Old Jun 17, 2012, 07:16 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Originally Posted by D.B. Hooper View Post
Got some work done on my Komet tonight. I'm using the Sapac black tornado and fan unit out of my crashed L39. Did a bench test on 4s and 5 s
5s 78 amps 1374 watts
4s 56 amps 780 watts
D.B.
I think the 1374 watt option will result in a heavy ready-to-fly model because of large ESC and batteries requirements.
Are you going to stick with your 4S setup?
My batteries arrived this morning so will test fly in the coming week - most likely Saturday if the weather permits.
Slaanesh is offline Find More Posts by Slaanesh
Old Jun 25, 2012, 12:54 AM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
Almost ready Going with the 4s set up with the ICE 75 lite.
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Jun 25, 2012, 07:09 PM
Vantagepoint is offline
Find More Posts by Vantagepoint
United States, TN, Nashville
Joined Aug 2008
What is the max speed achieved on the edf version? What power system was used (motor/fan combo, battery size and capacity)? Been looking at this one, but only if it's possible to get serious speed from it (140 +mph).
Vantagepoint is offline Find More Posts by Vantagepoint
Old Jun 26, 2012, 12:03 AM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Careful with those double ended servo links. I had one back out and crashed on takeoff. Those will unscrew when they vibrate. I soldered one end to prevent this.
p901P901 is offline Find More Posts by p901P901
Old Jun 26, 2012, 11:46 PM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I successfully maiden my ME-163 today.
I got a friend to hand launch it. Very gentle sag but she was away!
Beautiful and precise feel to the model.
Lots of float on landing!
3mm reflex is perfect. CoG at 93mm. 25-30° launch angle. Good strong throw. CS10 sounds great and so quiet. Glides for a long time thanks to smooth aerodynamics. Video coming.
Old Jun 26, 2012, 11:47 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Congrats! Sounds like a great flyer.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jun 27, 2012, 12:57 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Great! If possible please post a pic of your battery placement - what lipos did you end up using? Did you stick w/ 2100kV, or 2300kV?. Can't wait for the video (to see AND hear it), might have to get one after all, the HK Komet is great but I'd like a red one, too, and 3mm reflex sounds MUCH more reasonable for speed than the 8mm on the HK :-)
mopetista is online now Find More Posts by mopetista
Old Jun 27, 2012, 06:11 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I stuck with the 2100Kv motor on 5S - it's almost equivalent to a 2800Kv on 4S.
I used a 2200mah 3S and a 2200mah 2S 45C batteries in serial - one on each side of the thrust tube with the ESC on the same side as the lighter battery.
It really requires very little reflex which shows good wing design. I dialled in a little up trim just before hand launch and ended up dialling it all back out again with a little down trim required in the end.
The sound is good though the intake is probably still not the most ideal shape. The stock shape is a little "square".
My friend launched it for me over some long grass just in case there wasn't enough thrust but it was okay as you can see. 650W peak thrust in the first 10 seconds is enough to get it out okay!
Most of the flying was at 1/3 to 1/2 throttle as I was just enjoying sailing around. The landing was all sailing - no throttle - including downwind leg, turn and landing.
Commentary by a couple fellow fliers including a 2 in 10 chance of launch failure
ANTS163.mov (1 min 12 sec)
Old Jun 27, 2012, 06:24 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Oh yes, I also did a scale position/size flaps mod and tested them out during the flight and the ME-163 ballooned up a little - the above video does not have this.
I had no elevator mixed in to offset this but will do so for the next flight.
The flaps are located just behind the CoG and run the length of the inboard wing up to where the elevons start. Full deflection they are about 45°.
I think the will come in handy once trimmed out as you can see how floaty the model is coming in for landing.
Old Jun 27, 2012, 08:13 AM
Vienna, Austria
Joined Apr 2007
Very nice! Seems like a really slippery airfraime. How's the top speed at WOT, would it run appreciably faster than the the passes in the video? Congrats to the safe launch (good throw, it must be said!) and greased landing
cheers
Clemens
Old Jun 27, 2012, 04:43 PM
Trying get my CG set. Where are you guys measuring from, where the wing attachés to the fuse?
Old Jun 27, 2012, 07:48 PM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
It's not terribly fast at WOT. Probably around 130-140kph. It is slippery though and doesn't need WOT to keep the speed up.
Yes COG is measured from where the front of the wing root attaches to the fuselage.
I had two spare triangular "T-stoff" decals which I positioned at 95mm.
My balance point is 2mm in front of that.
Also for hi rates I used 7mm throws for elevator and 5-6mm for ailerons with 25 and 35% expo respectively.
Lo rates were 80% of these with 35 and 45% expo but I didn't try it and probably won't as high rates were perfect for my style of flying!
Old Jun 27, 2012, 11:27 PM
Having a hard time with the CG. First I tried 2- 2s 35c 4200mAh, way nose heavy.
Next 2- 2s 35c 2650mAh all the way back. still nose heavy. I moved the motor back 1 3/4' Still won't balance! It's around 90mm now. I guess my Sapac Black tornado EDF unit is way heavy. Weight with the 4s 2650mAh is 1180g 2.9 lbs. I'll just try flying like it is tomorrow. Will get video
Old Jun 28, 2012, 01:08 AM
munce31 is offline
Find More Posts by munce31
RA-TA-MA-HAT-TA
munce31's Avatar
Melbourne, Australia.
Joined Feb 2010
HobbyKing Daily - Servoless Airbrakes (1 min 38 sec)
these may be a good addition to the me163
munce31 is offline Find More Posts by munce31
Old Jun 28, 2012, 02:05 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Now thats something I can use in the Adventure glider! Sweeeeet
Extreme_RC is offline Find More Posts by Extreme_RC
Sold Don's Wicked EDF Extreme Motor 5400KV skyracer068 Aircraft - Electric - Jets (FS/W) 3 Sep 07, 2011 12:30 PM
Sold KOMET ME163 by Dave's Aircraft Works NIB KIT unclegeorge Aircraft - Fuel - Airplanes (FS/W) 3 May 29, 2011 08:00 AM
ACT Me163 Komet Build n Flite Report with Pics bolkow Foamies (Kits) 13 Jan 16, 2011 06:09 PM
For Sale S&B ME163 Komet docphi Aircraft - Electric - Airplanes (FS/W) 17 Oct 02, 2005 01:47 PM
S&B Me163 Komet movie Peter Young Foamies (Kits) 0 Jul 03, 2005 04:54 PM
