Old Jun 29, 2012, 06:53 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
If you look closely there's a small hole drilled in the carbon shroud to get to the grub screws. If I remember correctly 2mm or 5/64" is the correct size.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Jun 29, 2012, 07:24 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
As Arngeir posted there is hole in the shroud for a 2mm allen driver. Make sure you make a small flat on shaft under one of the set screw positions. Then tighten the screws in an alternating series to make sure rotor stays square on the shaft.
Let me know when your ready to fly we can go to either field.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jun 29, 2012, 07:37 AM
KentF is offline
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
Thanks Arngeir and Robert. I didn't see the hole but have not looked that closely. No wonder I have trouble seeing the smaller jets in the air!!
Robert, I'll get ahold of you a little later to setup a time we can meet/fly. My F-4 nose gear crapped out on me a few days ago and I'm waiting for a replacement.
Kent
KentF is offline Find More Posts by KentF
Old Jun 29, 2012, 08:00 AM
Joined Dec 2000
That works for me.
Old Jun 29, 2012, 06:45 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Well....I'm not losing my mind. I did't see any hole for a good reason. My shrowd doesn't have any hole. Anyone see a reason why I shouldn't drill my own? Can anyone that has one tell me how far in from the front of the shrowd is the hole?
Thanks in advance,
Kent
Old Jun 29, 2012, 06:51 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The hole is usually somewhere in the sticker. Drill your own no problem, I would put some masking tape both sides before you drill.
Put a flat steel ruler across the face of the fan then measure down to the motor housing, you ideally want to file a notch in the top edge of the motor tube so that the adapter can drop down as close to the motor as possible.
I would drill my hole around 2mm below the front edge of the motor tube, 3-4mm drill bit gives you enough room to move and if you have a round needle file like a jewellers one, they are usually just under 4mm, you can file a nice semi circle into the side of the motor tube allowing your hex key to reach the set screws while the rotor hub is below the lip of the motor tube.
Interesting to see the fan has conventional mounts towards the rear now.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 29, 2012, 06:55 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Oh, that's odd, I always check the hole, must have slipped thru somehow. The lengthwise position of the hole should be 1mm forward of the front edge of the motor tube, so that when the rotor is on the motor and pushed back there's just enough space to get the Allen key in. Around the shroud, I find having it on the top half over to one side is convenient for access to the grubscrews when it's mounted. Use a 2.5-3mm drill and don't press too hard when it's coming thru because the carbon will splinter.
Stu.
stumax is offline Find More Posts by stumax
Old Jun 29, 2012, 07:04 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Kent
My 80mm was setup by Stu himself he drilled the hole at 28.10mm from the front of the shroud. See pic's
Hope this helps
Thanks in advance,
Kent
BadLemon is offline Find More Posts by BadLemon
Old Jun 29, 2012, 09:25 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Originally Posted by BadLemon View Post
Kent
Hope this helps
That helps a bunch. Thank you.
Kent
Old Jun 29, 2012, 09:28 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Stu.
Thanks Stu. Not a problem. Will make sure to go very easy on the pressure.
Kent
Old Jun 29, 2012, 09:33 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Thanks for the tips. Not sure if the mounts are newer or older. All this talk...I can't wait to get mine fired up.
Kent
Old Jun 30, 2012, 01:25 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
I filed a few of the 90mm ones when doing them and the last batch I received had a triangular notch filed for the hex key to sit in, I filed these round as the hex key catches on the edges otherwise.
Oh and the mounts are newer, they started off as small tabs, 2 each side one front one rear. But the weight is all in the rear once a motor is in, the mounts now look just like the ones I use on my alloy fans and the ones molded into wemo etc housings, much easier to mount in most models too.
Old Jun 30, 2012, 05:41 AM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Kent
The mounts on the 80-45 have always been like this, as this fan was designed to drop straight into a Habu. The 100-45's have been using these mounts ever since the 80-45 came about so I could standardise on the mounting tabs. I much prefer having 4 smaller tabs as the spacing provides a much more stable mounting arrangement, but people seem to prefer the two tabs similar to what all the other EDF manufacturers use.
Stu.
Old Nov 02, 2012, 02:16 AM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Does anyone know what's the recommended ESC settings for the sm80-45 with HET 1785kV and 6S? What is everyone else using? I have a CC ICE LITE 100A. Timing advance low? Frequency 12kHz? Thanks for any help.
Castel101 is offline Find More Posts by Castel101
Old Nov 02, 2012, 09:37 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Yes. My 700-60-935 on 12S runs low timing and 8khz.
You'll get little to no gain from higher timing. And higher frequency will
just heat up the ESC.
Michael Paxton is offline Find More Posts by Michael Paxton
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Power Systems (FS/W) 0 Sep 06, 2011 09:02 AM
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Jets (FS/W) 0 Sep 06, 2011 09:00 AM
Sold Delta-V (R) 32 80mm EDF and BL32 Ducted Fan Motor, 2150Kv New in box beachflyer Aircraft - Electric - Jets (FS/W) 1 Jul 17, 2011 12:08 PM
Found "FAN" 80mm 8 blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Power Systems (FS/W) 2 Aug 20, 2010 02:58 PM
Found "FAN" 80mm 8-blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Jets (FS/W) 0 Aug 17, 2010 01:13 AM
