Old Oct 23, 2001, 09:59 PM
Space Coast
Space Coast
Joined Oct 2000
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project.
SteveC has converted a "and now" into a Ultimate Biplane that looks real great. So great that I have to have one. He has posted a drawing on the Pitts thread and I hope he will put it on here. His has about a 27" wingspan....I think I'll try one with a 22" wingspan. He has already flown his version without the foam body and reported that it flies well so if you use his dimensions you know it will work. Mine are always a thrill
So get out your hot wire gun, the exacto blades, and lets start building.
hoppy
hoppy is offline Find More Posts by hoppy
Old Oct 24, 2001, 03:21 PM
jojo's Avatar
belgium
Joined Oct 2001
hey
Hoppy is on the road again for a new challenge
don t forget as the previous one to show us the pics
good luck Hoppy
AJoe
jojo is offline Find More Posts by jojo
Old Oct 24, 2001, 03:33 PM
SteveC's Avatar
So Cal
Joined Sep 2001
Hi guys,
Here is the Ultimate Bipe in progess.
I weighed it and so far the airframe with servos 4.1 oz.
The wings were an experiment for my "and_now" stik, it flew awesome with the stik fuselage.
Steve
Here is a picture of the first stik version;
SteveC is offline Find More Posts by SteveC
Old Oct 24, 2001, 03:44 PM
Rochester, NY, USA
Joined Aug 2000
Steve,
Your 4.1oz measurement is impressive.
Can you list the components you used please?
Greg Covey is online now Find More Posts by Greg Covey
Old Oct 24, 2001, 03:50 PM
SteveC's Avatar
So Cal
Joined Sep 2001
Here is a picture of how it looks so far.
This time I'm using 4 channel, full house control.
Everything is made of Walmart's depron sturdyboard with the paper removed.
I expect it to fly even better than the stik version.
The stick version is using the "lil hornet" mg1 motor/brass tube setup and flew fully aerobatic.
With this one I thought I would step up to a speed 400 for even better aerobatics and maybe get into the foamy scratch built contest.
What do you guys think about the speed 400?
Too much? Too heavy? Just right?
I got the idea from david_dewit of Australia who uses a 400 in his "tiny"
With the MG1 motor and battery I expect it to weight right around 10 oz.
I haven't weighed the speed 400 and battery yet.
Here is how it looks so far:
Old Oct 24, 2001, 04:01 PM
SteveC's Avatar
So Cal
Joined Sep 2001
Greg,
I'm using GWS pico std's for the rudder/elevator and a pico BB for the aileron servo.
If I stick with the MG1 I'll be using a little Greatplanes 5a esc that I love.
I'll be using CC's pixie 14 if I go with my speed 400.
I'll probably be using a stripped down hitec 555 for the receiver.
I have been using a GWS RP4 but the range is too limiting for even the stik version I'm flying.
Steve
Old Oct 24, 2001, 04:23 PM
SteveC's Avatar
So Cal
Joined Sep 2001
I have been asked for plans so I thought I would give it a shot.
I have found a new appreciation and respect for the people who make plans!
So far all I have are a drawing and the dimensions using adobe illustrator.
These are not to scale so if you want to use it you will need to get out a straight edge and pencil and make the patterns using the dimensions given, or try your own.
I'm sure there are much more qualified people than me out there, so any input is greatly appreciated.
There is more wing area than scale and the fuselage width is tapered toward the nose.
The nose is longer than scale, and will likely be shortened, I left it long in case I need to drastically correct the CG.
Here is a screenshot so far:
Old Oct 24, 2001, 04:26 PM
Space Coast
Space Coast
Joined Oct 2000
Now we're C O O K I N
I'm debating on the wing chord.....22x4, 22x5, 22x6?????
That's 8.18, 6.54, and 5.45 oz/sq ft. I think the 6.54oz/sq ft might not be bad. Comments???? Looks like Steve's plane is in the 4oz/sqft range, maybe I'm thinking too small...hmmmmm.
Are there any guidlines for biplane wingspan and chord relationships?? Both the Pitts and Ultimate Biplane have skinny wings in the "real" versions.
hoppy
Old Oct 24, 2001, 10:27 PM
SteveC's Avatar
So Cal
Joined Sep 2001
hey Hoppy, when I click on that link I get a "restricted area" error
Old Oct 24, 2001, 10:32 PM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Hoppy
Your link is to a restricted area.
Steve the ultimate looks great, good job!!!!!!!
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Oct 24, 2001, 10:52 PM
Space Coast
Space Coast
Joined Oct 2000
Thanks for the feedback.....I think the new one will work
The tail feather and wing patterns have been removed because they are being revised to a larger size.
hoppy
Originally posted by buzzsaw 46
Hoppy
Old Oct 24, 2001, 11:02 PM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
hoppy
It now works but says the album is empty
Old Oct 25, 2001, 08:01 AM
Space Coast
Space Coast
Joined Oct 2000
OK, now it's working (I hope). I found the yahoo page that permits it to be viewed by the public.
jojo, can you access this picture file? http://photos.yahoo.com/hoppyfl
Since my home page is maxed out, this is an easy way to post the templates.
hoppy
Old Oct 25, 2001, 03:39 PM
jojo's Avatar
belgium
Joined Oct 2001
no problems Hoppy i can open them
jojo
Old Oct 25, 2001, 03:55 PM
UK
Joined Jan 2001
Steve, is that Windows XP you got there? What do you think of it so far?
(Sorry, I know it's a bit off topic)
Ben C
Ben C is offline Find More Posts by Ben C
FS Depron Little Ultimate Biplane w/motor hotairflyer Aircraft - Electric - Airplanes (FS/W) 0 Apr 18, 2004 04:40 PM
another depron )meat tray foam ) question mhmitchell333 Foamies (Kits) 1 Jan 19, 2003 06:26 PM
PITT'S SPECIAL - A meat tray construction project. hoppy Foamies (Kits) 143 Nov 01, 2002 12:27 PM
Meat tray project shadetreeflyer Foamies (Kits) 14 Oct 10, 2001 05:28 PM
Construction of Meat Tray "Double Fun" hoppy Foamies (Kits) 2 Jun 21, 2001 01:47 PM
