Old Sep 13, 2003, 08:24 AM
hflyer is offline
Find More Posts by hflyer
Australia
Joined Sep 2003
How to check if motor is burnt out?
I recently got a feda dragonfly. It worked fine during the first flight (I was really enjoying it too! ). But on the second time, the main motor does not seem to start up.
Does anyone know of a simple way to check if it is the motor that has burnt out? (do they burn out so easily just after one flight?!)
Are there any visible indications on a burnt out motor that I can check for?
I've tried swapping the tail motor and the main motor around (where you plug it into the mixer) and the tail motor still works when I give the corresponding inputs on the transmitter, but the main motor doesn't work in either slots. Does this mean the mixer is still ok, and it is just the main motor is broken?
Thanks for any help,
Samuel.
hflyer is offline Find More Posts by hflyer
Old Sep 13, 2003, 11:14 AM
Glenn Cain is offline
Find More Posts by Glenn Cain
Joined Oct 2002
yeah that happened to me too
i had 3 minutes of flight straight after getting home from buying it and half way in my spool-up, throttle chopped. tested and it was not esc fault. went back to my LHS and they said they were willing to give me another motor but they will not accomodate another similar occasion as there 'was no gaurantee on these product'. might be the factory QC
Glenn Cain is offline Find More Posts by Glenn Cain
Old Sep 14, 2003, 02:00 AM
Supersix is offline
Find More Posts by Supersix
Supersix's Avatar
Sydney, Down under
Joined Aug 2003
dont hook it up to heli if u r suspect as this can cause a short in the motor and fry your mixing board. i know two people that this happened to (the original motors arent worth jack #@$%) if it dont spin i would say it is rat @#$% i bet if u take of the end of the motor one brush will be missing
Supersix is offline Find More Posts by Supersix
Old Sep 14, 2003, 06:53 AM
hflyer is offline
Australia
Joined Sep 2003
Thanks for the tips guys.
Looks like I need to look into buying a more reliable motor for it.
Old Sep 20, 2003, 04:58 AM
hflyer is offline
Australia
Joined Sep 2003
Ok, I took the motor out and had a play around with it and I've found out that the motor is still fine. It's just one of the capacitors that's connected to the shell casing is busted.
Does anyone have any information on what these capacitors are called (and what they are for) and if they are easily purchasable from electronics stores?
(There's a number 473 written on it and the capacitor is light brown in color).
Thanks.
Old Sep 20, 2003, 10:29 PM
Supersix is offline
Supersix's Avatar
Sydney, Down under
Joined Aug 2003
yes i got the caapacitor from dick smiths the part number is
R 2360
cap cer 50v y5v 5mm ls 0.1 uF (that what invoice says on it)
they were 30c each
Old Sep 20, 2003, 11:32 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Hflyer,
The 473 on the cap means 0.047uF, but the 0.1uF cap that Supersix mentioned will work fine. However, a broken cap will not keep the motor from working, unless the broken ends are shorting the two motor wires together. The caps are only there to keep the motor from interfering with the receiver. The motor should still run without any caps at all.
Jeff
Ps. I was curious about dick smiths, so I looked up their web site. It looks like an interesting store. Their part number for the 0.047uF is R2007. For those of us in the US, the radio shack part number is 272-134.
jeffs555 is offline Find More Posts by jeffs555
Old Sep 21, 2003, 06:12 PM
hflyer is offline
Australia
Joined Sep 2003
Thanks all! I got some capacitors from Dick Smiths on the weekend and my bird is up in the air again!
Discussion Axe EZ - How to Tell if Motor is Burned Out? Lon33 Coaxial Helicopters 6 Dec 28, 2007 01:30 AM
Discussion Blade CP: How to know if the motor is burned out? David Winter Micro Helis 9 Jun 09, 2006 03:43 PM
How come if a motor operates > 12v, people use it with a 4.8v cell to power planes? mortonj69 Power Systems 9 May 16, 2003 07:47 AM
how to tell if a motor can pull a certain plane bmess Electric Plane Talk 2 Oct 17, 2001 11:17 AM
how to tell if a motor can pull a certain plane bmess Fuel Plane Talk 2 Oct 17, 2001 02:55 AM
