Old Sep 07, 2011, 02:12 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Build Log
Precision Aerobatics Addiction X: "Burned Retina" Night Flyer
Well...
I have been putting a lot of effort into my Addiction-X and thought this may be the most appropriate venue for me to show it off
Here is the backstory:
I was out flying the X at my local club field after our annual "Warbird Fun-Fly"... I was hucking it around, and did not land when I heard my timer go off. Instead I flew for another 1:45 of hard 3d and hovering, before taking it back up to altitude for a blender.
This is where things got dicey After several rotations of flat spins, I neutralized controls, continued my down-line, and as I applied throttle and pulled back on elevator... my battery hit LVC! The nose pitched up but the plane took an elevator ride straight into the trees
Damage was so extensive, it required I completely remove the covering to properly address all the damage. One wing was broken beyond my repair skill level, but I was lucky the fuse and one wing were easily mended back together.
So I figured while I have the covering off, I may as well LIGHT IT UP
Yikes, so here I am near 350+ LEDs, and over 50 feet of wire later, things are starting to come together.
I will try to catch you all up with photos from my build/rebuild. At the time I write this I have completed installation of LEDs in the fuse, tail surfaces and stab, both ele and rud control surfaces, one wing and one aileron.
The one completed wing has 182 LEDs installed, Green with red on the wingtips and aileron control surfaces.
The fuse is broken into several colors:
Fuse and motor mount~Blue
Turtledeck, Rudder, Horizontal Stab~ White
Elevator~red
I have not begun covering anything yet, but plan on going with white covering over the top and transparent red on the bottom side.
There were several tricky areas: hinging the wiring through the control surface in the rudder and on the ailerons keeps all wiring neat and internal withing the frame. Keeping all of the wiring out of the way of the pull-pull cables. Connecting 5 different strands of wires (one for each horizontal stab, one for each elevator half, and one for rudder) together underneath the vertical stab. As for the difficult areas to reach (like in the leading edge of the wing), I was unable to wire the LEDs one at a time and ended up making long daisy chains before installing all the LEDs at once.
The finished product will have approximately 500 LEDs total and I have built out two options for lighting power: run off the 3s flight battery with diminished flight times, or I have also built a separate tray to hold a 400mAh battery for the lights above the motor mount and under the cowl. I am undecided for now, but will likely run off the flight battery for initial flights so that I may save some weight somewhere.
Anyway, enough jibber jabber, here are some pics!
...and a short vid:
Addiction X Lights Part 1 (2 min 32 sec)
(At the time of this video, I had not yet wired the aileron control surface; I will try to get an updated video up later this week)
Vapor Trails is offline Find More Posts by Vapor Trails
Old Sep 08, 2011, 06:41 AM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
I must conclude, from the evidence you have submitted, that :
a. you are a major stakeholder in an LED factory
b. you are an LED fetishist
c. you are clinically insane
All joking aside, that is quite impressive, the original airframe build too.
BTW I have looked long and hard and think you may have missed a bit.
electrotor is offline Find More Posts by electrotor
Old Sep 08, 2011, 09:34 AM
USA, GA, Atlanta
Joined Nov 2008
Thanks man! I think I am answers "B" and "C"
It has been a long process, the rebuild was tedious. The light installation was fun at first, then I got completely carried away... I kinda dread having to do an entire 2nd wing! It was painstakingly slow to get all my wiring the right lengths before installing the daisy chain of lights.
We do have a night fly at the club in 9 days and I would love to take it up for a re-maiden then; but I am skeptical I have the time to put towards it. I will keep posting up some new updates after the 2nd wing's lights are installed and will continue to update as the covering goes on... I am really hoping the white covering will reflect the lights well on 3s, but only one way to find out; if it doesn't I am covering in a transparent film.
Latest blog entry: Dayum Fine Custom Pilot
Old Sep 08, 2011, 02:36 PM
ctrout is offline
Find More Posts by ctrout
Waiting for the paint to dry.
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
Looking Good.
Something from my past. The bulbs will show more as lit dots in a thin film but will glow in a high solids color covering.
The dots can make a clear view of the plane a hand full to see
Look forward to your flight video.
trout
ctrout is offline Find More Posts by ctrout
Old Sep 08, 2011, 02:50 PM
USA, GA, Atlanta
Joined Nov 2008
thanks trout, I am really going for the "glow" look; I have been a bit concerned about the glare of transparent films...
BTW~ You have some fantastic night fliers in your stable! I was just going through some of your attachments that you have posted and they look great!
Old Sep 08, 2011, 11:19 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
That looks great Brad!
David Hogue is offline Find More Posts by David Hogue
Old Sep 09, 2011, 10:07 AM
USA, GA, Atlanta
Joined Nov 2008
Thanks David!
Quick question for all yall: What should I name her?
I was going with "Night-X" for a while, after plugging them in last night I am kinda leaning towards "Burned Retina"...
Your creativity and input is much appreciated
BTW~ I have done an official, up to date "LED count" last night and the conclusion was that if I use the same number of lights in wing#2 as I did on the first wing, I will have a total of 501 LEDs, 167 individual strips of 3 LEDs each.
Old Sep 09, 2011, 02:55 PM
Can Do is offline
Find More Posts by Can Do
California
Joined Nov 2003
Burned Retina works! BTW, if the covering has a clear backing, temporarily tape some scrap pieces on the wing, fuse, etc to see how it looks before you make things permanent. I also like the opaque covering better than the transparent, it makes a better projection screen. Good luck!
Can Do is offline Find More Posts by Can Do
Old Sep 16, 2011, 10:33 AM
USA, GA, Atlanta
Joined Nov 2008
Well I started wiring the second wing last night... no new pics yet.
I did not make much process, I installed all the red LEDs on the wingtip and almost finished installing the red LEDs on the aileron control surface.
I have hit a roadblock though as I am nearly out of Green LEDs
Old Sep 16, 2011, 04:56 PM
ctrout is offline
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
I'm waiting on the re-stock myself.
sitting stuck lol.
Old Sep 22, 2011, 10:42 PM
USA, GA, Atlanta
Joined Nov 2008
Yea!!! just got an email LEDs at HK have been restocked
I expect I should get an email in the next 24 hrs that my backorder has been fulfilled
This means my flashlight-build is back on track! I really want to fly this before X-mas...
Old Sep 22, 2011, 11:00 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
It's going to be Awesome!
ViperZ is offline Find More Posts by ViperZ
Old Sep 25, 2011, 05:16 PM
ctrout is offline
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
Looking forword to the video GL-
Old Sep 25, 2011, 11:11 PM
USA, GA, Atlanta
Joined Nov 2008
Thanks Fellas!
Looks LEDs have been shipped... just plaing the waiting game...
New Product Precision Aerobatics Addiction X rcbirk21 3D Flying 235 Sep 01, 2014 07:10 AM
Sold Precision Aerobatics Addiction X Power System...Price Lowered RCMC Aircraft - Electric - Power Systems (FS/W) 3 Mar 17, 2012 10:44 AM
Wanted WTB Precision Aerobatics Addiction or Addiction X lkk_299 Aircraft - Electric - Airplanes (FS/W) 4 Jul 26, 2011 02:47 PM
Sold Precision Aerobatics Addiction PNP Chopper1 Aircraft - Electric - Airplanes (FS/W) 2 Jun 01, 2011 04:25 PM
