Old Sep 06, 2011, 07:18 PM
gatorlynch is offline
Find More Posts by gatorlynch
gatorlynch's Avatar
United States, FL, Sarasota
Joined Mar 2010
Das Plas-Stick (DPS) - E version
This is a 75% scale of a DPS. The WS is 36".
I have had a partially built DPS (fuse only) hanging in my workroom for over a year - just can't seem to get away from the electrics to get this going. So, I decided to try an electric version.
The fuse is 4mm coro in lieu of gutter pipe. It's 2" square, 5 sided. The firewall & nose gear is something I had lying around from an EPS Sapac T-34. If it doesn't hold up, I'll go with a HDPE firewall & mount the nose gear to the backside. The nosegear is fixed - hopefully I can steer on the ground using rudder.
The rest of the plane is pretty standard from the DPS plans.
I'm using a 2830-11 400 sized motor with a 9" GWS prop - That's what I had lying around. Battery is a 1300 mah 3S.
She is a bit on the hefty side - I was hoping for 24-26 oz. & she came in at 29 oz. AUW. I think the motor/prop should be OK - barely.
As they say, there's only 1 way to find out .......
gatorlynch is offline Find More Posts by gatorlynch
Old Sep 07, 2011, 02:33 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Looks pretty good. Yes you are correct, there is only way to find out if it flies or not.
earlwb is offline Find More Posts by earlwb
Old Sep 07, 2011, 09:20 PM
gatorlynch's Avatar
Joined Mar 2010
Well, she flies - and pretty good at that!
The power is adequate - she just won't be doing any long vertical climbs. I'm going to try a 3 blade prop for hopefully a bit more thrust - I think the motor can handle it.
The wing develops a lot of lift. My other SPAD builds have used the KFm wing, so this is a noticeable difference.
My second-hand nose gear broke after my second return to earth (I can't in good conscience call them landings ...) - so I flew the rest of the day as a tail dragger. I'll be moving the gear forward and keeping her this way.
She is very pitchy, but I'm sure I can get her dialed in - just need to dummy down the elevator throws some, and add lots of expo.
Das Plas-Stick (DPS) SPAD - maiden flights (2 min 35 sec)
Old Sep 09, 2011, 05:50 AM
rockyabq is offline
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined May 2008
Very nice! Especially after you dialed back the control surface throws.
rockyabq is offline Find More Posts by rockyabq
Old Sep 14, 2011, 03:19 PM
gatorlynch's Avatar
Joined Mar 2010
My mini DPS has now been converted to conventional gear, after the nose gear broke off. The gear is just at the wing LE.
I needed to put just over 1 oz. of lead in the nose - which I hate doing. I'm going to see if I can shift the wing to avoid the lead.
I tried a 9X5 3 blade GWS, but decided the original 9X5 2 blade performed better. I might try a 10X6 next time - I think the motor will handle it.
Das Plas-Stick (DPS) SPAD - tail dragger (1 min 59 sec)
Old Oct 13, 2011, 01:20 PM
jib is offline
jib
Find More Posts by jib
jib
Chief Mechanic for my son
Covington, WA
Joined Oct 2008
gl - My full sized one is a tail dragger. Think about it next time. It's simpler.
jib is offline Find More Posts by jib
Old Oct 21, 2011, 12:25 PM
gatorlynch's Avatar
Joined Mar 2010
Night Ops
I have added LED's for night flying.
In the wing, I attached a strip of white to the forward side of the wing spar. This gives a nice glowing effect - really nice white on top & the red on the underside is also pretty good.
For the wingtips, I soldered a 3 light segment of Blue & Orange/Amber, to give me some visual orientation. I cut out a little piece (1"X3") of the red wing bottom & covered the holes clear packing tape. This really lets the true colors of the light shine out on the bottom.
The tail feathers simply have some white lights on the vertical fin & the open underside of the fuse.
Old Jan 07, 2012, 04:39 PM
gatorlynch's Avatar
Joined Mar 2010
Got Bomb ?
I have changed out the motor to a 450 size. She flies much better with the additional power.
I also added the Quanum Bomb Drop System to her. With my tallish gear, there is enough room underneath for ground clearance.
Bomb on a Stick, RC Style, Tree Landing & SR-71 Sighting (1 min 40 sec)
Old Jan 16, 2012, 04:55 AM
gatorlynch's Avatar
Joined Mar 2010
More bombing and some combat action
Quanum Bomb with Streamer (2 min 33 sec)
Das Plas-Stick vs Yellow Plane - RC Combat (3 min 19 sec)
Old Feb 07, 2012, 10:13 AM
gatorlynch's Avatar
Joined Mar 2010
Parachute Drop
Dropping a Military Flare Parachute with a tennis ball glued to the end.
The chute is about 36" diameter & packs inside a little pouch. The pouch is tied off to the plane & a simple servo/rubber band release mechanism allows gravity to do its' thing.
RC Parachute Drop (0 min 32 sec)
Old Feb 18, 2012, 01:10 AM
gatorlynch's Avatar
Joined Mar 2010
Parachute Bomb Drop Challenge
To spice things up a bit, in lieu of a simple parachute release .....
Parachute Drop & Catch Challenge (2 min 58 sec)
Old Feb 28, 2012, 04:14 PM
gatorlynch's Avatar
Joined Mar 2010
Mid-Air Colision during aerial combat with a ParkzoneT-28.
The T-28 was basically totaled & I needed to reposition my rubber bands .....
RC Mid-Air Collision (1 min 49 sec)
Old Feb 28, 2012, 09:29 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Wow, that's awesome that your plane flew that well with the wing that crooked! LOL Awesome video. The T28's kinda like bringing a knife to a gun fight, eh?
JohnsPop is offline Find More Posts by JohnsPop
Help! E-flite Mini Ultra Stick vs Mini Pulse XT vs Mini Funtana X vs Extra 260 3D 480 mediclavina Sport Planes 11 Oct 18, 2012 06:57 PM
Sold Thunder Tiger Mini Titan Version 2 (REDUCED) FNFAL Aircraft - Electric - Helis (FS/W) 3 Aug 20, 2011 07:40 AM
Wanted E-Flight Mini Pulse, Mini Ultra Stick, or PZ Extra 300 dlfcci Aircraft - General - Miscellaneous (FS/W) 2 Apr 21, 2011 10:30 AM
Discussion Urgent Choosing Between A Rtf Version Of Mini Titan Or The Rtf Blade 400 E-flite ? FedericoA Mini Helis 9 Jan 22, 2009 01:07 PM
