Old Oct 23, 2011, 08:55 PM
galognu's Avatar
Joined Dec 2004
So based on the experience here so far, two 4000 or 5000s would be too much battery huh?
I guess I'll go with two 3200's
THanks
galognu is offline Find More Posts by galognu
Old Oct 23, 2011, 10:03 PM
Spoont's Avatar
Australia, New South Wales, Sylvania
Joined Nov 2009
I have trouble stuffing a 4s 3000mah battery in so anything bigger than this is not gunna work but then it depends on the physical size rather than the capacity. It think the CG would be too difficult to control with a heavier battery as well, she is already a handful to land if you don't have the luxury of a large field.
Spoont is offline Find More Posts by Spoont
Old Oct 24, 2011, 01:52 AM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Joined Mar 2006
My ELITE 3200 4s just fits between the formers, its velcroed in on 2 sides, and the CG is a couple mm in front of the 90 point, I would rather it was back at 95mm so will add some lead under the tailpipe in the back, it lands too hot with the forward CG and elevator is sluggish. Might be able to move the Rx back into the fuse further but it weighs 2/10 of bugger all
Extreme_RC is offline Find More Posts by Extreme_RC
Old Oct 31, 2011, 08:04 AM
San Jose, CA
Joined Mar 2007
I am thinking about putting an ARC 28-47-2 and 8S in this plane. That's the setup I put in my E-flite sabre and it was pretty insane (1400 watts). I could get about 4 minutes of flight out of two 4S x 2450's.
I used a tam shroud. I think the shorter can arc needs it (or something else with a metal center body) at this wattage.
On the plus side, for the watts, it's a pretty light setup. You can also use a CC Ice-50 controller.
Heres the Sabre vid for them that are interested. (excuse the potty mouth)
Mike's Sabre (3 min 32 sec)
mbigby is offline Find More Posts by mbigby
Old Nov 01, 2011, 03:25 AM
Extreme_RC's Avatar
Joined Mar 2006
I run the 2848-1 on 4400 4s packs and its at 1400w / 2kg thrust as well, I would guess my AUW is slightly lower than a pair of 2500mah 4s packs in series.
Mine is running in the stock wemo fan no problem in my Sapac Hawk, hikes along and has really made the model.
Old Nov 01, 2011, 04:21 AM
RA-TA-MA-HAT-TA
munce31's Avatar
Melbourne, Australia.
Joined Feb 2010
For the first time today, I flew the Komet under the supervision of Extreme_RC. The plane's response felt precise and more than enough power for straight-up vertical (at only ~850 watts). Even at 1/3 throttle it would cover a lot of sky, so it's without a doubt an efficient air frame when it comes to aerodynamics.
munce31 is offline Find More Posts by munce31
Old Nov 01, 2011, 04:27 AM
Extreme_RC's Avatar
Joined Mar 2006
Yup the vertical is awesome on this model with the 2W18 setup, really amazed me at how strong it climbs out, hopefully Dale got some good video today.
Old Nov 07, 2011, 05:57 PM
RA-TA-MA-HAT-TA
munce31's Avatar
Joined Feb 2010
Here's a video of the Komet in action. ExtremeRC is at the sticks and i'm the one launching. As you can see it flies really nice. However unlike the prop'd version, this one has a bit more character, as it flies with a nice 'woosh' of the wemotec rather than that high-pitched sound of a 4-5" prop spinning at 30k+ RPM.
A big thanks to ExtremeRC for building and flying it and Baca for the video.
HET Me-163 Komet EDF (3 min 5 sec)
Old Nov 08, 2011, 09:20 AM
Joined Jun 2001
Hi Guys,
I need some help here.
From the picture, it seems like my Komet's inlet duct came slanted resulting in gap between my edf and the inlet duct. Is it okay that I just use a tape to cover the gap?
As for the battery, do you unscrew the edf unit each time you need to swap battery?
Thanks in advance.
Regards,
Arnold
casioppc is offline Find More Posts by casioppc
Old Nov 08, 2011, 10:05 AM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
That's excellent! Got a 50" pss hanging in my room,that cuts a fair turn of speed.Now how's about a wheeled dolly take off from one of you guys building?
Stupot46 is offline Find More Posts by Stupot46
Old Nov 08, 2011, 05:28 PM
Extreme_RC's Avatar
Joined Mar 2006
Originally Posted by casioppc View Post
Hi Guys,
Thanks in advance.
Regards,
Arnold
I would try to heat up the end of the duct carefully and then push the fan in to reshape it and close the gap as much as possible. Or remove the duct and epoxy it back in straight. This is the first one I have seen with a wonky duct, should not have left the factory like that but its a bit late when you are sitting in the workshop with it! Is your dealer local? maybe take it back and see if they can do anything.
Our battery is in permanent, but yes it can be removed quite easily just by undoing the 2 screws holding the fan and sliding the whole assembly back, thats why I set the ESC into the top of the duct, it can all be moved around inside the fuse in one piece.
Old Nov 17, 2011, 09:39 AM
Joined Jun 2001
Thanks for the advise.
Do you guys set both elevons 5-6 mm up as the neutral position according to the manual?
Thanks.
Old Nov 17, 2011, 03:12 PM
Extreme_RC's Avatar
Joined Mar 2006
Only needs 3-4mm of up on the control surfaces to set the reflex correctly, and we actually added 15g of lead into the tail last weekend to move the CG back a little, made a huge difference to the response of the elevator. I believe our CG is now at 90mm.
Old Jan 02, 2012, 01:17 AM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Mine fly's great at 90mm. Ailerons D/R at 60% Exp -60% Elevator D/R at 70% Exp -40% on my Futaba 10CAG. Aileron rolls are excellent, barrel rolls are large at full throttle. Slowly increasing elevator throws. Love this plane.
p901P901 is offline Find More Posts by p901P901
Old Mar 03, 2012, 01:11 PM
SMCLEODVT's Avatar
Southwest Virginia
Joined Nov 2009
anyone got any photos of mounting the servos in the wings if you dont have the mount kit
SMCLEODVT is offline Find More Posts by SMCLEODVT
Sold Don's Wicked EDF Extreme Motor 5400KV skyracer068 Aircraft - Electric - Jets (FS/W) 3 Sep 07, 2011 12:30 PM
Sold KOMET ME163 by Dave's Aircraft Works NIB KIT unclegeorge Aircraft - Fuel - Airplanes (FS/W) 3 May 29, 2011 08:00 AM
ACT Me163 Komet Build n Flite Report with Pics bolkow Foamies (Kits) 13 Jan 16, 2011 06:09 PM
For Sale S&B ME163 Komet docphi Aircraft - Electric - Airplanes (FS/W) 17 Oct 02, 2005 01:47 PM
S&B Me163 Komet movie Peter Young Foamies (Kits) 0 Jul 03, 2005 04:54 PM
