Old Sep 10, 2011, 10:20 PM
Swert Pertoto is offline
Find More Posts by Swert Pertoto
Joined Nov 2009
Connecting two batteries with a Y harness will..
double the capacity or voltage?
For example, I connect 2 3s 2200mah batteries with a y harness, will it become a 6s 2200mah or will it become a 3s 4400mah?
Swert Pertoto is offline Find More Posts by Swert Pertoto
Old Sep 10, 2011, 10:36 PM
romeodz is offline
Find More Posts by romeodz
United States, TN, Knoxville
Joined Mar 2005
It depends upon the harness you use?
Series connection is positive terminal from one battery to negative terminal on the other battery. This would be 6S, 2200 mah.
Example - http://www.hobbyking.com/hobbyking/s...Series%5F.html
Parallel connection is both positive battery terminals are connected together and both negative battery terminals are connected together.
This would be 3S, 4400 mah.
Example - http://www.hobbyking.com/hobbyking/s...FParallel.html
romeodz is offline Find More Posts by romeodz
Old Sep 10, 2011, 10:38 PM
Joined Nov 2009
Series connection is positive terminal from one battery to negative terminal on the other battery. This would be 6S, 2200 mah. http://www.hobbyking.com/hobbyking/s...Series%5F.html
This would be 3S, 4400 mah. http://www.hobbyking.com/hobbyking/s...FParallel.html
Awesome, thanks!
Discussion Y harness for connecting 2x 6s lipo mfbs17 Power Systems 9 Jun 13, 2011 07:53 AM
Question parallel Y connecting 2 ESC's, will I burn out my RX StudentCJ Power Systems 16 Mar 23, 2010 07:38 AM
Connecting two Lipos with Y cable yshimoni Power Systems 4 May 03, 2004 03:06 PM
Connecting two battery packs with a y-connector glide Batteries and Chargers 8 Apr 19, 2004 01:46 AM
two Receiver Batteries and Y Servo Harness = Doubled Capacity? Nik-rc Batteries and Chargers 4 Jun 04, 2003 08:43 PM
