Old Sep 06, 2011, 11:35 AM
ServoCity is offline
Find More Posts by ServoCity
ServoCity's Avatar
United States, KS, Winfield
Joined Jun 2011
FAQ
NiCAD vs. NiMH Batteries
Choosing the correct battery for your application is critical. When making this decision you may need to ask yourself the following questions:
1. How much room do I have?
2. How much weight can my application handle?
3. How many amps will I be using under full load?
4. How much “run-time” do I need?
5. How fast do I need to recharge?
NiCD (Nickel-Cadmium) and NiMH (Nickel-Metal Hydride) are two very different types of batteries. Both types must be handled differently from one another in regards to charging and discharging procedures and philosophies.
In general, NiMH batteries cannot handle the high rate of charges or discharges (typically over 1.5-2 amps) that NiCAD batteries can. Many modelers use high rate, peak detection or time-based chargers to charge NiCAD batteries. Such chargers are NOT recommended for NiMH batteries (unless otherwise specified in the charger or battery literature) as they can cause permanent damage to the NiMH cells. Also, NiMH batteries will not perform well in high rate discharge applications, typically providing only a small fraction of the rated capacity in these instances.
NiMH batteries also have approximately twice the self-discharge rate of NiCAD batteries when in an used state. For example, when your radio is off, a 1650mah NiMH battery can discharge itself nearly twice as quickly as a NiCAD battery, typically within one week. Therefore, you must charge your NiMH batteries the night before each use.
When handled correctly though, NIMH batteries can be very beneficial, providing much longer run times than comparably sized and weighted NiCAD batteries.
We highly recommend NiMH batteries in applications that call for long duration but not a high amp load. If you have an aircraft with very large servos that pull a lot of amps or more than 8 standard servos we recommend using NiCAD batteries for the best results.
At ServoCity we have a large selection of both NiCAD and NiMH Batteries - as well as all kinds of great battery accessories (switches, power supplies, connectors, battery wire, chargers, monitors, and much more!).
To view our batteries and accessories, click here.
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
Discussion NiCad charger for NiMH batteries Raycamaro Batteries and Chargers 1 Aug 13, 2011 12:54 PM
For Sale Imax B5 Charger (Lipos/Nicad/Nimh) New with Everthing! hcsk8ter Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 01, 2011 08:09 PM
Sold GWS NiMH/NiCad charger w/nimh batteries and Venom Lipo Balace Charger for Sale SFGuy Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 22, 2010 09:49 PM
NiMH vs. NiCad vs. Lipoly degradation rate Nowell York Batteries and Chargers 1 Apr 02, 2003 03:16 PM
Nicad/Nimh vs. LiIon/LiPoly?? Do I even need a Nicad/Nimh charger? duganderson Batteries and Chargers 1 Feb 02, 2003 05:36 PM
