Old Sep 08, 2011, 12:33 AM
PatternFlyer is online now
Find More Posts by PatternFlyer
Frontenac, KS
Joined Jan 2003
Help!
jet screamer 1400 shaft removal.
I need help from someone who had replaced or disassembled Jet Screamer 1400 70mm version.
I need to remove the original shaft off the bell. So far, both set screws are out.
Shaft will not even move at all. I tried heating the bell, but too much heat may cause problem with magnets, so couldn't heat too much.
I've tried hitting the shaft from outside without luck. Don't want to damage the bell as it needs new shaft going in.
Any idea on how to remove the shaft?
PatternFlyer is online now Find More Posts by PatternFlyer
Old Sep 08, 2011, 06:59 AM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
This should help you out:
http://www.maxxprod.com/mpi/tips1.html#Shaft_Reversal
Pete Miller is offline Find More Posts by Pete Miller
Old Sep 08, 2011, 07:55 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Take a longer tubular object, I use deep socket wrench for example, that is large enough to just clear the shaft and put it up inside the housing. That concentrates the pressing forces on the area around the shaft.
Then use a vise, press or even a hammer to force the shaft down through the snug fitting hole. If you use a hammer, put a softer piece of metal on the end of the shaft and strike that, don't strike the shaft directly.
And make sure the housing is not resting on the ends of the magnets or it might break the magnets loose from the housing.
Jack
jackerbes is offline Find More Posts by jackerbes
Sold NIB Jet Screamer 1400 (90mm fans) flanker Aircraft - Electric - Jets (FS/W) 2 May 27, 2010 12:57 PM
Sold 70 mm jet screamer 1400 and wm 400 fan $60 shipped java8297 Aircraft - Electric - Jets (FS/W) 2 Nov 01, 2009 10:58 PM
Wanted Jet Screamer 1400 wanted! craigmel Aircraft - Electric - Power Systems (FS/W) 0 Feb 25, 2009 06:30 PM
For Sale Jet Screamer 1400 + HET 6904 70mm fan Dan Halverson Aircraft - Electric - Power Systems (FS/W) 5 Dec 15, 2008 09:52 PM
Wanted jet screamer 1400 hondaboy92hatch Aircraft - Electric - Power Systems (FS/W) 1 Aug 24, 2008 09:45 AM
