Old Dec 08, 2012, 05:38 PM
Aaron Wallace is offline
Find More Posts by Aaron Wallace
Aaron Wallace's Avatar
San Diego
Joined Oct 2006
Originally Posted by Althorpe1 View Post
Is there any place to get parts for the FMS Pitts biplane? Today I was flying her for the 5 th time and all of a sudden it made a loud noise and I noticed two of the prop blades broke off and yes I do balance my props. Well this caused the motor to wobble and break the plastic motor mount. She landed ok but hit a small tree in yard on my emergency landing and broke the elevator. This really suck because I really liked that plane. Anyone think BH will replace? So if there are no parts is this a 260 dollar piece of foam on wheels?
If you can't find parts for a time, maybe you can make an elevator out of balsa.
AAron
Aaron Wallace is offline Find More Posts by Aaron Wallace
Old Dec 08, 2012, 06:48 PM
borntoolate is online now
Find More Posts by borntoolate
Bomber Bob
borntoolate's Avatar
United States, CA, Cupertino
Joined Mar 2012
Try www.pw-rc.com
http://www.pw-rc.com/index.php/cPath/124_149
It shows a Pitts elevator in stock. Not sure if it is the right one for you.
btl
borntoolate is online now Find More Posts by borntoolate
Latest blog entry: FMS B-25 bomb bay mod
Old Dec 08, 2012, 10:09 PM
condor12 is offline
Find More Posts by condor12
Dinosaur
condor12's Avatar
Australia, TAS
Joined May 2012
Well, finally assembled my FF and took it out to the front paddock (reasonably close cut grass and dirt/dust) for low and high speed taxy trials. Two low speed runs went well, but on the second high speed run the aircraft just lifted off (two or 3 inches) and the port undercarriage wheel and leg assembly fell out of its upper sleeve. Pulled power off and the aircraft slewed to a halt in a cloud of dust with one broken blade and the oleo door snapped in two. The inner doors were ok. Fortunately I had fitted wing tip skids in case this ever happened so there was no other damage (tip didn't even hit ground). On investigation I found the grub screw showing two thread out of the sleeve. Both trunnion grubs were also loose. The starboard side U/C exhibited the same loose condition. I know I should've checked but I didn't . QA is obviously a little lacking at production level! Anyway, a word of warning for those new to this bird - check all nuts, bolts and anything that moves! She's all fixed and ready for a maiden early January.
condor12 is offline Find More Posts by condor12
Old Dec 09, 2012, 01:44 AM
San Diego
Joined Oct 2006
Happy to hear your Mustang survived OK. Indeed all screws fittings and structural supports need to be inspected for integrity in ARFs. Especially a complex one like this P-51.
Aaron
Old Dec 09, 2012, 10:43 AM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
This has always been an on-going issue. Always check the motor/mounts, the E-Tracts, even the servo arms for security. You don't know if that plane you got didn't come off the line at 5:00pm on a Friday?
Gary
Sandancer is offline Find More Posts by Sandancer
Old Dec 09, 2012, 05:28 PM
joerayy is offline
Find More Posts by joerayy
I make crashing look easy..
Canada, ON, Hamilton
Joined Nov 2012
Thx for the tip ... with mine I assembled and went straight to flying without incident. Probably not the best thing to do. Will check these items before the next flight. What an awesome plane !
joerayy is offline Find More Posts by joerayy
Old Dec 09, 2012, 06:44 PM
condor12 is offline
Dinosaur
condor12's Avatar
Australia, TAS
Joined May 2012
Hard lesson to re-learn!!
Shane
Old Dec 10, 2012, 07:36 AM
TFOA is offline
Find More Posts by TFOA
Super-duper Airplane flooper
USA, OH, Toronto
Joined Oct 2009
I need to reinstall the gear sequencer, but as there are no markings on it, I am at a loss. Can someone help me out and let me know which one goes where? IE: inner doors on left, maingear on right or vice versa. Thanks!
TFOA is offline Find More Posts by TFOA
Old Dec 10, 2012, 02:54 PM
vilhelmsson is offline
Find More Posts by vilhelmsson
Sweden, Skåne County, Malmö
Joined May 2012
Regards Anders
vilhelmsson is offline Find More Posts by vilhelmsson
Old Dec 10, 2012, 03:21 PM
TFOA is offline
USA, OH, Toronto
Joined Oct 2009
Thank you Anders!
Old Dec 10, 2012, 04:02 PM
srt8madness is offline
Find More Posts by srt8madness
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
In regard to sanding you really aren't going to be sanding enough to make a difference in the airfoil of the blade
So don't be afraid to sand
It won't hurt :
Originally Posted by PeterVRC View Post
I would not be grinding off parts of a blade!! Near the hub or not... let alone that near the hub is fairly useless, as it is so close to the point of pivot!! And change in a surface, from smooth to....??? 'dented', slotted, 'holed' etc etc adds a point of weakness. Umm, "Weaker-ness"...LOL. Weaker than it was in its pure form.
V8's mentioned ways of tape, paint, ca.... out on the blade.... is far more technically sound.
I think the paint idea is the best, as far as the least alteration of the blade and airflow. Though I use a band of tape myself - making sure the ends are 'downstream airflow' so they will never lift off themselves over time!
You also can't do anything that alters the blade area out in it working airflow areas. eg sand or trim back/off any! That would cause an 'aerodynamic imbalance' only seen when the prop is in use.
srt8madness is offline Find More Posts by srt8madness
Old Dec 12, 2012, 04:40 PM
jdm2ner is offline
Find More Posts by jdm2ner
flying is everything
jdm2ner's Avatar
United States, FL, Hollywood
Joined Oct 2010
ok just finished the cradle a few days ago. Now its all done.
jdm2ner is offline Find More Posts by jdm2ner
Old Dec 12, 2012, 04:54 PM
jdm2ner is offline
jdm2ner's Avatar
Joined Oct 2010
bump
Old Dec 12, 2012, 05:22 PM
San Diego
Joined Oct 2006
Looks like that will work well. I was not able to see the video though.
Aaron
Old Dec 12, 2012, 05:25 PM
jdm2ner is offline
jdm2ner's Avatar
Joined Oct 2010
click on the link on top of he video insted of play
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 02:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 01:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 11:08 AM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2010 09:38 PM
For Sale Guillows North American P-51 Mustang SupaMan Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 09:07 PM
