Old Sep 14, 2011, 02:46 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
Originally Posted by Rimmyman View Post
also, just out of curiosity here, has anyone considered using this?
http://www.hobbyking.com/hobbyking/s...idproduct=6565
might pretty much eliminate the torque roll from the frame. its going into my next plane! (I would love to use the F-22 as a test platform actually)
Not enough Watt output. Need around 600 watts.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Sep 14, 2011, 03:11 PM
Rimmyman is offline
Find More Posts by Rimmyman
San Jose, CA
Joined Mar 2006
well thats a bummer. counter rotating would have been slick
Rimmyman is offline Find More Posts by Rimmyman
Old Sep 14, 2011, 03:15 PM
Rimmyman is offline
San Jose, CA
Joined Mar 2006
seems they make one.
http://www.maxxprod.com/mpi/mpi-266.html
800 watts. $200 though, sounds kinda pricy!
Old Sep 14, 2011, 05:12 PM
Joined Aug 2011
Yeah, the $35 G40 option looks like the best.
Old Sep 14, 2011, 06:06 PM
wing_man is offline
Find More Posts by wing_man
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Ordered my motor...checked home depot for foam. All they have here is one with foil on one side and plastic on the other and of course they have pink stuff. I bought my dowels and spar...
wing_man is offline Find More Posts by wing_man
Old Sep 14, 2011, 08:38 PM
Joined Aug 2011
My Home Depot looked at me crazy when I started talking about pink foam, fanfold, blu cor or anything but the R-Tech and foil type.
Old Sep 14, 2011, 10:01 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
It all kinda depends on the WEATHER in your area and what the contractor need/want.
My search for Blue again today ended with ZILTCH !
I' will look around in the Portland area again tomorrow.
birdofplay is offline Find More Posts by birdofplay
Old Sep 15, 2011, 01:29 AM
foamdave is online now
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
dupe
foamdave is online now Find More Posts by foamdave
Old Sep 15, 2011, 01:33 AM
skumgummi dave
Gresham, OR.
Joined Mar 2004
birdofplay:
Have you tried Allied Building Products
www.alliedbuilding.com - 11305 Northeast Marx Street, Portland - (503) 256-5544.
Dave-
Old Sep 15, 2011, 10:07 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Web says they are a definate maybe. thanks dave
Old Sep 15, 2011, 11:46 AM
wing_man is offline
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Well I wanted to use the same material as you Otto...but I'm out of luck, I might try home depot in Erie, PA. If not I'm going PINK...
Dennis
Old Sep 15, 2011, 01:45 PM
E28 is offline
E28
Find More Posts by E28
E28
United States, AL, Troy
Joined May 2011
Do you leave the binding on the foam?
E28 is offline Find More Posts by E28
Old Sep 15, 2011, 02:07 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
For the stuff Otto used the BINDING stays ON !
It would be way too flimsy with it removed. I just Expanded bead type foam.
The XPS ( extruded) foams stiull have a thin film on them. At least the Pink does.
ANd I remove it for two reasons.
1. it is a lower temp plastic and melts on my Router bit when I'm cutting it.
2. it leave a messy edge when left on and easily peels off
so I presume very littel strength if kept. AKA NO benifit.
BTW Sprnt the day on the river yesterday, however,
I am almost done with my F-22 test build.
Every thing is hinged and I have servos installed.
I'm getting around 600watts with a 9.5x6 MAS prop.
more l8r
So stay tuned.
Bob
Old Sep 15, 2011, 04:38 PM
K2XR10 is offline
Find More Posts by K2XR10
ski bum
Joined Oct 2009
What sort of "Blue" are you looking for? There are gobs of 1/4" Dow PBII in the Portland area, $38 per bundle.
K2XR10 is offline Find More Posts by K2XR10
Old Sep 15, 2011, 05:53 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Just returned from Shipping out another The Twins kit to N.H. !
K2xr10:
1/2" is the thickness that Otto used for his YF-22 and the F-15 and the Sea Dart.
I can get Pink OC brand at Homedepot.
But locally all I see stocked is 3/4" blue or thicker.
I dont WANT to have to hot wire split thicker sheets.
Allied says they either have it or might order it.
But you know the SUPPLIERs song.
Buy a LOAD or go away ! NO sympathy for low volume guys like me.
I'd sooner make them out of 9mm Depron if that's they way they want to play.
But hey ... I thought you were on the ID/NV boarder ?
That's 3/4 of the St of OR away from Portland.
Discussion Giant Foamie Home Depot F-15 Otto Dieffenbach Foamies (Scratchbuilt) 809 Sep 08, 2014 08:51 PM
Discussion Enlarged YF-22 (yardbird copy) w/twin pushers? Doubledog Pusher Prop Jet Models 3 Feb 23, 2012 11:30 AM
Sold H9 Raptor YF 22 flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 13, 2011 05:28 PM
Discussion i want to go out and build a foamie plane tomorrow. can i goto home depot, an art sup captaingeek Foamies (Scratchbuilt) 11 Jul 09, 2009 04:48 PM
Giant Pink Plane courtesy of Home Depot HIGHFLYER99 Foamies (Kits) 3 Apr 14, 2004 10:11 AM
