Old Apr 22, 2012, 10:04 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Originally Posted by D.B. Hooper View Post
Thanks for that info! I'm thinking of sticking with the 2W-20 Like you said to keep the weight down and make it easyer to launch. I do own a Jetapult bungee launcher.
my guess is u wont see 130 w/ that setup. at~ 800 watts the tractor version may get there but not the edf. could be wrong but thats a 100-110 mph deal in other similar jets. fwiw. 130 is in the big power league.
what say u 901?
chuck.
chas650r is offline Find More Posts by chas650r
Old Apr 22, 2012, 10:07 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
Originally Posted by SMCLEODVT View Post
i hand launch mine with a 3300mah - but its the prop jet and has more torque. just set your neutral flaperons at 4-5mm up to be safe - its a little high but helps when tossing - but the crappy part is that high speed passed you have to hold down elevator to keep at level -
up? thats spoilerons ? for launching?
Old Apr 22, 2012, 10:10 AM
SMCLEODVT is offline
Find More Posts by SMCLEODVT
SMCLEODVT's Avatar
United States, VA, Roanoke
Joined Nov 2009
when using a flying wing you gotta set neutral as up a little - and yes - i meant spoilerons - sorry
SMCLEODVT is offline Find More Posts by SMCLEODVT
Old Apr 22, 2012, 10:44 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
got it now, u mean reflex.
Old Apr 22, 2012, 12:10 PM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
what say u 901?
chuck.
How about a Storm EDF unit with the beast?
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Apr 22, 2012, 01:46 PM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
so hand launch is ok w/ the 4000? i will most likely bungee but not until its sorted out.
have u used the 2w20 and 6904 on more than 4's? seems like a smoke test to me , pretty high kv for 6's
chuck
My ME163 weighs 1700 grams and has retracts so I use a runway to take off. Have not tried the 2w20 on six cells. If the motor can take this what about the fan?
p901P901 is offline Find More Posts by p901P901
Old Apr 22, 2012, 02:21 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
the 6904 is very robust , good into the 1+ kw area no problem. the 2w20 is not, imo.
Old Apr 22, 2012, 03:38 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Maiden! Launch was hairy. The bungee snagged near the end of its pull and it went off at an extreme angle. Fortunately it survived that part then went on to a very good maiden. Good speed, Very stable. Thought it might be squirly but it wasn't. And as I left it all red, thought it also would be hard to tell up from down but that wasn't hard either so..happy!
HET 2W-20, 6904, 4000ma 4s
cheers,
stanordave is offline Find More Posts by stanordave
Old Apr 22, 2012, 05:12 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
cheers,
good to hear!! so can u guess at top speed?
chuck.
Old Apr 22, 2012, 06:06 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Problem with the WM400 setup is its power hungry, 108A to get 2.5kg thrust on 6s in their videos, the wemotec with ARC2858-1 pulled 87A to do the exact same sustained thrust, and the ARC will do it continuous, the Velocity motor is rated at burst only.
If you want huge 6s power then the new HET 1W40 in a wemo rotor'd fan is the way to go, it pulls 96A on 6s for just over 2000w, and is spinning the fan 5000rpm faster than the ARC setup!!! I havent had time to bolt one to the thrust stand but 2.8-2.9kg would be the result I think based on the rpm.
The Hoffmann are good heaters, pull lots of amps and dont outperform any of the quality inrunners.
The 2W20 wont run on 6s, not 5s, not in the 6904, this fan is too pitchy. In the wemotec fan the 2W20 will run on 5s but you have to be careful of WOT and limit your use of it.
Best setup for a balance of power and weight on 4s is the one I installed into Munce's Komet, Minifan PRO and 2W18 motor, 800w on 4s3300 packs, 1.5kg thrust and 125mph measured speed in level flight. It weighs 1.2kg and is an easy hand launch.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Apr 22, 2012, 09:23 PM
Was going to order the HET 1W-40 combo from you but just realized your in AU.
How much is shipping to the usa on something like this and how long?
Thanks D.B.
Old Apr 23, 2012, 02:18 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Shipping is real good these days to US, $27.00 gets you registered airmail up to 500 grams, can send fan and motor no problem in that, likely other small bits too. Aust Post says around 10 days but guys have been reporting 7 days on average.
Old Apr 24, 2012, 10:53 PM
If I can't find one here in the states I'll be getting one from you. Thanks for all the info.
D.B.
Old Apr 25, 2012, 10:18 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Dunno kids..that thing with a hole in the middle just looks.. Wrong.. to me.
Bare is offline Find More Posts by Bare
Old Apr 25, 2012, 12:24 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
funny , i was thinking just the opposite for me its about the noise factor , i know i can make a well balanced edf less obnoxious than the tractor model i have nib. any body want to trade?
Sold Don's Wicked EDF Extreme Motor 5400KV skyracer068 Aircraft - Electric - Jets (FS/W) 3 Sep 07, 2011 12:30 PM
Sold KOMET ME163 by Dave's Aircraft Works NIB KIT unclegeorge Aircraft - Fuel - Airplanes (FS/W) 3 May 29, 2011 08:00 AM
ACT Me163 Komet Build n Flite Report with Pics bolkow Foamies (Kits) 13 Jan 16, 2011 06:09 PM
For Sale S&B ME163 Komet docphi Aircraft - Electric - Airplanes (FS/W) 17 Oct 02, 2005 01:47 PM
S&B Me163 Komet movie Peter Young Foamies (Kits) 0 Jul 03, 2005 04:54 PM
