Old Sep 08, 2011, 05:10 PM
oded mazor is offline
Find More Posts by oded mazor
oded mazor's Avatar
Tel Aviv-Yafo Sde Dov, Israel
Joined Apr 1999
Quad goes crazy when FPV equipment is turned on !
my Quad (FH-X46 / AQ50D board) flies great and very stable.
installed a new FPV system onto the frame - 1.2GHZ 700MW and DX201 camera (no OSD). FPV gear is powered by its own battery.
When the FPV battery is plugged the Quad tilts hard to one side and looses all trimms. still controllable but very different than before. tried with a Hitec FM Rx and the problem persist (also, only when the FPV battery is plugged in).
Any idea what is going on?
oded mazor is offline Find More Posts by oded mazor
Old Sep 08, 2011, 05:19 PM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
This should really be in the FPV thread, What frequency is your rc link operating on? If its 2.4ghz do you have a low pass filter installed? If not you should have. Also you should have your reciever on the quad as far away from the vtx as possible. Can you post a photo of how its mounted? Your vtx may be choking your reciever.
malcr001 is offline Find More Posts by malcr001
Idea You know you like FPV when... saucisse FPV Talk 9 Sep 07, 2011 03:13 PM
Help! 4#6s goes crazy when applying rudder Jonnio Micro Helis 8 Nov 13, 2010 06:22 PM
Discussion FPV test flight video - 36mhz radio goes crazy at 600 meters away :( chancesAU FPV Talk 1 May 07, 2008 11:19 AM
Discussion when i turn on the radio everything goes crazy john-rcg Batteries and Chargers 8 Aug 23, 2006 02:49 AM
Do MGM Compro controllers pull current when they are not turned on? Heli Slime Power Systems 8 Aug 22, 2002 06:19 PM
