Espritmodel.com Heli Air
Old Sep 10, 2011, 06:09 AM
Worcestershire, England
Joined Nov 2007
Turnigy 9X LCD Back light power consumption
Hi folks,
I've fitted a Hobbyking LCD back light to my Turnigy 9X.
I've just left the TX on for 60 minutes to see how much battery consumption was used. It used 1.1 volts.
Not being an electronics man i have no idea if that is good or bad. And i didn't test consumption before fitting the back light!
On the face of it that doesn't seem to bad to me. What do you people out there think?
I want to fully charge my 3s lipo and do the same test again. Then re-charge it and see how many mah were used. However, i want to fit what i think is called an "in-line diode" to reduce the out-put voltage of the lipo first.
Does anyone out there have any knowledge of this??
Jam1e is offline Find More Posts by Jam1e
Old Sep 10, 2011, 07:02 AM
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Here's a thread on it over in radios...
http://www.rcgroups.com/forums/showthread.php?t=1338412
bartricky is offline Find More Posts by bartricky
Old Sep 10, 2011, 11:07 AM
USA, MO, Florissant
Joined Nov 2010
According to Hobbyking, it should draw about 90mA from a 3S battery, so you should see about 90mAH drawn, in addition to what the TX draws, in 60 minutes. If you have a current setting on your voltmeter, it's just a matter of inserting the meter leads in series with on of the two battery wires to get the total current draw: minus from the battery to minus of the TX, for example.
Wintr is offline Find More Posts by Wintr
Old Sep 12, 2011, 12:51 PM
Joined Nov 2007
Charged TX lipo, Left TX on for an hour then recharged it.
It used 397mah!!!
Old Dec 16, 2011, 04:22 AM
B12
Finland
Joined Sep 2010
That is totally false information. The leds have a 470 ohm current limiter resistor in line with the leds so according to ohms law it should be maximum of 21mA on 10V and 25mA on 12V assuming the output is shorted. Something like 15mA measured is reported by some folks.
I will measure it tonight.
B12 is offline Find More Posts by B12
Old Dec 16, 2011, 06:05 AM
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Switches for backlight and beeper
Hey Guys,
Here is a fairly simple mod to add to your 9X to reduce unneeded current draw from your battery. Add a mini toggle switch in series with the power to the backlight panel. Fits just fine in space next to speaker vent slots near top of transmitter. While I was at it I put in a switch to turn off the speaker ( saved my sanity)
Bill
See pic:
Bill Smudge is offline Find More Posts by Bill Smudge
Old Dec 16, 2011, 07:20 PM
USA, MO, Florissant
Joined Nov 2010
I just quoted the listing on HobbyKing's site. Is there only one resistor, or are there a few, operating more than one string? Assuming each string has a 470 ohm resistor, I would guess their numbers indicate three or four strings in parallel.
Old Dec 17, 2011, 04:34 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
The standard 9X on 8 NiMh 2300mAh fully charged will power for over 8 hrs till Low voltage alarm sounds.
I have had over 9hrs ... but I work to 8.
Then that is : 287mA rate per hr. (I'm making it simple by assuming alarm is at lowest nominal voltage and use of total mA capacity ... yes its wrong but practical).
Taking mateys 397mA draw over an hour from his battery ...
397 - 287 = 110mA ... which seems to agree with HK .. OK a touch higher ... but lets put that down to errors in Wattmeter calculation of use .. which is a pure maths figure based on reading batts.
solentlife is offline Find More Posts by solentlife
Old Dec 17, 2011, 04:45 AM
papabearflying's Avatar
Joined Mar 2011
Jam1e Do you fly a lot at night? I canīt imagine why anyone would need backlight? apart from night flying or bad eyesight.
papabearflying is offline Find More Posts by papabearflying
Old Dec 17, 2011, 04:50 AM
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
I have the 9X and it is a bit dim to read sometimes, the contrast in the menu is pretty poor range.
But so far after near a year of use - never needed to look at fitting a BL. Neither the Firmware that people rant on about.
Old Dec 18, 2011, 08:06 AM
B12
Finland
Joined Sep 2010
It is measured now. Total draw of the Turnigy 9x (ER9X) was 135mA backlight on and 120mA backlight off. This was with 9.6V battery voltage.
So 15mA it is, no more, no less.
Old Dec 18, 2011, 08:08 AM
B12
Finland
Joined Sep 2010
It has only one resistor feeding two leds.
Old Dec 18, 2011, 06:59 PM
USA, MO, Florissant
Joined Nov 2010
Then, clearly, it is not the one here: http://www.hobbyking.com/hobbyking/s...dProduct=17129. The rating there is for several sets of LEDs. Not unheard of for the parts to be different from those advertised, though.
Old Dec 19, 2011, 07:44 AM
B12
Finland
Joined Sep 2010
It is the same one but blue color. It has total of two surface mounted leds and one 470ohm surface mount resistor. I kind of know because I have disassembled two backlights for fitting a BS170 mosfet for ER9X control for the light.
Old Dec 26, 2011, 12:26 PM
Joined Sep 2011
And just FYI, different color LED's have very different power consumption, so unless we are comparing same colors, the numbers mean absolutely squat...
Tweety_Bird is offline Find More Posts by Tweety_Bird
Build Log If you have A123/LiFe receiver packs, you WANT this mAh consumption tracker PLD Batteries and Chargers 140 Dec 07, 2011 05:42 PM
Discussion Turnigy 9x + 6ch RX => AIL DIFF ? JMF11 Radios 4 Sep 08, 2011 04:35 PM
Alert DIY Turnigy 9X LCD Backlight Kit CrashingDutchman Radios 10 Mar 26, 2011 10:28 AM
Discussion HELP with Turnigy 9x v2 Radio LCD pablohlq Radios 19 Dec 01, 2010 09:49 AM
Back Light Lcd????? Mr-Tamiya DIY Electronics 7 Apr 02, 2005 03:26 PM
