Old Sep 11, 2011, 06:10 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Build Log
Extreme RC's build of the HET ME163 Komet EDF
Well I finally pulled my finger out, and a box out, and started on the little Komet!
I will outline the plans for the bird first, all the parts going into it etc, then get into the build. The basic plan is for a hot 4 cell Komet, a setup that can use a couple of 2200-2600mah 4s packs in parallel, piggy backed on either side of the ducting, or a pair of 3200-4000mah 2s packs in the same spot.
LINK TO HET ME163 KOMET
SETUP:
Wemotec Minifan PRO & ARC2848-1 motor
Platinum PRO 100A 2-6s ESC
SAPAC MSD65M digital MG servos
Perfomance of this fan is 1400 watts and 2kg thrust on the bench.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 11, 2011, 06:19 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Ok first up wings.
I have decided to install some servo cases into the wings, I have a new shipment of parts from HTG and I ordered a few dozen of these servo cases with covers, they are used in the larger gliders and the Sapac MSD65 servo drops in perfectly, Hitec HS65 is the same size.
So first picture shows the hole cut out to the size of the case, the hole needs to be slightly wider, so I cut away a strip towards the LE, IE the thicker part of the wing chord.
Then I sat the trays in the holes and scribed out around either end of the tray in order to open the holes up to the full tray size including the mounting tabs.
Reason for this is I want the trays flush with the wing skin so when the covers are fitted they are flush against the wing.
I then cut some spruce strip, 1/2" wide, 1/8th thick and 50mm long (2") and used a new exacto knife to slice foam out of either end of the cutout exposing the balsa skin.
Epoxy the spruce strips against the underside of the balsa sheeting, do one at a time holding it firmly in place, 5 min epoxy obviously needed here
Once the strips are in the servo tray sits in perfectly, and can be securely screwed to the hard wood.
Covers sit neatly over the top as you can see in the last photo, and can be painted with some Tamiya bright red to match in.
I think the end result is worth the few $$ for the cases, and makes for a neat streamlined instal.
Tomorrow I will sort out the horns and finish off the wings and then prepare them for epoxying to the fuse.
(Apologies for the photos, main light blown in workshop and it was dark outside!)
Old Sep 11, 2011, 06:34 AM
munce31 is offline
Find More Posts by munce31
RA-TA-MA-HAT-TA
munce31's Avatar
Melbourne, Australia.
Joined Feb 2010
Excellent! Looking forward to this build thread, through to the maiden flight. Should be screamer, like the prop'd version
munce31 is offline Find More Posts by munce31
Old Sep 12, 2011, 08:37 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Yes I am interested in this too.
I like those servo cases!
Slaanesh is offline Find More Posts by Slaanesh
Old Sep 12, 2011, 09:06 PM
Spoont is offline
Find More Posts by Spoont
Spoont's Avatar
Australia, New South Wales, Sylvania
Joined Nov 2009
Hi Mark its Shawn,
I have about 30 flights on mine now. Other than a hand launch gone wrong (don't try it) I have had nothing but great flights.
I am running a 2w-18 on 4s with HET FAN and one of your alloy shrouds. Dopplered it yesterday at 161kh (if i got it right) from a rather poor video taken on my phone.
This is one of the most stable planes I have owned (and I have owned a few).
One thing I would recommend to enyone who builds it is to add a contrasting colour to the bottom because the all red does not aid orientation. Also, since my failed hand launch I have used the bungee 100%.
Back to your build.
Spoont is offline Find More Posts by Spoont
Old Sep 13, 2011, 05:12 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Thanks Shawn, nice to hear some feedback, how did you go with your CoG? Another builder in SA had some issue getting the CG forward enough with the same setup as yours, albeit he was using the plastic shroud so a little lighter.
Seems a little slow at 160k though, that setup does 135+mph in the F16, and the komet is not too draggy. If you can get some video up that would be great, and some readings of amps and watts after 20 seconds or so to stabilise.
Sorry guys I have not been able to get back onto it, had a heap of backorder stock come in and there are like 12 fans waiting to be built, my new 2445 motors came in for the GWS 64mm fans and there are half a dozen of those needing to be built and balanced alone, gonna be busy again tomorrow but hoping to finish the wings off and then get them slapped onto the fuse and start planning the layout of the guts.
Old Sep 13, 2011, 05:32 AM
munce31 is offline
RA-TA-MA-HAT-TA
munce31's Avatar
Joined Feb 2010
All good Mark. Its much better to build it once and build it right, rather than rush through it all.
And Spoont.. Love the DP rofl
Old Sep 13, 2011, 05:47 AM
Spoont is offline
Spoont's Avatar
Joined Nov 2009
Mark,
To get the CG right I moved the fan mount forward by 5mm which involved carefully trimming the intake ducting with the dremel. I built a battery box from light ply which is positioned so that i get the CG right every time.
As for the speed, the run was done with a well used pack. I managed to get out again today and this time used one of your race packs. The difference was remarkable.
Looking forward to seeing the results of your build. I am sure this airframe will scream with a power system set up by someone who does it for a living.
Cheers
Old Sep 13, 2011, 05:48 AM
Spoont is offline
Spoont's Avatar
Joined Nov 2009
Hey Munce,
Leave my mum alone....
Old Sep 15, 2011, 03:29 AM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
cant wait to see how this baby flys ive had my 28 48 1 (with heat sink) and wemo from extreme for a few months now and i have to say these ARC motors are fantastic!!
Ive even been very bad too as i run it on 5s 3300 30c in 5 - 6sec bursts and she still didn't get any hotter (don't try in summer maybe) although the hobby king batteries are not up to the job i increased about 200 watts from my eflight 4s 3600 the HK 5s battery dropped a cell after 3 flights.
back to 4s lol, any way the Me163 on arc 28 48 1 has to go hard!!
evo101 is offline Find More Posts by evo101
Old Sep 15, 2011, 05:43 PM
X30PILOT is online now
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
Here are some photos of my ME-163.
Not exactly an EDF this baby uses a 60 pound thrust rocket motor!
X-30
X30PILOT is online now Find More Posts by X30PILOT
Old Sep 15, 2011, 05:59 PM
evo101 is offline
evo101's Avatar
Joined Jun 2009
OMG now thats wild!
Old Sep 15, 2011, 06:07 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Where's the video of that!!!!
Old Sep 16, 2011, 04:19 PM
Ricky2117 is offline
Find More Posts by Ricky2117
United States, CA, Stevenson Ranch
Joined Feb 2008
Where did you get the servo cases?
Ricky2117 is offline Find More Posts by Ricky2117
Old Sep 16, 2011, 10:41 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Ditto! I woud sure like to purchase a dozen.
Pete
hole digger is offline Find More Posts by hole digger
Sold Don's Wicked EDF Extreme Motor 5400KV skyracer068 Aircraft - Electric - Jets (FS/W) 3 Sep 07, 2011 12:30 PM
Sold KOMET ME163 by Dave's Aircraft Works NIB KIT unclegeorge Aircraft - Fuel - Airplanes (FS/W) 3 May 29, 2011 08:00 AM
ACT Me163 Komet Build n Flite Report with Pics bolkow Foamies (Kits) 13 Jan 16, 2011 06:09 PM
For Sale S&B ME163 Komet docphi Aircraft - Electric - Airplanes (FS/W) 17 Oct 02, 2005 01:47 PM
S&B Me163 Komet movie Peter Young Foamies (Kits) 0 Jul 03, 2005 04:54 PM
