Old Sep 06, 2011, 07:29 PM
kap64 is offline
Find More Posts by kap64
NC
Joined Dec 2002
T-Rex 600E pro servo install question
Hello all, making my conversion over to helos from boats and trucks. I just bought a T-rex 600E pro kit to compliment a highly modified nitro pro I bought from a friend of mine (still haven't flown due to learning to fly). A question on servo installation and more specifically, the elevator servo in the metal mounting bracket. All of the Align servos have a small ridge between the mounting screw holes, so the screws and servo plate do not sit flush on the servo ears, there is a small gap. Is this right? It doesn't seem to move, but it just doesn't look right. Then it tells me to use machine screws on the outside of the metal frame and self tapping screws on the inside of the same metal servo frame. Both sides have machined threads, so why would it tell me to put self tapping screws? It gives me enough machine screws to go around. I broke out the nitro pro and it's nothing like the electric. Thanks.
kap64 is offline Find More Posts by kap64
Old Sep 06, 2011, 10:10 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
First, the screw you need to mount the servo into the metal servo mount is not self tapping but rather the socket button head screw.
Finally, to get the servo plate to sit flat against the servo, you either: (1) cut away the "small ridge," or (2) enlarge the cut out in the servo plate. Most of us just trim away the ridge.
chopper62 is offline Find More Posts by chopper62
Old Sep 06, 2011, 10:41 PM
Druss is offline
Find More Posts by Druss
Canada, AB, Edmonton
Joined May 2008
Aren't there rubber mounting grommets for the servo?
Druss is offline Find More Posts by Druss
Old Sep 06, 2011, 11:04 PM
Joined Apr 2008
I think he forgot to use the servo grommets.
Old Sep 07, 2011, 06:46 PM
kap64 is offline
NC
Joined Dec 2002
I used them, just thought it looked weird. I reseated the servo plates and it looks better.
Sold **Align T-REX 600E Pro/700E T-plug Serial Adapter*** Rudderman98 Aircraft - Electric - Helis (FS/W) 1 Jun 12, 2011 10:07 PM
Build Log T-REX 600E PRO Assembly Step fung Large Electric Helis 3 Jun 10, 2011 02:42 PM
New Product New T-Rex 600E PRO at AlignTrexStore.com IN STOCK AlignTrexStore Hot Online Deals 1 May 19, 2011 07:21 PM
Sold Neu 1515/2.5D/FBrushless Motor For T-Rex 600E For Sale Super D Aircraft - Electric - Helis (FS/W) 0 May 03, 2011 02:16 PM
