Old Sep 10, 2011, 09:34 PM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Help!
Problems with Plettenburg calculations
I have tried a few calcs (with no luck) for the following set-up.
Plettenburg HP 220/25/A1 P6 7:1
Shultz FUT 18.129F
17x18 w/7 degree twist
First of all I don't know how to figure the pitch with the 7 degree twist (guessing around 21 or 22).
Second, The motor/prop calcs don't have this motor on the list as an option.
I am trying to just get some general estimate of what kind of power (amps/watts) a strong 3S...4S...5S ??? would draw...or how many cells it can handle without killing everything. And what kind of numbers can be expected.
Any answers, direction, or help of any kind would be greatly appreciated.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Sep 10, 2011, 10:49 PM
David H is offline
Find More Posts by David H
Joined Aug 2004
As there are 4 17x18 RFMs gold,red,green,blue that I know of, that adds to the problem(this is also the power absorption order). The props with +5,and +7 were supposed to be 18in of pitch on those hubs, but that is not how they measure( 18in could be designed pitch with blades at some angle of attack).
so which prop do you have, I have calculated some N100 for the red and green(RPM for 100 watts).
A Pletti 220/37/A1 P4 7:1(your motor has same Kv) was soft on 4S with the 18x19+7 but with the 18.129 4S might be the limit for this motor controller on 4S with the 17x18.
5S on the 220/37 with 16x17 skinny cooked the motor.
David H is offline Find More Posts by David H
Old Sep 10, 2011, 11:09 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I don't recall what color and don't have the prop on hand to check at the moment.
I never can keep the numbers of all the different motors straight. What's the "37" in the 220/37 and 220/25 mean?
At this point, not knowing the exact prop, it seems that the ESC is the weak link.....not the motor?
What is this motor capable of with the right esc?
So without more info...it seems like....
3S is weak
4S would be better but not great
Does this sound about right?
I'll find out about the prop in the morning.
Thanks so far, Bill
Old Sep 10, 2011, 11:26 PM
David H is offline
Joined Aug 2004
this is the rotor length like the 2nd 2 digits in Neu motors. P6 or P4 is the number of pole so 37/25 x6/4=1 i.e. Kv the same.
4S should be fine and good, the smaller motor will get hot quicker so the 17x18 would be about as big a prop you could safely use on this motor.
Old Sep 10, 2011, 11:34 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
This has all very helpful. At least now I have "some" idea.
Thanks, Bill
Old Sep 11, 2011, 11:39 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I would recommend you try mailing Pletti, they have great guys that can help you out, and also a few team pilots that probably run this or similar setup, so it would surprise me if you dont get the answers you need.
Jocke is offline Find More Posts by Jocke
Old Sep 11, 2011, 01:08 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
That's a very good idea.
Old Sep 12, 2011, 12:40 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
If it makes any difference know...it's the "BLUE" RFM.
Bill
Old Sep 12, 2011, 02:24 AM
David H is offline
Joined Aug 2004
That big wide high current drain prop. I am a little worried about the controller with that, but i don,t know for sure
Old Sep 12, 2011, 07:54 AM
Kenbogunz is offline
Find More Posts by Kenbogunz
Joined Sep 2008
What would be a more conservative prop to use with this ? Would a standard spinner /prop combo be advised?
Kenbogunz is offline Find More Posts by Kenbogunz
Discussion Flying Problems with Gaui Invertible Multirotor Talk 5 Sep 06, 2011 07:57 AM
Discussion Battery calculations split_s Batteries and Chargers 4 Sep 05, 2011 11:33 PM
Discussion Need help with motor/ prop calculations bran713 Power Systems 5 Feb 24, 2006 08:13 AM
Excel spreadsheet helps with calculations jludwick DIY Electronics 0 May 31, 2005 12:16 AM
Max rpm with Plettenburg? WarrenKriesel Power Systems 2 Jan 22, 2004 10:10 AM
