Old Sep 09, 2011, 02:59 PM
firey1 is offline
Find More Posts by firey1
firey1's Avatar
New Zealand, Canterbury, Temuka
Joined May 2011
Build Log
UH1-B 600 scale Huey
Will be building the UH1-B using the HK 600
I also have a UH1-N 450 size and a MD500E 450 so this is my first big build
The mechanics arrived yesterday and still waiting on the fuselage which is in transit and should arrive next week
The flymentor is a great cheap back up incase of dumb thumb
Flymentor 3D helicopter stabilisation System
Turnigy T600 Brushless Outrunner for 600 Hel with 15 tooth pinion
BMS-661DMG+HS Super Fast Digital Servo (MG) 3 for cyclic
Turnigy dlux Programming Box
Turnigy dlux 100A SBEC Brushless Speed Contr
HK-600GT 3D Electric Helicopter Kit
HobbyKing GA-250 MINI-MEMS Gyro
D50011MG 57.4g / 9.6kg / 0.08sec High Torque for tail
High Quality 600mm Carbon main blade
firey1 is offline Find More Posts by firey1
Old Sep 10, 2011, 07:45 PM
firey1 is offline
firey1's Avatar
Joined May 2011
HK600 build
Almost all done head and tail stripped and greased/ locktighted
Motor and servos installed
last of the electronics to fit when battery and UBEC arrive tommorow
Comments and tips always welcome
Old Sep 13, 2011, 01:17 PM
firey1 is offline
firey1's Avatar
Joined May 2011
Update
All the electrics fitted and tested
But still waiting for the body kit to arrive as it has the 15 tooth pinion with it
certainly alot nicer working on bigger bolts and nuts after the small 450 sizes
Old Sep 13, 2011, 05:17 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
Check the tail rotor assembly good for any play and I would change the front tail rotor drive gear unless you want it to fail in the air , mine did on my HK-600. Also I don't know as I would trust a bird this big to a $9.00 gyro , these things can get pretty evil when they go out of control they're not like a 450 size heli parts and pieces fly alot farther and hit alot harder.
cap231ex is offline Find More Posts by cap231ex
Old Sep 13, 2011, 06:31 PM
firey1 is offline
firey1's Avatar
Joined May 2011
Thanks Cap feed back welcome
Yes I read all about the tail drive problems
double checked all the fault areas on mine when i assembeled it and didnt find any of the stated problems ( maybe i got a gord one ) but did CA glue around the tail drive gear as per some one elses precaution
I didnt even have a problem with my flybar cage
the Gyro I have found that GA250 is way better than the 401 in HH mode
this is for scale not 3d and know that a couple of others have this mounted on there HK600 with same servo and have had no problems
Cheers
Old Sep 13, 2011, 07:34 PM
thenodemaster is offline
Find More Posts by thenodemaster
Mini-Me is watching you...
thenodemaster's Avatar
Hemet, CA
Joined Aug 2010
Found that one out when my Chaos 600 decided it would rather fly on its own instead of listening to me. Got a nice sized hole in the running board panel of my wife's Explorer from where it hit.
thenodemaster is offline Find More Posts by thenodemaster
Old Sep 13, 2011, 09:15 PM
firey1 is offline
firey1's Avatar
Joined May 2011
Yes they are a very big intimading bird thats for sure and glad I have a big sports ground only 2 streets away to fly it
may have to change my car to transport it tho
was looking at the Chaos 600 & the UH1-N fusealage from another company but after almost 3 weeks of waiting for a question on the supply of the fuselage I gave up and went for the HK600 and the UH1-B from centruy-rc
Old Sep 14, 2011, 12:48 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
That is the very reason I fly at the 1300 acre AMA Headquarters with no innocent victims to wound. I once lost a FG blade off of one of my 450 size helis and stuck it through the door panel of a 1978 Chevy pickup truck , that was the end of backyard flying for me. Be safe and look out for others , oh and enjoy the hobby.
Old Sep 14, 2011, 12:55 AM
firey1 is offline
firey1's Avatar
Joined May 2011
Was flying the 450 pro in the md500 one day and the tail rotor snapped in half never did find the half rotor lol
managed to get it back on the ground in one piece but rotor shaft and tail boom bent
Where I live there is no association or flying grounds so yes the area I fly i always make sure there is no one else around
enjoying this hobby got started at xmas with a we honeybee v2
now have 4-450s (one is my sons) honeybee and now the 600
Like the scale flying but son (14) wants to get into the 3d (thats when he gets a job and buy his own parts
Old Sep 14, 2011, 05:49 AM
chris s is offline
Find More Posts by chris s
Mechanical gypsy
Spain
Joined Dec 2006
I like your choice of paint schemes. Look forward to seeing it finished.
C
chris s is offline Find More Posts by chris s
Old Sep 14, 2011, 08:30 AM
Hemet, CA
Joined Aug 2010
I was at the flying field with the club when it happened. It drifted back from the runway and went into the parking lot. Wish there was some sort of barrier, but I am told that it is in the works.
Old Sep 14, 2011, 01:16 PM
firey1 is offline
firey1's Avatar
Joined May 2011
C
Thanks Chris
the Cal fire will test my masking skills thats for sure
Old Sep 14, 2011, 01:59 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
You might think of trying "Bob Dively's Liquid Masking Film" http://www3.towerhobbies.com/cgi-bin...?&I=LXC100&P=0 , I've used it on many project over the years and found it is the best thing to use when you need sharp paint lines.
Here is a link to a build I did using it on a 400 size SeaRanger TH-57C , I think it is around post #12 when the masking film startes. It is very easy to use and can be sprayed or brushed on , I think I used about 3/4 of a 4oz bottle on the SeaRanger project.http://www.rcgroups.com/forums/showthread.php?t=1265015
Old Sep 14, 2011, 06:43 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
Yes, I have found Diveley's masking film to be a must have in painting detailed logos etc on a scale project.
rotoraddict is offline Find More Posts by rotoraddict
Old Sep 14, 2011, 06:44 PM
Joined Jul 2008
+1 on the masking film. I have found Diveley's masking film to be a must have in painting detailed logos etc on a scale project.
For Sale [B]For Sale: - 1/5 Scale L213A Scale Sailplane Hollow Molded 2.7M Wingspan ARF [/B] Fastfiat Aircraft - Sailplanes (FS/W) 0 Jul 04, 2011 09:16 AM
Discussion DJI AceOne flight system 1st scale build- JayHwak, Huey sidneyw Scale Helicopters 13 May 20, 2011 12:17 AM
For Sale [B]For Sale: - 1/5 Scale L213A Scale Sailplane Hollow Molded 2.7M Wingspan ARF [/B] Fastfiat Aircraft - Sailplanes (FS/W) 4 Apr 18, 2011 02:37 PM
Wanted want to buy - UH1 huey apolloman Aircraft - General - Miscellaneous (FS/W) 2 Feb 12, 2009 05:41 PM
Discussion T-REX Huey n(20th Century 1/18th scale body) gunnar18c Mini Helis 91 Mar 15, 2007 04:32 PM
