Old Nov 02, 2012, 10:25 AM
Castel101 is online now
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Cool, thanks Michael.
Castel101 is online now Find More Posts by Castel101
Old Nov 02, 2012, 06:21 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Originally Posted by Castel101 View Post
Does anyone know what's the recommended ESC settings for the sm80-45 with HET 1785kV and 6S? What is everyone else using? I have a CC ICE LITE 100A. Timing advance low? Frequency 12kHz? Thanks for any help.
I've found very little difference between low and mild timing, low is a little bit more efficient, definitely don't use a large advance on timing, that's for outrunners only. 8 and 13kHz works fine. 8kHz is supposedly a little bit more efficient for the esc but I think it will make the motor sound a bit louder if your ears are good enough to pick up those frequencies.
Stu.
stumax is offline Find More Posts by stumax
Old Nov 02, 2012, 06:22 PM
Castel101's Avatar
Joined Sep 2011
Thanks Stu! Might stay with 12kHz then.
Old Nov 02, 2012, 09:42 PM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
I have been flying my Stumax 80 equipped Habu on a 7s GensAce 4400. I mostly fly it on 6s 5000 packs but let me tell ya the difference is not subtle It goes from 88A to 118A and the little Habu just takes off, my unscientific gut feeling is 20% more power and speed, plus an added benefit that I don't understand is it sounds even better. Definitely smoother and whooshier on 7s... More air sound and less motor sound.
Husafreak is offline Find More Posts by Husafreak
Old Nov 02, 2012, 10:23 PM
cquian is online now
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
I have the same setup, and use the CC ICE 100 on 6s, and have been wanting to try 7s. What ESC are using for 7S?
cquian is online now Find More Posts by cquian
Old Nov 03, 2012, 10:52 PM
Husafreak's Avatar
Well, that's a problem isn't it? I had an old HV85 and had to upgrade to an ICE2 HV120 to do the job. Plus since my little blue CC BEC was only good for 6s I had to use a 4 cell Eneloop Rx pack I had on hand to power the Rx. Plus I had to buy a couple of connectors from Progressive RC to make up a special balance connector for the 7 cell pack to my FMA PowerLab8. Hey, in my defense I didn't know all that would be needed until after I bought the 7 cell pack, DOH!
Old Nov 04, 2012, 06:05 AM
RibarSRQ is offline
Find More Posts by RibarSRQ
Roll with the changes...
RibarSRQ's Avatar
United States, FL, Sarasota
Joined Nov 2012
Where can I get one?
I've been searching and can't find this anywhere. I live in Florida and tried Esprit but they are backordered.
Any suggestions?
My Habu 32 is grounded.... need stumax
RibarSRQ is offline Find More Posts by RibarSRQ
Old Nov 04, 2012, 06:17 AM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Any suggestions?
I'm currently building a batch for Esprit and USARCJets. I've been stuck at my real job working very long days for 6 weeks straight without a weekend (today was the first day I haven't gone into work since August), so almost no fan work has been possible. Things are back to normal now, so production will resume and stuff will begin to ship in a few days, 80's probably early next week.
Stu.
Old Nov 04, 2012, 07:28 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Eric does your pack use the xh balance connector
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Nov 04, 2012, 12:35 PM
Husafreak's Avatar
Yes the Gens Ace 4400 mAh pack has the XH style balance connector. I purchased a FMA PowerLab 8 balance cable AC-F8B and Parallel (2x) Balance Adapter for 7s JST-XH AC-PAR2J7 from Progressive RC and soldered them together so the balance cable can plug directly to the PL8. I can post a picture if you want to see it but it is easy. The cost for the cable was 8$. FMA also sells a balance/charge board for up to 8s packs but it is pricey.
Old Nov 05, 2012, 10:31 AM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
I've had real good luck using the old style HV110 on 8S. I mounted the ESC so part of the heatsink is exposed in the airstream because I'm overrunning the current but have dozens of no trouble flights at up to 161mph
MCSGUY is offline Find More Posts by MCSGUY
Old Nov 06, 2012, 06:18 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
So you have the SM80-45 with HET 700-60-1485, Old HV110 on 8S? What size/C rating batteries?
jimmy34256 is offline Find More Posts by jimmy34256
Old Nov 10, 2012, 11:19 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Actually I'm running the 1738kv Het with a pair of 4S TP3850 65C's
Old Nov 16, 2012, 08:56 PM
ellzy_21 is offline
Find More Posts by ellzy_21
United States, TX, Wichita Falls
Joined Nov 2011
Hey Stu,
About to buy the habu 32 and I can't think of anything else I'd want in there but a stumax fan/het combo....I saw that you've been busy with a different job and that you'd be making some more of these soon? Any idea when we might be able to see some of these in the states? Thanks.
ellzy_21 is offline Find More Posts by ellzy_21
Old Nov 16, 2012, 09:15 PM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Originally Posted by ellzy_21 View Post
Hey Stu,
1+....
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Power Systems (FS/W) 0 Sep 06, 2011 09:02 AM
Sold Fury 80mm Fan Shulman 1950Kv for Habu and Align 70 Amp Esc with BEC rcgalore Aircraft - Electric - Jets (FS/W) 0 Sep 06, 2011 09:00 AM
Sold Delta-V (R) 32 80mm EDF and BL32 Ducted Fan Motor, 2150Kv New in box beachflyer Aircraft - Electric - Jets (FS/W) 1 Jul 17, 2011 12:08 PM
Found "FAN" 80mm 8 blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Power Systems (FS/W) 2 Aug 20, 2010 02:58 PM
Found "FAN" 80mm 8-blade fan /hobby lobby scale f-16 sikky Aircraft - Electric - Jets (FS/W) 0 Aug 17, 2010 01:13 AM
