Old Mar 03, 2012, 05:52 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Just epoxy them in, I am doing one now and used some 1.5mm ply sheet in the wing then epoxied the servos to it with some blocks either side to increase support. Then use the supplied film to cover over the holes, looks neat.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Mar 03, 2012, 10:11 PM
SMCLEODVT is offline
Find More Posts by SMCLEODVT
SMCLEODVT's Avatar
United States, VA, Roanoke
Joined Nov 2009
thank you - exactly what i did and it came out good - to the point of making a template for the motor - maybe tomorrow - doesnt look too fun
SMCLEODVT is offline Find More Posts by SMCLEODVT
Old Mar 11, 2012, 11:11 AM
SMCLEODVT's Avatar
Joined Nov 2009
should there be any thrust angle in the motor? i guess the plywood mount was put in completely crooked and when i put the spinner on it looks horrible so im gonna sand it down flat - should i leave some down and right or is it not needed?
Old Apr 04, 2012, 11:13 PM
stanordave is online now
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I just started to build mine and saw it has a similar problem to Arnold's except my motor mount is in crooked. Very crooked
stanordave is online now Find More Posts by stanordave
Old Apr 05, 2012, 08:19 AM
SMCLEODVT's Avatar
Joined Nov 2009
i built the prop jet - you will definitely have to straighten that one out... i thought about the ducted fan version - may have to get one
Old Apr 05, 2012, 11:33 AM
stanordave's Avatar
Joined Jan 2006
Well Tony at HET said to try to fix it myself and if I screw it up, he'll replace the fuselage. Can't ask for any better than that. He also said epoxy was OK. Just was confirming that as one thread mentioned something about it not sticking, etc...
Think it will be a straightforward, quick affair. Was hoping to fly it this weekend (Wx permitting as always)
cheers,
Old Apr 11, 2012, 02:06 PM
toro_0397 is offline
Find More Posts by toro_0397
Joined Mar 2009
hello, what would be the fastest setup for this jet? i was wondering if it would be faster than the prop version? thanks for the help
toro_0397 is offline Find More Posts by toro_0397
Old Apr 11, 2012, 07:58 PM
SMCLEODVT's Avatar
Joined Nov 2009
i have seen both and i think the prop version is faster
Old Apr 11, 2012, 08:40 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Depends how its set up, our mild EDF version does 200kmh with an 800w 4s fan in it. Easy to fit a lot more power into it.
Old Apr 11, 2012, 10:44 PM
munce31 is offline
Find More Posts by munce31
RA-TA-MA-HAT-TA
munce31's Avatar
Melbourne, Australia.
Joined Feb 2010
How's the second build going Mark? Moving a long at a pace I hope
munce31 is offline Find More Posts by munce31
Old Apr 21, 2012, 11:08 PM
D.B. Hooper is offline
Find More Posts by D.B. Hooper
Flirtin With Disaster !!
D.B. Hooper's Avatar
United States, OR, Mt Angel
ME 163 Komet on the way!
My ME 163 Komet EDF is on the way!
Haven't decided on the power system. Was thinking of the 2w -20 with the HET 6904, ICE 75. Would like to get 130mph or so. Any recommendations before I order the fan unit this weekend?
D.B.
D.B. Hooper is offline Find More Posts by D.B. Hooper
Old Apr 22, 2012, 02:37 AM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
D.B.
My setup is with the HET 6904 and 2w-20 with a 4000mA 4 cell battery and a 100 amp ESC. Its plenty fast and thinking of placing 2 x 3 cells near the wing roots inside the fuselage. 6 cells should bring the speed up.
You could also try the WM400 mkII Fan/Motor Combo, 6s
Specs:
Thrust...2500g (5.5lb)
efflux....345kph (214mph)
Watts...1900-2000 (burst)
Amps....105-110
RPM......54K
Lipo......6s
Motor....2900kv, 28-56mm, 4mm shaft
With this setup you will need to place this EDF further back into the fuselage for proper CG.
All these combos will bring the weight up and hand launching would be difficult.
p901P901 is offline Find More Posts by p901P901
Old Apr 22, 2012, 10:33 AM
Specs:
Amps....105-110
RPM......54K
Lipo......6s
Thanks for that info! I'm thinking of sticking with the 2W-20 Like you said to keep the weight down and make it easyer to launch. I do own a Jetapult bungee launcher.
Old Apr 22, 2012, 10:55 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Specs:
Amps....105-110
RPM......54K
Lipo......6s
so hand launch is ok w/ the 4000? i will most likely bungee but not until its sorted out.
have u used the 2w20 and 6904 on more than 4's? seems like a smoke test to me , pretty high kv for 6's
chuck
chas650r is offline Find More Posts by chas650r
Old Apr 22, 2012, 11:03 AM
SMCLEODVT's Avatar
Joined Nov 2009
i hand launch mine with a 3300mah - but its the prop jet and has more torque. just set your neutral flaperons at 4-5mm up to be safe - its a little high but helps when tossing - but the crappy part is that high speed passed you have to hold down elevator to keep at level -
Sold Don's Wicked EDF Extreme Motor 5400KV skyracer068 Aircraft - Electric - Jets (FS/W) 3 Sep 07, 2011 01:30 PM
Sold KOMET ME163 by Dave's Aircraft Works NIB KIT unclegeorge Aircraft - Fuel - Airplanes (FS/W) 3 May 29, 2011 09:00 AM
ACT Me163 Komet Build n Flite Report with Pics bolkow Foamies (Kits) 13 Jan 16, 2011 07:09 PM
For Sale S&B ME163 Komet docphi Aircraft - Electric - Airplanes (FS/W) 17 Oct 02, 2005 02:47 PM
S&B Me163 Komet movie Peter Young Foamies (Kits) 0 Jul 03, 2005 05:54 PM
