Posts by rotorkilla
For Sale Lobster Hydroplane hydro Electric Brushless ARTR rc Boat Rigger t161 Boats (FS/W) 12 Nov 25, 2011 04:16 AM
Discussion ProBoat Formula Hydro being converted to brushless! DoctorAudio Racing Boats - Electric 16 Jul 12, 2011 07:14 PM
Discussion 4 Cell 34" OutRigger Hydro Build / Photos / Design Details / 720P Video ryan_t888 Racing Boats - Electric 13 Jul 07, 2011 10:39 AM
Sold 2 TENSHOCK BRUSHLESS Micro Hydro RC Boats k10smith Boats (FS/W) 3 Apr 29, 2011 05:51 PM
Discussion build manual for Hydro Glider dlysell Foamies (Scratchbuilt) 4 Apr 27, 2011 10:22 AM
