| Thread Tools |
| This thread is privately moderated by banana hobby, who may elect to delete unwanted replies. |
Irvine, CA
Joined Oct 2001
Sku: Jt1955-05-arf
Hello,
1) What happened to your phone numbers? I have been trying to call sales and nothing. 2) I am trying to place an order for SKU: JT1955-05-ARF, the web site indicated is "In Stock" it has the "Buy Now" enabled, but the drop down indicates the Swiss (and all the rest) all sold out. What is the real status of this plane? Thank you, CB |
In regards to the C-Ratings, what it is is basically telling you the discharge rate of the battery. This tells you how fast a battery can be discharged safely. With higher C ratings, it doesn't hurt much, but it is just a precaution. Now if you go too low with the C ratings, you will either damaged the battery and possibly the ESC. Reason being is that the discharge rate is way to low thus, not releasing enough juice. ESC needs a certain amount of juice to pump the power throughout the aircraft giving it a good flight. Not enough juice --> under power --> electronics overworking itself to distribute the power throughout the aircraft Usually when flying, some pilots see that the aircraft is under power, so what they do is apply more throttle. That's where the ESC will start to burn and overheat. Now i'm not saying that this happen all the time, but once in a while I do see this scenario happen. I also hope this answer you as well jbryan80. ![]() - Nancy |
![]() - Nancy |
You can reach our Customer Service Center via phone at (626) 373 - 2288. Our hours of operations are from Mondays - Fridays 9:00am - 6:00pm PST and is closed between the hour(s) of 1:00pm - 2:00pm PST. In regards to SKU# JT1955-05-ARF, unfortunately, this aircraft is currently unavailable to us with no EDA from the manufacturer. With you being interested in the F-5E, may I also interest you in the SKU# JT2287-04-ARF-red, 4 CH Freewing Red Stinger RC EDF Sport Jet? ![]() - Nancy |
I know what C-Ratings are....but after only a couple sentences you changed your discussion to LOW C-Ratings, & that isn't what was being asked about. The question begs itself, using your words -- "With higher C ratings, it doesn't hurt much, but it is just a precaution. " What "hurts", even if only a little; and it's a "precaution" .... against what? Please understand - batteries don't 'push' their charge onto or into an electrical circuit....they merely supply (IF capable) what's demanded by the circuit. |
Joined Jul 2010
To someone familiar with Ohm's law, it still doesn't make sense. If the current isn't available to be drawn, the voltage drops, and the motor either slows down or doesn't speed up more. If the ESC is too small for the current drawn by the motor, that is what burns up the ESC. A battery still cannot push current into an ESC or motor.
Curiosity
Nope - it's the amperage that 'burns' things up.
Voltage is Electromotive Force (EMF); it supplies the potential for current flow. Amperage is the rate of the current flow; restricted only by circuit resistance and battery capacity. AFA the radio Tx question - you use low-current simply becuz the radio with its low current demands doesn't need high discharge. It's economics, not performance issues. |
Correct, and let me clarify the point I was making with my post above about voltage, although not stated very elegant. We see these post all the time where people think using a higher C rated pack or higher Mah pack than what they have will somehow cause damage.
My point was that those things will not cause damage, but using a higher voltage battery than what the device is designed for will. Thanks for the clarification. |
Colombia, Bogota
Joined Feb 2013
Good day, I´m Andres from Colombia, south America. I just bougth from you the 12 CH BlitzRCWorks Super Hornet FA -18 Fighter RC EDF Jet ARF
Can you please tell me which is the best battery for this airplane, for good flight time and aircraft power? do you have a recomended brand? ans a serious seller? Thank you very much. Big hug from Colombia!! |
| Thread Tools | |
| Alert Banana hobby customer support is THE BEST! They really are pretty amazing. | bluemeane | Banana Hobby | 15 | Aug 27, 2012 01:46 PM |
| Discussion Banana Hobby Customer Support | Banana Hobby CSR | Banana Hobby | 67 | May 14, 2011 07:04 PM |
| Discussion Banana Hobby Customer Support Rotation Update! | banana hobby | Banana Hobby | 34 | Nov 16, 2010 09:08 PM |
| Discussion Official Banana Hobby Support/Questions Thread | banana hobby | Vendor Talk | 121 | May 18, 2010 07:58 PM |
