Old Jun 11, 2012, 10:57 AM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
I have been running my SM 80 in my Habu on 6s 5000 for quite a while now and I love it. Fly 5 min land with 25-35% pack. If I get a 7s pack (just for fun ) will I notice much of a difference in performance? What size cells would fit? I imagine I would get a 3 and 4 s pack of approx 4500 mah. How long are your flight times? Thanks
Husafreak is offline Find More Posts by Husafreak
Old Jun 11, 2012, 05:54 PM
icicles is online now
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
I'm using the same combo, SM80 Habu32. Using the Hobby King 7s 5800mah Compacts. Same weight as my 6000mah Nano. Basically unlimited vertical. When i do a large vertical and when i think it has stopped i put the inputs in for a snap and it snaps so it is still flying. Heaps quicker. And sounds even better too.
I get 5 min flights. But i do push my batteries very hard
Chris
icicles is online now Find More Posts by icicles
Old Jun 12, 2012, 01:34 AM
Husafreak's Avatar
HK 7s 5800, thanks
Old Jun 28, 2012, 07:26 AM
KentF is offline
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
I was hoping someone (and maybe Stu) could answer a question for me. I just bought a SM80-45 from EspritModels (fan only no motor) and I'm trying to establish if I got an older model. The one I received has screw holes to secure the motor in the front but I read that the newer ones use grub screws and secure the motor to the aluminum casing in the rear. Also, the Neu 1509 motor I have (which is 39mm wide) is extremely loose in the case...more than thermal grease can help.
Kent
KentF is offline Find More Posts by KentF
Old Jun 28, 2012, 10:07 AM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Originally Posted by KentF View Post
...... just bought a SM80-45 from EspritModels (fan only no motor) and I'm trying to establish if I got an older model. The one I received has screw holes to secure the motor in the front but I read that the newer ones use grub screws and secure the motor to the aluminum casing in the rear. Also, the Neu 1509 motor I have (which is 39mm wide) is extremely loose in the case...more than thermal grease can help.
Kent
Might do to call or email Stuart directly, he's pretty busy so I'm not sure how often he reads these posts?
stumax@optusnet.com.au
+61 288 194 330
If the fit is the only issue you can wrap the motor case in aluminum HVAC tape to bring the diameter up to a snug slip fit then do the thermal grease thing.
-Mike
Mike Warren is offline Find More Posts by Mike Warren
Old Jun 28, 2012, 10:18 AM
STEVEAIR2 is offline
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
HK 7s 5800, thanks
When you say Hk 7s Compacts
Do you mean Zippy? this is all I can see on the site.
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Jun 28, 2012, 11:10 AM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
+61 288 194 330
-Mike
I've emailed to that address a couple of times but no response. Figured he was a busy guy. I'm most concerned about the fit but I also want to make sure that I have the latest fan unit, everything stays cool and secure. The aluminum HVAC tape is a good tip. I have plenty of that, just need to get some thermal grease.
Stu mentions that the motors are secured with 5 grubscrews in the rear of the aluminum motor enclosure but mine does not have any holes to do this and it looks like the motor is secured by the standard "screws in the front of the motor". I'm currious if anyone has any knowledge of this. My TJ-80 uses the grubscrews method and I thought Stu wrote that the SM80-45 did also.
Thanks for the advice,
Kent
Old Jun 28, 2012, 11:21 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I prefer the forward mounting flanges that he previously used.
My Stumax 90mm has the same style motor tube with the mounting flanges as you have received and works flawlessly.
There is no advantage to the set screw retention method, it is slightly less expensive to manufacture and that was the reason for the change.
Put it together and enjoy it!
Stu will respond to your email.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jun 28, 2012, 12:02 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Good info Robert. Thanks. I've got that warm cozy feeling again
Kent
Old Jun 28, 2012, 12:08 PM
Joined Dec 2000
Just wait to you run and fly that bad boy!
Old Jun 28, 2012, 01:57 PM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Robert,
I notice I'm only a short distance from you. Where do you fly? I'm at Miami Valley RC Club just north of the 275 loop.
Kent
Old Jun 28, 2012, 03:06 PM
Joined Dec 2000
Kent I fly at the GCRCC in Trenton. We should get together some time to fly.
Old Jun 28, 2012, 05:56 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
What you want to know is which batch of blades your rotor was made from, the tabs have been removed since mid last year from memory, so if the fan was built around then it could be from the first batch of blades which is ok, could be from the second which is not. Best to ask esprit if it was a rebuilt rotor from the recall or not.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 29, 2012, 06:29 AM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Robert,
That would be great. You're just a stones throw away.
We don't really have anyone else doing high performance ducted fans at our club right now so it would be great to see what you're doing. Is there a day you normally fly or is it usually last minute?
Kent
Old Jun 29, 2012, 06:31 AM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Thanks for the information. I just got an email from Stu and it's a recent rotor. Now I just have to figure out how to get in there with a wrench to tighten down the 4 grubscrews from the rotor hub to the motor shaft. Advice?
Kent
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Power Systems (FS/W) 0 Sep 06, 2011 09:02 AM
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Jets (FS/W) 0 Sep 06, 2011 09:00 AM
Sold Delta-V (R) 32 80mm EDF and BL32 Ducted Fan Motor, 2150Kv New in box beachflyer Aircraft - Electric - Jets (FS/W) 1 Jul 17, 2011 12:08 PM
Found "FAN" 80mm 8 blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Power Systems (FS/W) 2 Aug 20, 2010 02:58 PM
Found "FAN" 80mm 8-blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Jets (FS/W) 0 Aug 17, 2010 01:13 AM
