Old Sep 07, 2011, 12:30 PM
RcLento is offline
Find More Posts by RcLento
Joined Jul 2011
Can Anyone Explain What Is This Voice What Comes From Motor
Do you know what is this noise ?
Is it because of esc or rx or battery,...
Noise comes from motor but i am sure its not problem of motor ! i also changed esc but still same voice comes. ???
RcLento is offline Find More Posts by RcLento
Old Sep 07, 2011, 01:25 PM
Innov8tive is offline
Find More Posts by Innov8tive
Innov8tive's Avatar
Joined Jan 2007
Sounds perfectly normal to me. What "Noise" are you referring too?
Innov8tive is offline Find More Posts by Innov8tive
Site Sponsor
Old Sep 07, 2011, 02:19 PM
RcLento is offline
Joined Jul 2011
Sounds like friction,have used same motor many times,only on that one happens !
Old Sep 07, 2011, 02:22 PM
RcLento is offline
Joined Jul 2011
Noise sometimes goes sometimes comes,it also affects motor power ! its not fast !
Old Sep 07, 2011, 09:50 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Can Anyone Explain Why Some People Consider It Necessary To Use 24 Question Marks
...when one would be plenty?
Harry D is offline Find More Posts by Harry D
Old Sep 07, 2011, 10:37 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
For emphasis!!!!!!!!!!!!!!!!!!
Seriously, everything sounded normal to me also.
Does your motor have a partial shaft sticking out the back and maybe rubbing the firewall?
aeronca52 is offline Find More Posts by aeronca52
Old Sep 08, 2011, 02:21 AM
RcLento is offline
Joined Jul 2011
i found the reason,the result is strange !
HALF OF THE NEGATIVE CABLE WHAT GOES TO CONNECTOR IS BROKEN AND LITTLE BIT WIRE HOLDING CONNECTOR,SO IT WASNT HAVING WHAT NEEDED THATS WHY THAT VOICE CAME,SOLDERED AND NO PROBLEM :-)
Old Sep 08, 2011, 06:27 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
RcLento glad you found the problem, but were you talking about the change in rpm? I thought you were doing that with your transmitter.
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 08, 2011, 07:48 AM
RcLento is offline
Joined Jul 2011
Soon i will upload a video of normal voice of my brushless !
Old Sep 08, 2011, 07:50 AM
RcLento is offline
Joined Jul 2011
Azarr
Yes also from trasmitter but it wasnt from transmitter,problem was wire what goes motor !
Old Sep 08, 2011, 08:03 AM
RcLento is offline
Joined Jul 2011
Here is the video after found out the problem !
Old Sep 08, 2011, 09:06 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Sounds good now, what plane is that? Looks interesting.
Azarr
Old Sep 08, 2011, 09:26 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
For what it is worth - each of those three carries current the same --- there is no "negative" wire in the brushless system.
JimNM is offline Find More Posts by JimNM
Old Sep 08, 2011, 11:07 AM
RcLento is offline
Joined Jul 2011
agree !
Old Sep 08, 2011, 02:12 PM
RcLento is offline
Joined Jul 2011
Azarr
Hi !
This plane is a sea plane
Wanted can anyone tell me what plane this is happybird Aircraft - Electric - Airplanes (FS/W) 6 Aug 10, 2011 07:11 PM
Help! Can anyone tell me where to buy this switch from? Aero Andy DIY Electronics 6 May 19, 2011 01:01 PM
Discussion Can somebody explain this to me in English please? raythomas Glow to Electric Conversions 6 Apr 26, 2011 12:17 AM
Discussion can anyone identify this outrunner EDF motor? for 90mm fan. Warhead 1850kv motor? cleansho93 Electric Ducted Fan Jet Talk 2 Mar 18, 2011 01:56 AM
