Old Sep 08, 2011, 03:07 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Erics Harrier
Didn't know he was still working on it just last year.
This is the best circuit I have seen of his ship so far. Looks nice and smooth.
Erics RC Harrier 2010 Oct 11 flies one circuit (1 min 24 sec)
RCvertt is offline Find More Posts by RCvertt
Old Sep 08, 2011, 05:33 AM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
woow ... didn't know that either ,,, good find
v22chap is online now Find More Posts by v22chap
Old Sep 08, 2011, 04:40 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Woudn't mind seeing some close up shots of the inside. I still have the model RC article that showed the one he made using the fuselage from Yellow Aircraft. It shows lots of close up shots but you still can't really see how he attached the swivel nozzle joints. Cutting the tops off of aerosol cans that had plastic tops that would spin around fairly easily is the closest I have come to finding something that might work.
I wonder if EDF units would put out equivalent static thrust now. I imagine the duration might not be as long but maybe there is enough for a one circuit test. There would be a lot less vibration with an EDF.
Looks like he is using a lot of CF in the wings and tail. I wonder how much lighter it would be if the fuse was done in CF and foam?
Anyone know how much static thrust he is kicking of that fan? Also wondering how much his motor, fan, and fuel weighs.
Old Sep 08, 2011, 05:41 PM
Brandano is offline
Find More Posts by Brandano
the easiest way, I think, is to just put a shaft centred in the duct around which the outer portion will rotate. It will cause a little drag, but it can be reduced by streamlining. And the model version does not have to deal with hot exhaust gases and bearing leaks that would be disastrous on the full size
Brandano is offline Find More Posts by Brandano
Old Sep 08, 2011, 08:30 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
If it overlaps by two inches or more I suppose that would work.
These turbine/EDF combos are looking interesting as a power source.
This Dynamax system looks like it has some nice thrust numbers for the price. Wish they would give some numbers on how long those thrust numbers can be sustained. 29+ pounds for 2 seconds doesn't do us much good.
Old Sep 11, 2011, 04:30 AM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Here another one I hope is still being worked on. At least the website if fairly recent from last year. Hope all RC Harrier development didn't stop last year.
http://web.archive.org/web/201009250...m/harrier2.php
Looks like they have enough thrust for VTOL. They just need to throw a MultiWii board in it now.
Cool Profile Harrier - Plans and CNC Cut Kits Available! - SGTalon Foamies (Scratchbuilt) 69 May 09, 2012 07:13 AM
For Sale Seagull Harrier 3D 90 LPU MI machineoperato Aircraft - Fuel - Airplanes (FS/W) 0 Sep 03, 2011 09:22 AM
Discussion Jet Harrier de turbina JACOBO VILLALOBO Mexico 2 Jul 13, 2011 01:20 AM
Discussion rolling harrier dialed kygreen229 3D Flying 8 Mar 15, 2011 11:02 PM
