Old Sep 15, 2011, 05:57 PM
wing_man is offline
Find More Posts by wing_man
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Bob,
Do you have a part number for xps? I'm trying the store availability function on the home depot site to see if I have it locally...
Dennis
wing_man is offline Find More Posts by wing_man
Old Sep 15, 2011, 10:04 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
No # , but it's called Dow residential sheathing
I only was looking for Blue because I didnt think GUYS wanted pink ,generally speaking, ya know :-)
silly ,YEs, but ...
bob
birdofplay is offline Find More Posts by birdofplay
Old Sep 15, 2011, 10:34 PM
trroadster is offline
Find More Posts by trroadster
trroadster's Avatar
Canada, AB, Edmonton
Joined Oct 2006
How about this ??
http://www.hobbyking.com/hobbyking/s...F600kv%5F.html
Originally Posted by Otto Dieffenbach View Post
This looks like a cheap alternate motor that should do the job well.
Originally Posted by wing_man
Thanks, motor shopping right now...
Dennis
Description
The G40 (50-45) brushless out-runner motor can replace a .40 - .46 two stroke nitro engines. It is equivalent to AXI 4010, more power than the E-Flite Power 32, but less than Power 46. It is capable of producing up to 7 lb of thrust and generate about 800W of power.
Specifications:
KV: Listed as 890, tested to be approx. 910.
Weight: 7.1oz (202g) for motor only, not including mounting accessories.
Motor Diameter: Approx. 50mm
Shaft diameter: 8mm
Max efficiency: Approx. 50A
Max Load: Approx. 60A
Motor Dimensions:
Recommended Setup:
80A Opto brushless motor ESC
3-5S LiPO and at least 4000-5000mAh.
Prop Selection: Remember to always use props designed for electric motors, nitro props are heavier and might overload the motor.
With 5S LiPO: 10x6
With 4S LiPO: 12x6, 11x7, 11x6
With 3S LiPO: 14x6, 11x8.5
The above prop selections are recommended for sports flying at open throttle. You may use slightly larger props if you do not fly at constant open throttle.
How about this one?
Otto's reply:
That one sounds great. What's the price/source? I did some visiting yesterday at Inov8tive Designs and they have a bunch of prop data. I now use an APC 10x7 prop at 981kv generating 5 lbs static thrust. The same motor will generate 6 lbs thrust with an APC 11x7. Their data indicates that with a Master Airscrew 10x7x3 3 blade at this kv you get the static thrust of the 11x7 but the amp draw of the 10x7. It was pretty conclusive that 4s with this prop and kv are a great combination for this plane.
trroadster is offline Find More Posts by trroadster
Old Sep 16, 2011, 12:00 AM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Originally Posted by trroadster View Post
The wattage looks good but the kv is too low. This kv would take a large diameter prop to get the power. Find a similar motor with 900 to 1000kv then you would be good. I have had a bad experience with large HK motors; it didn't meet advertised spec and I burned it up. The smaller motors have been great.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Sep 16, 2011, 12:39 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
MAYBE THIS ONE ...
http://www.hobbyking.com/hobbyking/s...dProduct=16233
THE ONE i WILL BE TESTING WITH IS OUT OF STOCK JUST NOW.
Old Sep 16, 2011, 04:21 AM
Joined Aug 2011
Originally Posted by birdofplay View Post
MAYBE THIS ONE ...
If you use this one an APC E10x7 prop will put you at the amp limit for the motor so be careful or back off a little to an APC E9x7.5.
Old Sep 16, 2011, 06:36 AM
wing_man is offline
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Bob,
does the sheathing come like blue fanfold? All hooked together? My Home Depot has a "pink" fanfold...no where near 1/2 inch though...3/8 inch maybe...I guess that is near 1/2 inch...lol.
They do have the rigid pink stuff without plastic covering.
Dennis
Ebay'd an 80 amp controller....bought some 10x7 3 blade props...still undecided YF-22 or F-15, I know eventually I'll build both...lol
Old Sep 16, 2011, 10:07 AM
K2XR10 is offline
Find More Posts by K2XR10
ski bum
Joined Oct 2009
But hey ... I thought you were on the ID/NV boarder ?
That's 3/4 of the St of OR away from Portland.
True that. But Lowes has a lovely website that shows what stores have stock on what foam, and for what price. I noticed that the Delta Park Lowes had the 1/4" stuff. Didn't check on the 1/2".
But let me get this right...Otto used 1/2" beadboard and you're looking to make it out of 1/2" blue foam? Seems like a great idea.
K2XR10 is offline Find More Posts by K2XR10
Old Sep 16, 2011, 11:01 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Wow pink FFF 3/8" ...intersting.
The BIG 4x8 sheets do not come in fanfold form.
They come on a TRUCK ! :-)
Let me be clear ....
I've been all over the lowes and HD web sites. and allied and and and ...
HD and Lowes' Local stocking varys widely.
I simply want it local to save acquisition costs.
As it is HD and Lowes are ~ 30 miles away. ONE WAY
I want a NO SKIN foam board because I cant cut the skinned stuff with my CNC.
The skin, as I've said B4, is a lower temp than even the styrene.
SO it melts, builds up on my bit, then makes a mess and ruins the cutedge.
Blue is simply because some guys dont like "pink".
Pink is fine and I'm using it on my current build.
I'm going to do a slide on carpet test with my YF sometime today.
THEN as soon as I get time, I may REwork my Small F22 so the bottom is
suited to grass slide take offs.
Old Sep 16, 2011, 11:21 AM
wing_man is offline
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Bob,
Did you make adjustments to the plans after you fitted the parts? Any tweeking? Any pics/video of the carpet slide?
Sorry for all the questions...last one...PDF coming?
Just found 1/2 XPS PINK on the Home Depot store site for Erie, PA....road trip this weekend...only 30 miles.
Almost ready to start mine!
Thanks...Dennis
Old Sep 16, 2011, 04:49 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
No adjustments or updates to the plans provided a few pages back yet.
I wanted to wait until I got mine tested.
That's why I gave a HEADS UP re the slight dimensional changes a few posts back
for guys who were already building.
I'll do a PDF when I'm happy with the parts fit.
Parts fit is kinda "variable" since there is a lot of Beveling and shaving to get that 22.5 deg side and Fin angle.
PLus the Front bottom fuse parts also have an Angle in their assembly.
I'm thinking that this is going to be a challenging Builders Kit
NEWS !!!
It's almost flyable , not painted, But Balances so I QUICK slapped some tape on the bottom and went out in the back yard for a SLIDE TEST.
After a couple of wiggles of the elevons it started sliding and was airborne as it passed over the sidewalk.
I didnt exactly expect that, It flew about another 30 feet to the edge of the yard and stopped.
It looked about right IMHO.
So I am pretty happy SO FAR :-)
This is at 3# 7oz AUW using PINK Foam, with a motor developing ~ 600 watts
as measured on my wattmeter , Using a 9.5 x 6 Master Airscrew and 4 cells.
It's QUITE the Handfull Of FOAM !!!
Old Sep 16, 2011, 04:57 PM
Joined Aug 2011
NEWS !!!
Now there are two.... Congradulations on your first hop. You'll really love it with room.
Old Sep 16, 2011, 05:20 PM
wing_man is offline
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Congrats!
Thanks for the update...
Dennis
Old Sep 16, 2011, 05:31 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
I think I'm going to try some of that H20 spray paint in a can.
Kinda of a dessert pale yellow/sandy color then some camouflage spots.
Thanks Otto.
T'morro's Sat I will try to get in a full flight then !
C U L8r
Bob
Old Sep 16, 2011, 05:46 PM
Joined Aug 2011
Thanks Otto.
C U L8r
Bob
Will be waiting to hear....
Discussion Giant Foamie Home Depot F-15 Otto Dieffenbach Foamies (Scratchbuilt) 809 Sep 08, 2014 08:51 PM
Discussion Enlarged YF-22 (yardbird copy) w/twin pushers? Doubledog Pusher Prop Jet Models 3 Feb 23, 2012 11:30 AM
Sold H9 Raptor YF 22 flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 13, 2011 05:28 PM
Discussion i want to go out and build a foamie plane tomorrow. can i goto home depot, an art sup captaingeek Foamies (Scratchbuilt) 11 Jul 09, 2009 04:48 PM
Giant Pink Plane courtesy of Home Depot HIGHFLYER99 Foamies (Kits) 3 Apr 14, 2004 10:11 AM
