Old Sep 10, 2011, 02:35 PM
bagofbones11 is offline
Find More Posts by bagofbones11
bagofbones11's Avatar
Joined Jul 2010
Has anyone used this foam from the Dollar Tree?
I went to the dollar tree last week to pick up some more foamboard when I saw this black foamboard. I just glanced at it but never really thought much about it.
Today I went to see if I could find it and it wasn't there I asked the manager when they would be in stock and he said "Maybe never" and he gave me the option if I wanted him to order some now and they would be there in about 2 days. I told him ill come back. But yes here is the link: http://www.dollartree.com/catalog/pr...oductId=310686
If anyone has used that foamboard please tell me if its good or not. I don't want to waste $50 on foamboard ill never use.
bagofbones11 is offline Find More Posts by bagofbones11
Old Sep 10, 2011, 06:09 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
The white is better
Wilfor is offline Find More Posts by Wilfor
Old Sep 10, 2011, 11:09 PM
adamdb is offline
Find More Posts by adamdb
United States, CO, Denver
Not sure if it is the same thing I got at my local dollar tree which is the same Adam's brand foamboard, but with black paper rather than white. The foam in the middle is still white. I couldn't see any difference (other than color) between the black and white foamboard.
adamdb is offline Find More Posts by adamdb
Old Sep 20, 2011, 08:44 PM
propjobbill is offline
Find More Posts by propjobbill
propjobbill's Avatar
USA, OH, Oberlin
Redi board is made in a number of colors. Dollar tree mostly sells the white. I bought about 6 or 7 sheet of the black. I have also bought green yellow and red from a craft stor in this area. Once you strip the paper off the foam under the paper is all the same.
If you are going to leave the paper on, you may like it better because it is a different color.
propjobbill is offline Find More Posts by propjobbill
Old Oct 19, 2011, 03:45 PM
ERNtheMAD is offline
Find More Posts by ERNtheMAD
not angry... just crazy
Joined Oct 2011
dollar tree foam board is good for sketching out the plane and cutting. just peal it off after, n good to go.
anyone tried to use CA to harden the wing front or nose? have used it on smaller planes, seems to do ok.
ERNtheMAD is offline Find More Posts by ERNtheMAD
Old Nov 29, 2011, 01:27 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
It is very difficult to remove the paper from the black DT foamboard. This is a disadvantage for building techniques described in http://www.rcgroups.com/forums/showthread.php?t=1504758.
For me, the white is much better, and I can paint it whatever color I want (ever try painting a black surface?)
However, I have built some planes with the black foamboard. It looks cool when you paint the foam edges a different color.
foamflyer is offline Find More Posts by foamflyer
Old Nov 29, 2011, 05:04 PM
USA, OH, Oberlin
I bought some of the black a few months ago and I must agree is doesn't come off good at all. It is hard to take off, and leaves a lot of paper behind which look nasty, black on white,
I tryed painting the black paper and leaving it on. After the paint was dry the paper flexed and began to come off. Of course I have tryed painting the white and it does the same thing. I like leaving the paper on for strength but after a while it comes off. I have covered the foam with silkspan held on with watered down white glue and that worked good. It was much stronger and very little extra weight.
I'm not sure any of the colored paper is better because it does let loose after a period of time and that encludes the white paper. It seems like once the paper has taken on moisture it begins to let go of its grip.
Discussion Can Anyone Explain What Is This Voice What Comes From Motor RcLento Power Systems 14 Sep 08, 2011 02:12 PM
New Product Has anyone used this system? ian murdock Slope 23 Jul 04, 2011 10:15 AM
Discussion A lot of Blucor sheets and white board foam board from dollar tree.. Cdr.Instigator 3D Flying 4 Feb 15, 2011 12:53 AM
Discussion SLUM CAT... From Dollar Tree Foam Board. Revisited! RWCLOUD Foamies (Scratchbuilt) 20 Nov 22, 2010 12:27 AM
Discussion Slope Soarer from Dollar Tree Foam AirmanAirhead Flying Wings 1 Mar 11, 2010 08:48 AM
