Old Sep 09, 2011, 04:05 PM
slowstick4ap is offline
Find More Posts by slowstick4ap
United Kingdom, England, Worcester
Joined Dec 2004
Yippee!
Nearly there on the Easy Glider Pro
This is a friend's Easy Glider Pro which I helped him build recently to introduce him to the hobby. We sprayed up the color scheme today and are quite pleased with the results. It was the first time I've used paint and it produced an impressive matte finish in minutes with no iron in sight either!
The engine is an Axi 2808/20 running on 3s 2700mah and it's nearly there with the thrust angle. It was porpoising a lot under any kind of power so the motor was shimmed and things improved but it will need as much again to take advantage of the power.
It's also been set up with spoilers using a Futaba 6EX and a PMIX on the TX (set to 100%). That certainly killed some lift on landing!
With the spoilers reduced to about 30%, and more down thrust on the engine we should we have some usable power and a great plane.
Hope everyone likes the colour scheme!
slowstick4ap is offline Find More Posts by slowstick4ap
Discussion Is there an easy way to use a DX7 RX on multiple planes? chopper320 Electric Plane Talk 8 May 06, 2011 04:13 PM
Discussion Easy Glider Pro Mods wsmorton Sailplane Talk 6 Apr 27, 2011 12:17 PM
Sold Multiplex Easy Glider Pro kit Maybz Aircraft - Electric - Airplanes (FS/W) 3 Apr 05, 2011 05:52 PM
Wanted multiplex easy glider [pro] $80 nib crashtested Aircraft - Sailplanes (FS/W) 7 Mar 21, 2011 10:58 AM
Question Radian Pro vs Easy Glider Pro? tdriedger Electric Sailplanes 1 Mar 09, 2011 04:08 PM
