Old Nov 21, 2011, 12:16 PM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
Originally Posted by Robert Belluomini View Post
I'll confirm what keithsr stated. At E-Jets I flew the 8S setup and was quite stunned with its performance.
Unlimited vertical and so quiet you could not even hear it with other models.
I used the stock tail pipe.
Anmazing simply amazing performance.
keithsr what batteries are you using?
I'm running Gens Ace batteries, 8s 30c. Not XPS but pretty good batteries.
keithtsr is offline Find More Posts by keithtsr
Old Nov 21, 2011, 02:18 PM
nippaero is offline
Find More Posts by nippaero
nippaero's Avatar
United States, ID, Nampa
Joined Oct 2009
keithtsr,
Thansk for the info! Are you using the reccomended 1485kV HET motor as well for the 8S setup? Do you think a Castle ICE 100 would do the trick?
Also, what kind of flight time are you seeing with this setup?
nippaero is offline Find More Posts by nippaero
Old Nov 21, 2011, 03:20 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
Yes defiantly go with the 1485 motor. Just because I had it, I am running a 160HV castle. Maybe that's a little over kill but better to be safe than using a fire extinguisher! I would at least go with a 120.
I'm no expert but why push your esc to the max, it just doesn't make sense to me.
I flew yesterday for about 3 minutes, mixed throttle and had 63% left in the batteries. I made 4 high speed passes with big loops after the pass. I think if a pilot just flew wide open he/she would have 4 minutes minimum. I think it's not realistic to fly it wide open for a couple reasons. It's nice to stretch the batteries and this thing is deceiving with it's speed. It's so quiet it just doesn't sound like it's going fast but in reality it's moving pretty quick and you need to get off the throttle to make the turns.
Old Nov 21, 2011, 03:27 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I'm using a Hobby Wing 120 Platinum ESC very smooth running ESC. I have it mounted through the bottom of the fuse under the battery tray.
Keithtrs what capacity are your packs. I'm running 3850 TP 65C
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Nov 21, 2011, 03:35 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
I'm running 5300 Gens Ace packs, 30C. I also have my esc mounted under the battery tray but I have the fins sticking out the belly. Did I mention it was better to be safe....than good with a fire extinguisher. lol
I think the Hobby Wing/Turnigy 120 is a good choice.
My oldest son will be in town tonight. He has a stock Habu (converted a heli pilot), I have one with a Stu and one with a TJ 80. I hope to get some video or at least post some numbers.
Old Nov 21, 2011, 03:55 PM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
Do the 5300's fit ok in there? I am currently trying to decide between the Stu and TJ80. Got the $ ready. Just can't make up my mind So I am looking forward to your comparison. Thanks for the info!
Old Nov 21, 2011, 04:06 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
Yes both packs fit...well they do now. I lowered the battery tray down about 3/4 of an inch and stack the batteries.
I have conducted a little comparison in my shop. I'll know more when I finally get the TJ 80 up, retracts have been a problem. The TJ 80 has the 1409 motor installed from Tam, very easy set up, very smooth fan.
Old Nov 21, 2011, 04:25 PM
STEVEAIR2 is online now
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Hi Keithtsr
What retracts did you use?
Cheers
Steve.
STEVEAIR2 is online now Find More Posts by STEVEAIR2
Old Nov 21, 2011, 04:35 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
I just amaze myself sometimes. Sorry Steve, I'll explain in a minute, on the one with the TJ 80, I'm using the Eflite 25-46. On my Stu bird I thought I was using the Eflite 15-25.
A while ago I was in the shop looking for my little Eflites, all I could find was the 15 to 25 size, man I looked everywhere. Well I found them there in the 1st Habu with about 20 landings on them. They still work like a champ. In my defense they do look a like.
Old age sucks!
Old Nov 21, 2011, 05:38 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
I would be very intrested in the results as well
snoshoe62 is offline Find More Posts by snoshoe62
Old Mar 03, 2012, 02:50 PM
delta_kilo is offline
Find More Posts by delta_kilo
United States, WA, Everett
Joined Nov 2011
I have one of these for sale state side that's brand new if any ones interested.
http://www.rcgroups.com/forums/showthread.php?t=1606516
delta_kilo is offline Find More Posts by delta_kilo
Old Jun 10, 2012, 01:52 PM
Dave Grife is online now
Find More Posts by Dave Grife
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
Update,
I'm getting really close to 100 flights on my Habu 32.
First 20 or so were with stock power and Tam struts.
Next 75 or so were with TJ 80 plug n play 1509.
Last 3 were with Stumax plug n play 8 cell set up.
The power seems very similar to the TJ 80, but the Stumax is incredibly quiet.
The airframe in flight seems to make more sound than the Fan/motor.
Thanks Stu, you have a really cool product.
-DG
Dave Grife is online now Find More Posts by Dave Grife
Old Jun 10, 2012, 08:58 PM
Joined Dec 2000
Dave my sentiments exactly! Vertical power is phenominal!
Old Jun 10, 2012, 11:44 PM
icicles is offline
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
Very happy with my 80mm Stumax. 6-7s in my Habu.
7s has heaps of performance and oh so quiet
Chris
icicles is offline Find More Posts by icicles
Old Jun 11, 2012, 02:00 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
I'm getting 9+ lbs of thrust on my 80-45 on 12S. Just a bugger to get it balanced. After it is tho...Nothing better!
Michael Paxton is offline Find More Posts by Michael Paxton
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Power Systems (FS/W) 0 Sep 06, 2011 09:02 AM
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Jets (FS/W) 0 Sep 06, 2011 09:00 AM
Sold Delta-V (R) 32 80mm EDF and BL32 Ducted Fan Motor, 2150Kv New in box beachflyer Aircraft - Electric - Jets (FS/W) 1 Jul 17, 2011 12:08 PM
Found "FAN" 80mm 8 blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Power Systems (FS/W) 2 Aug 20, 2010 02:58 PM
Found "FAN" 80mm 8-blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Jets (FS/W) 0 Aug 17, 2010 01:13 AM
