Old Sep 07, 2011, 06:41 PM
quique65 is online now
Find More Posts by quique65
Spain, CT, Barcelona
Joined Jan 2010
Build Log
Genius FP - Xieda GW 9958 mod
Hi,
my last version of the "Walkerized" 9958 project. Can I call it the Genius FP?.
- Walkera RX2605A - Full 2801 TX programming options.
- 2 HK Digital micro servos (1.7g).
- Xtreme parts (head and blades).
- mSR flybar.
- Nano-tech batteries.
Good and resistant trainer for Walkera fans.
quique65 is online now Find More Posts by quique65
Old Sep 08, 2011, 12:26 AM
helimaniac8 is offline
Find More Posts by helimaniac8
United States, CT, Berlin
Joined Jun 2011
Questions questions questions, what was it originally, fp single rotor? What was the original swashplate? Looks like an interesting project I just don't know what you started with
helimaniac8 is offline Find More Posts by helimaniac8
Old Sep 08, 2011, 02:28 AM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Nice! I wanted to try out a similar 9958 mod using Solo Pro or Bravo SX Rx but I found 9958 parts such as rotor blades linkage balls & rotor head to be brittle & easy to break from crashes.
Brosol is offline Find More Posts by Brosol
Old Sep 09, 2011, 10:27 AM
Joined Jan 2010
Hello,
it's a GW Xieda 9958. Follow the links at "Similar Threads" and you will find a lot of information about this heli.
One note about the HK mini servos. You should swap the ground and signal wires in order to connect it to the Walkera RX's.
Old Sep 09, 2011, 10:33 AM
Joined Jan 2010
Hi,
I've found it quite crash resistant (36g with battery).
Old Sep 09, 2011, 07:10 PM
FreakFlow is offline
Find More Posts by FreakFlow
MicroHeliPilot III
FreakFlow's Avatar
Florida
Joined Aug 2010
What is that silver box between the two servos? Would those servos plug into the tiny ar6110 Spektrum RX? this might be fun to make my 9958 bind to my DX6i you use stock battery holder?
what gyro are you using if any? esc for the motor?
FreakFlow is offline Find More Posts by FreakFlow
Old Sep 09, 2011, 08:13 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Nice job.
Could you elaborate on how it flies? I know you said it's more responsive ...but I is it "fun" or "funny" ?
Also, could you link to the servos you used?
Thanks.
Daryoon is offline Find More Posts by Daryoon
Old Sep 10, 2011, 06:15 AM
Joined Jan 2010
Hello,
it's the support for the servos and the RX. I've made it using the metalic plate of a 3 1/2 floppy disk.
The gyro and the connectors for the motors (brushed main and tail) are on the Walkera RX. To use the DX6i I think that your only option is the Blade MSR receiver.
Yes, is the stock battery holder.
Old Sep 10, 2011, 06:17 AM
Joined Jan 2010
Originally Posted by Daryoon View Post
Nice job.
Thanks.
Hi,
I want to say funny. I will upload a video when I have time to do it.
This is the link for the servos:
http://www.hobbyking.com/hobbyking/s...c_0_075kg.html
Old Sep 24, 2011, 03:42 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Thanks quique65.
Any more news or info on how this thing flies? Did outfitting the 9958 with new electronics fix its' tendency to slide during bank turns?
Did you get a chance to record a video?
Saw that it's about 36g with battery after the mod.
Thanks!
Old Sep 30, 2011, 03:27 PM
Joined Jan 2010
Thanks quique65.
Thanks!
Hello,
I've updated the thread. I'm searching how to upload a video...
Old Sep 30, 2011, 05:55 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Thank you for the update. Can't wait to see the video.
I assume the RX2605A has a gyro built in?
Old Oct 01, 2011, 06:17 AM
Joined Jan 2010
Hello,
the small video is in the video gallery.
http://www.rcgroups.com/forums/showthread.php?t=1515060
Yes, the 2605A is a six channel rx with gyro. It's the original rx of the Walkera 4G3.
Old Oct 02, 2011, 12:57 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Thanks for that. When you can, I'd love to see some fast forward flight with banked turns.
Old Oct 02, 2011, 07:26 AM
Joined Jan 2010
Hi,
sorry but I'm a beginner flying at home. FFF it's too much for me and for my available flying field as you can see in the video. I have two Walkera helis (CB100 and V120D02) and I've made this mod to continue learning using the Walkera TX but with less breakage. I hope to shoot that video one day...
In my opinion, the pros of this conversion are (if you have a Walkera 2801 TX):
- similar weight
- better servos, more possibilities of reglage
- RX fully programable with pots for mixing (tail motor speed) and servo travel adjust
- Pro TX: access to subtrim, servo travel, curves, dual rates, expo and gyro sens
From my beginner point of view (hovering, basic movements) the heli is more reactive to the sticks and more controlable.
Regards.
New Product GW Xieda 9958 Frank_fjs Micro Helis 7500 Jan 06, 2015 12:20 PM
Mini-Review GW Xieda 9958 - Review Frank_fjs Micro Helis 10 Nov 24, 2011 10:38 AM
Discussion GW Xieda 9958 TX, Use Another BNF? MrC4FF Micro Helis 4 Aug 24, 2011 02:21 AM
GW Extra 330 and Yak Foam Fly by gw-ezone part 2 Martin Hunter 3D Flying 293 Nov 18, 2006 06:27 PM
New receivers GW/R-4PII and GW/R-6NII sheerLuck Radios 0 Oct 22, 2003 06:06 PM
