Old Sep 07, 2011, 09:13 AM
toutoune06 is offline
Find More Posts by toutoune06
toutoune06's Avatar
France, PACA, Roquebillière
Joined Jan 2011
th9x down (burned)
Hello! Today I made a mistake in my connection my radio lipo th9x burned . I removed the radio to see the damage and noticed that an item has exploded. Here is the photo:
Radio goes blank when I turn on. and you thought it possible to repair? or your can find a replacement board? if it impossible to repair and I sell it for parts.
thank you for your help
toutoune06 is offline Find More Posts by toutoune06
Old Sep 07, 2011, 09:24 AM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Reverse polarity warning
I burned 9X same way. Used two pin plug instead of original 3 pin plug and plugged it on wrong side.
9X has 3 pin socket wired in -+- so if 2 pin plug is inserted on wrong side, it result in reverse polarity. 9X should have left one side terminal open instead of grounding. If you use the original 3 pin plug with + in center, it never happens. Must use the original plug.
I posted this warning on several related threads so all 9X users be aware.
When 9X burns, it usually damage voltage control diode and one capacitor. In my case, fine line ciruit burned as well. I sold it for parts.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Sep 07, 2011, 10:00 AM
toutoune06's Avatar
Joined Jan 2011
yes I know exactly what happen!
so there is no solution either by replacing the radio?
the board can not find this one?
Discussion Now that LoneStar has burned down scrubs Scale Kit/Scratch Built 6 Nov 29, 2007 09:22 PM
Question Our flying Field almost burned down, would a Fuse have prevented the fire? dogon1013 Power Systems 0 Mar 02, 2007 12:18 PM
Burned down house: The aerial sortie that wasn't eBird Aerial Photography 6 Jun 13, 2004 07:09 PM
109D almost burned down our house!!! hoverkid87 Batteries and Chargers 91 Apr 21, 2004 09:12 AM
