Old Sep 19, 2011, 05:17 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Originally Posted by tulz43 View Post
Thanks!
Anyone have a recommendation for a brand of thermal grease here in the states?
Radio Shack has it. Don't you have Fry's out there?
Bob
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Sep 19, 2011, 05:40 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Bob
We do. Thanks. I'm going 6s per your recommendation Bob. And I have a 7s pack to try if need be.
tulz43 is offline Find More Posts by tulz43
Old Sep 19, 2011, 07:23 PM
Joined Dec 2000
I'm running zero timing on the motor and the lowest switching freq. This coming weekend ill record some numbers as the packs will have enough cycles by then.
Old Sep 20, 2011, 12:36 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Got my fan. Now, I am experimenting with motor options. I might try this setup in one of my Savex L-39s.
JimDrew is offline Find More Posts by JimDrew
Old Sep 22, 2011, 05:47 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Hi STU,
I have an ARC 36-65-1 just sitting around waiting for a new project. Looking at the E-Flight F-4 too, it's a real beauty and would do this fan justice. Would the ARC motor be suitable for this fan on 6S?
vanderbrander is offline Find More Posts by vanderbrander
Old Sep 22, 2011, 05:50 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Motor tubes are made for 39mm, you would have to sleeve the motor to get it to fit properly, and now with the new motor tubes having no actual motor mounts on them, I dont think it will be possible. The motors are all being held in by set screws now, look at the photos from the back angle you will see set screws just behind the stators.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 22, 2011, 05:59 PM
Joined Nov 2010
Yeah thanks - after reading the first post properly I just realized it's 39mm not 36mm.
Looks like I'll the motor back on the shelf again for a while....
Old Sep 25, 2011, 07:38 PM
Joined Nov 2010
Ok now that I've completely read Stu's post and watched the video, I've got to order one for my E-flight F-4.
The fan is a done deal but the motor I'm having difficulty with - any suggestions or thoughts would really be helpful thanks.
I have a bunch of 4S 4000 packs but I doubt 4000mah will be enough for a +3kw fan setup (with any reasonable flight time that is). I personally don't fly at WOT all the time but three minutes is a bit short for me - I'm just starting to settle the nerves down from the takeoff by then
I also have 5S 4000 so I'd hate to have to go 6S 5000 packs if I can avoid it.
Old Sep 26, 2011, 02:19 PM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Fan and motor is here! Should be able to fly it tomorrow after work.
Old Sep 26, 2011, 04:01 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Ron and I will be there.
gregg f is offline Find More Posts by gregg f
Old Sep 26, 2011, 04:21 PM
Joined Dec 2000
Cool us know how it goes!
Old Sep 27, 2011, 12:45 PM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Does it matter if the thermal compound is silver or ceramic based? I went with the ceramic as it would a good bit cheaper.
Old Sep 27, 2011, 12:52 PM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Bout to order all Components for the upcoming F-4 Phantom from E-Flite.
Just buy the Airframe, build it, fly it, having fun
NS.
neversommer is offline Find More Posts by neversommer
Old Sep 27, 2011, 01:07 PM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
NS.
I don't think you understand my question... it has nothing to do with the plane.
Old Sep 27, 2011, 01:15 PM
Joined Dec 2000
The brand I use is white, Never really looked at the compound makeup.
Hope that helps.
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Power Systems (FS/W) 0 Sep 06, 2011 09:02 AM
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Jets (FS/W) 0 Sep 06, 2011 09:00 AM
Sold Delta-V (R) 32 80mm EDF and BL32 Ducted Fan Motor, 2150Kv New in box beachflyer Aircraft - Electric - Jets (FS/W) 1 Jul 17, 2011 12:08 PM
Found "FAN" 80mm 8 blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Power Systems (FS/W) 2 Aug 20, 2010 02:58 PM
Found "FAN" 80mm 8-blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Jets (FS/W) 0 Aug 17, 2010 01:13 AM
